Bad collimation or defect on Apertura 8" RC
jmdl101Rodrigo RoeschOlivier ConstansNirajTony Gondola
65 replies2.5k views
Rodrigo Roesch avatar
HelloI recently purchased an 8" Aperture CarbonStart RC telescope. In order to check the collimation, I removed the secondary baffle extension, so I can see better the entire reflection of the primary in the Cheshire eyepiece. One thing that called my attention is the reflection of the primary in relation to the optical axis is off center. The secondary mark seems to be well centered to the pinhole of the cheshire and the concentricity of the secondary holder in relation to the primary also seems to be good. So does it means that the primary cell is not centered well in relation to the telescope tube? The stars at the corners do not look very round, they have a bit of a triangular shape. I am including a single frame taken wiht ASI2600mc at native FLThank you for your help
Tobiasz avatar
To check the collimation you always have to shoot the stars out of focus. There you can see the state of the mirrors better.
jmdl101 avatar
I have similar results with my RC8. The outer ring of light is not concentric when the secondary donut is centered and the inner baffle ring is concentric. I've adjusted the tilt plate to bring the outer ring concentric and everything looks perfect, but I haven't had a chance to star test yet.
Well Written Concise
Ethan Pearson avatar
I also picked up the RC8 carbonstar. I do have pulled stars in the top two corners as well but I’m pretty sure it’s collimation on my part. It’s also my first RC coming from newts and learning about what it wants. Using an OCAL 3.0 to get close then fine tuning with defocused stars.
below is one of my screenshots through the ASIAIR with poor seeing conditions.
Tobiasz:
+1 on this. Rack it well out of focus and that should tell you right away if your collimation is off.
Ethan Pearson:
Thank you. Your picture looks similar to mine. I ordered the collimation focuser plate  so  I can do what you are describing
Tobiasz:
What is not clear to me is what to see in an out of focus star in this telescope.  Assuming the star is in the middle of the field of view, if the secondary shadow is not concentric to the white disc of the star, does it mean the secondary needs to be collimated? I have seen two videos: One tells to move the secondary to center the shadow in the middle of the bright disk, the other video tells to move the primary to center the shadow in the middle of the bright disk. What is the correct way to do it?
Thank you
Rodrigo Roesch:
Thank you
Neither. Centering the secondary against the primary with respect to the image plane (e.g., the Cheshire crosspiece) should done ahead of tilt correction which is what you do either using a tilt plate.
Freddy Meiresonne avatar
To refer to the first post : triangled shaped stars mean pinched optics. I noticed i easily can get triangled shaped stars by just tighten the screws of the sec a tad too much. From the moment you feel a little resistance do not screw it any further. The word 'tightening' is almost an overwhelming word for my screws on my sec.
Freddy Meiresonne (Fmeireso)To refer to the first post : triangled shaped stars mean pinched optics. I noticed i easily can get triangled shaped stars by just tighten the screws of the sec a tad too much. From the moment you feel a little resistance do not screw it any further. The word 'tightening' is almost an overwhelming word for my screws on my sec.
Thank you, I most have tightened too much when I collimated the secondary
Monty Chandler avatar
After a lot of failing I finally got my rc8 collimated by doing what is described in this video by Allen Mitchell.  https://youtu.be/a3UOGDUaq6o?si=jhTRuCQY4Y0lWvca
jmdl101 avatar
Well I went ahead and bought the Apertura rack and pinion focuser from highpointscientific, hopefully it will actually fix my focuser droop with my heavy imaging train.
Bill McLaughlin avatar
I have only seen one Apertura scope and that was a dob that a friend bought but it was so badly made that the spider had been mounted too far forward so as to put the secondary in a position that it could not be centered under the focuser and could not be collimated. It was sent back. That was enough to convince me to stay away from Apertura.
Just one data point but I was stunned that it could have left the factory with that huge an issue.
jmdl101 avatar
Someday I'll learn how to collimate this thing, not today, but someday. Everything looked great inside, not so much now. I thought my defocused issues were just thermal since the scope had only been outside about 30 minutes when I checked, coma and astigmatism looked pretty good though. Now I have these ugly looking star shapes. I do like testing just how much blurX can fix.
I cropped off the guiding graph, but I'm at 0.4 to 0.5 tonight so I doubt that's causing my issue.
That really looks like guiding error to me. At 1800mm 0.5" RMS might not be good enough, especially if the delta error is high between RA and DEC. I shoot at 900mm and can certianly see the effect if guiding gets much above 0.6" RMS.
Helpful Insightful Respectful
jmdl101 avatar
It's with the reducer at 1100mm, but the stars look the same blobby and spiky in the sharpcap live view at 1 second exposure length. I really think it's just my collimation, plus ASTAP is showing 23% severe tilt, that's probably not helping either. I think I'm just going to start over once I get the new focuser, maybe try it one night without the tilt plate at all.
Oh wow, a lot of things adding up then.
jmdl101 avatar
At least blurX can compensate for my failure. This is correct only mode.
That still looks liked pinched optics to me…typically triangled shapes stars….
jmdl101 avatar
Freddy Meiresonne:
That still looks liked pinched optics to me...typically triangled shapes stars....
So I just checked it and again the secondary is a good bit off center even though I checked it inside just before taking it outside to put on the mount. Something is happening in the few minutes between those two points. Maybe it's the temperature change from 70f to 40f, maybe it's the way it clamps down, I don't know. I do know that from now on I guess I'll do the collimation after I clamp it down on the mount.
It's a pretty significant shift, from dead center to black dot below the first ring looking through the cheshire (RCKOLLI), takes about a half turn on the secondary screw to get it back, crazy for just moving the scope from inside to outside. I'm sure it's my fault whatever is happening.
Pinched optics could still be possible, I'll double check my primary screws.
jmdl101 avatar
Also, probably unrelated, maybe not, the silver focuser rail is clearly visible now that I have the scope outside pointing at the sky. I wonder if this could be causing some weird reflection or diffraction on brighter stars, it's much more shiny than in the picture here. I used a black marker on mine and it looks better. No secondary mirror shift putting it on the mount so now just waiting on temperature to stabilize so I can slew it around and see if it moves. It's just weird to me that mine has now done this at least the last two nights I've used it so I really want to figure out what's causing my mirror to shift so bad.
jmdl101 avatar
Well, I've confirmed my indoor method does not work whatsoever for collimation, at least not with the camera attached. After collimating with my TS RCKOLLI and putting the camera on, I decided to check with the DSI method. It was very much way off, secondary and primary. After about 20 minutes of work with the DSI method, I'm really close and nearly all my star issues are gone. A 5 minute exposure from my blue filter from just now.
jmdl101 avatar
Just a quick update, the rack and pinion focuser from Apertura looks to be perfectly centered with the tube, unlike the stock focuser that was heavily tilted. I'm hoping my next star test will show much less tilt and significantly better stars, just have to wait on the clouds to go away.
Olivier Constans avatar
I got this kind of star shape with my RC10 when the polar alignment is not perfectly ok ;)
Also I am using ocal to collimate the RCs (I have 10,8 and 6')  it is working very whell but you also need to remove the primary baffle to have clear view of the spider and all the circle  inside. Then just follow the tutorial ocal has done for collimation of a RC6  because it works for all size of tube.  The only thing I do more is to adjust the tilt ring to center the black dot that remain not centered in the RC6 tutorial from ocal. After that I have nothing to touch  , the residual tilt is less than 9%.
The picture below show a residual tilt before I adjust the tilt ring, the spider is not perfectly aligned
at the end you have something like this
Olivier Constans:
Are the blue arrows indicating the separation between the primary and the tub? do you center that by using the focuser tilt plate?  That is the part that looks off in my scope
Thank you
Collimating question /Ocal collimation
Help need before i go stir crazy , scope is a 200pds ,fitted with a baader steeltrack focuser , now i inputted ocal camera focus code into text file ,for the life of me i cannot align the primary edge and get the donut centred at the same time ,see p...
Addresses collimation problems and diagnostic methods for reflector telescopes.
Feb 6, 2023
Collimation Problems
Hello guys. I just acquired a Sky-Watcher 150/750 PDS Newtonian and I am new to the whole Newtonian thing, I watched videos and read articles about how to collimate and I follow through all the techniques (Cheshire eyepiece, collimation cap, laser co...
Same telescope model; collimation and optical issues directly relevant to your setup.
Sep 21, 2023
Keep RC 8 or sell and purchase a Skywatcher Quattro??
Hello I`m contemplating selling my RC8 in order to buy a fast newt something like a Quattro 8 or 10. I love the image scale of the RC8 and guiding doesn`t seem to be an issue with my OAG on my EQ6R Pro. Just wondered what you guys and ladies think? C...
Author considering RC8 sale; collimation issues relevant to telescope evaluation.
Sep 15, 2023
GSO RC rear cell design - 8in closed tube vs 10in truss
Hi everybody, I’ve been hunting to get a longer focal length telescope (900 - 1250mm) to image smaller targets for quite a while now. Currently Im 90% sold on getting the TS ONTC - 8” F4.5 Newtonian… But I really like the idea of an 8” RC as well… I ...
Directly addresses 8" RC collimation issues author is concerned about.
May 26, 2023
