I currently have an exos2 with a cheap 4" f10 achro. My AP attempts so far have been limited. I want to get a faster newtonian so that I can try AP again. I know the EQ5 is limited but I did manage some shots with it by keeping exposures low, change to an F5 newtonian will help there as my exposures can be a quarter of what they are. The mount is small but the budget doesn't permit anything better right now and a small 5" - 6" newtonian should be a similar load to my refractor. In addition to that I now have a goto unit on the EXOS2 which I should be able to drive through an ST4 and use guiding. I have a cheap 80mm f5 refractor which is waiting to be used for guiding.
Everything in the setup is secondhand or homebuilt which probably give some idea of the budget.
So with all the above where would you start building an AP setup. I have the choice of skywatcher 130pds, 150pds or at a push an orion optics VX6. The 6" should presumably offer a slight resolution advantage and bigger image size but other than that is there any reason to not use the 130pds?
Ta
Ta
