Is it worth upgrading to a SW quattro 150?
4 replies469 views
Menelaos avatar
Hey guys whats up?
I need opinions on this. I own a SW 150/750 explorer. I tuned it for astrophotography quite well and i am kind of happy with the results i get. I was wonderIng though is it worth upgrading to a SW150 quattro?? I know this one has bigger secondary mirror, faster focal ratio, and with a reducer i will get even faster, and i plan to cannibalise the explorer to hypertune the quattro. But! My question is: Is this worth? Will it make a noticeable difference from the explorer? I mean they are both very similar in design. Should i just go with a completely different scope? Of course i dont want a refractor i am a Newtonian guy i love those scopes! Shoot your ideas. Thank you.
It ain't worth the effort. If you want to step up go bigger and then let it be a Quattro (or whatever as long as it is good and fast).
Bela Szabo avatar
Hi Menelaos,
I've been using a 150 Quattro for a while now and I have to say that I'm pretty happy with the results.
As you've mentioned, with its coma corrector the focal ratio goes down to f3.45, which makes it much faster than the f5 Explorer.
Although on paper it sounds good, but its less forgiving. I mean your collimation has to be spot on, your guiding has to be precise.
I modified my scope quiet a bit. I feel som of them are mandatory, some of them are nice-to-haves.
The three mirror clips produces some weird artefacts around the stars so I replaced it with a 3d printed ring with the proper height and the holes in the appropriate positions. This reduces the aperture slightly but I was willing to make that sacrifice.
I also changed the secondary spider for a billet aluminium part, which is rock solid and while the scope was in peaces I also flocked the inside. Than a round plate was added behind the primary mirror cell to reduce light leaks.
The reason I'm writing all my struggles is to let you know that this scope has some potential to be great (at least in my opinion anyway), but out of the box state is a sort of budget scope.
if you like to thinker with things and not bothered spending significant amount of time collimating it after reassembly and also not bothered spending extra money on upgrades I say go for it.
If you plan to use it as it is, you might want to look at some better built, more premium unit (a Carbonstar 150 or a 15028HNT from Sharpstar) or go bigger if your mount can handle it.
[deleted]
You have a good scope and as I understand you have upgraded it, do not bother your self with speed, speed comes with some problems. And slower scope gives you better detail!!!! And not to mention that it's not that big difference in speed f4 vs f5, it is difference but not that you will notice that in real world usage!!
It's the same aperture so it's not that much of an upgrade. You'll gain some speed and the FOV is larger but that about all. The cost will be a more finicky OTA and if you go beyond F/4, you'll need to replace your narrowband filters with high speed versions.
Helpful Insightful Concise
Newt to complement 80mm APO?
I currently image with a TS Optics 80mm APO (544mm, f/6.8) on a SkyWatcher Wave 150i, with a Touptek 533 and filter wheel. The image quality is great, but under Bortle 7–8 skies here in Ireland, the limited number of clear nights means f/6.8 forces m...
Discusses imaging with similar aperture Newtonian telescope and astrophotography setup.
Oct 23, 2025
Upgrading from Quattro 200CF to 300P: seeking owner experiences and advice
I’m seriously considering upgrading from a Quattro 200CF to the Quattro 300P and would love to hear peoples’ opinions on the scope. I plan to get a CEM70 to run it. My image train is the ZWO ASI2600MM, ZWO 7×36 EFW, ZWO OAG-L, ZWO EAF. I already own ...
Directly addresses upgrading between Quattro models; seeks owner experiences and advice.
Aug 28, 2025
Seeking advice on next steps in my astrophotography journey
I’d really appreciate your views on the next steps on my Astrophotography journey. Having been doing this amazing and absorbing hobby now for just under two years, I know that my journey has progressed from bafflement with how to use the equipment an...
Covers decision-making for next steps in astrophotography journey and equipment upgrades.
Feb 5, 2026
attaching DSLR to Celestron C6-N
Hello, sorry for this question. I couldn't find a complete answer anywhere. I want to buy myself a telescope for both observation and astrophotography. I am currently using my school's telescope (Meade lx85 8" Newtonian) for both observa...
Compares telescope upgrade options for astrophotography performance improvement.
Jun 13, 2023
