What would cause this with 2600mm camera?
10 replies383 views
Dan Kearl avatar
I am at a loss, same setup 3 nights in a row, first 2 nights excellent, third night images are way over exposed at same settings.
I am posting the Ha images, Oiii and Sii the same. The entire 3 hour session all the same.
300 sec images, 100 gain, -10c
Equipment:
Zwo 2600MM
Zwo 7 position filter wheel
Antila filters.
Askar 600 scope.
Darryl Ackerman avatar
High thin clouds will do that
Clouds, fog, mist…
Alex Nicholas avatar
That's cloud… very thin, probably couldn't see it with your eyes, but that's cloud alright.
It seems you have a bayer pattern in the second one, which is kinda odd.
Reg Pratt avatar
I've had this happen once with my 2600 and twice with my 268. Had to send them in for repair. As a matter of fact my 268 is at the repair center right now for this exact same issue.
Rick Krejci avatar
Hard to tell what overexposed is from stretched images.    What to the histograms look like from these 2 images?
Dan Kearl avatar
Yes it does, I am afraid this was not a high cloud issue (there we're none).
I guess I wait for a clear night to find out but I am afraid it is the camera.
Dan Kearl:
I have a pole master attached to the dec plate and take an image every 60 seconds so it's looking where my scope is. You'd be surprised at the high clouds that you cannot see are actually there. You can tell by obviously seeing the bright clouds that pass by but also by the varying intensity of the brightness from frame to frame. You may not see them, the weatherbug or whatever app will say there's none but it's very likely they are there.
Could be dew, high humidity, fog, I doubt it's the camera.
The bayer pattern could be from star alignment interpolation, if these are aligned images.
Bob Rucker avatar
One more possibility. If it was cold and humid and you did not turn on the camera dew heater the sensor could have frosted up. I'm a brand new 2600MM owner that just moved from the Arizona desert to ice cold central Washington. I just learned this lesson myself.
Dan Kearl:
*Hopefully it can be fixed without resorting to sending the camera away. Mine died on me just there and then.
Large aperture planetary setup heavily underperforming for an unknown reason
So this Jupiter image i took recently, its somewhat decent i would say, but as im exploring this site i notice people getting far better results with significantly smaller telescopes and less data, makes me wonder what am i missing / doing wrong. For...
Equipment troubleshooting for exposure consistency issues with ZWO cameras.
Jan 20, 2026
Mysterious star trailing solved: a cautionary tale of fan vibration with a fan cooled (especially ZWO) camera.
Suddenly after no problems with star shapes, the next night out they were just terrible! Below I show a gif comparing two 2 hr stacks, one with the good stars, and the next with elongated stars. In this example the distortion was vertical. But later ...
Environmental factors affecting image quality; fan-cooled camera performance issues.
Nov 18, 2025
Similar artifacts on different setups on M45
Last night I was imaging M45 with my dual rig which consists of: Tak TOA-130, Player One Zeus (IMX455), Chroma LRGBHSO WO Cat 91, Player One Zeus (IMX455), Chroma LRGBHSO AP Mach 2 mount So both scopes were imaging at the same time in parallel and im...
Systematic artifacts across imaging sessions; multi-filter setup diagnostics.
Dec 15, 2025
