Looking for gear & accessories advice
3 replies183 views
Rudy avatar
I have recently got into astrophotography and use a stock Canon 7D mark II with 400mm f/5.6 and 50mm f/1.8 II. My circumstances don't let me spend more than 2/2.5 hours out photographing hence the amount of total exposure time I can manage is limited.
Till now I have only managed around an hour of data couple of times (https://astrob.in/full/strjmh/0/ & https://astrob.in/z8xjyc/0/).
I believe the following can help me gather more data in the limited time I got. I am looking to photograph DSO in the range of 50mm to 300mm.
1. HA mod of my DSLR / or get a used HA mod DSLR (if second option, any suggestions?)
2. Get a used f/2.8 lens which gives reasonable results at f/2.8 (I don't pixel peep, so bit a of coma is fine in the corners). Thinking of two lenses... 24-70 f/2.8 & 70-200 f/2.8, zooms because I will be able to use them in day time photography as well. Any recommendations? Have heard good stuff about the old Tampon 70-200 f/2.8.
3. Is the Red-dot finder helpful? Finding the object quickly can be very helpful considering the limited time I get. Any views on this one - https://www.widescreen-centre.co.uk/omegon-red-dot-finder-for-dslr-flash-shoe.html?
4. Any other suggestions?
Thanks in advance.
- Rudy.
With reasonably dark skies you'll be all right with the standard 7Dii but the filter mod will give you a better Ha response. Lens I am afraid is a bit a thorny subject as the good Canon ones are really expensive. You could get Nikons but those would be short of full functionality. Best option here is to get a Samyang/Rokinon 135mm f/2.
Médéric Hébert avatar
Depending on why you can't spend more time astro imaging, automating your kit could potentially give you a lot more exposure time without a greater time requirement on your part.
verticalmagic avatar
I would vote for the Ha modification, and I second the automation comment, for example with Nina. There are a lot of well made tutorials to get started on Youtube. Plate solving will make you save a lot of time. Plus it is a step that will be the basis for future further developments.
New scripts for PixInsight: ExtensionToolset
Hi everyone, I have developed ExtensionToolset, a collection of scripts to support image processing and analysis in PixInsight. Features included in ExtensionToolset: - AdditiveColorCalibration: A high-accuracy and robust additive color calibration t...
PixInsight scripts may help optimize limited astrophotography data processing workflow.
Aug 10, 2025
Finding targets in light polluted skies - any tricks?
Hello everyone! As you can guess from the title, I’m still fairly new to this hobby. I have a tracker but not a go-to mount unfortunately, so all my targets so far have been the classic easy ones to find - the ones you can pretty much see with the na...
Light pollution workarounds relevant for maximizing target acquisition in limited time.
13 days ago
New scope/lens for current setup under $500?
Hello,Here is my current setup:-Canon 6D-Star Adventurer GTI-Rokinon 135mm I shoot DSO in a bortle 6 location. Basically, I want a new scope that has a longer focal length under $500 that will be supported with my camera and star tracker. I have hear...
Gear and accessories advice directly addresses author's equipment questions.
Feb 20, 2023
[RCC] - Help with Andromeda
Hello! I have been taking pictures of DSO's for about a year or two, and have slowly been getting better and better pictures. I recently took some pictures of the Andromeda galaxy, and i really can't pinpoint what to improve, other than just ...
Similar gear setup; seeking advice on improving astrophotography with comparable equipment.
Feb 27, 2023
Hello from France / Bonjour à tous !
Hi ! Really happy to be on astrobin, I am returning to astrophoto after a few years not having much time for it. I began astrophotogrpahy in 2006 mainly using telescopes from the Observatoire de Haute Provence in France, now I am focused on light gea...
Author testing multiple lenses; candidate seeks gear advice for similar setup.
May 4, 2023
