Fluorostar 91 -ZWO EAF
6 replies270 views
Ricky Graham avatar
Has anyone ever put a ZWO EAF on a William Optics Fluorostar 91?
just curiosity to see if it’s compatible
Ricky
David Nozadze avatar
You think it will not fit? Looks like if you remove one of the manual knobs, it will work perfectly. Just in case you may want to order a Takahashi bracket together with the normal one from ZWO.
Steven avatar
Not 100% sure.
Best I can find is this guide  , of the installation on the 81mm William optics.
Perhaps you can see and judge wether or not the construction of the focuser is similar enough to look if it would fit.
All I know, is that the brackets and adapters are pretty versatile and forgiving and it doesn't take much to line things up correctly.
I'm using mine on one that 'technically" isn't supported by the bracket. But it does work.
ZWO also lists a diagram with all the measurements of the bracket. You might be able to measure if it fits the holes on your scope.
So far, any image I've seen of the EAF being installed on different William optics, have been with this bracket.
And there is also the other bracket for Takahashi scopes if it doesn't suit.
Hope this helps, as I haven't been able to find a guide specifically for the 91.
But if the focuser and holes are similar, it should work.
Michael Massie avatar
I bought a FLT 91 a few months back.  The ZWO EAF will definitely fit on the coarse focus knob on left side.  You have to take out a screw on the bottom of the focuser to get to the 2 set screws holding the knob on and then remove knob.  The rest is the same as with other scopes.  Warning, the EAF and focuser shaft will probably be touching in the flexible coupling.  That was my only issue,  I didn't get the set screws tight enough on my first go.
Michael
Ricky Graham avatar
Michael
Thank you Michael, exactly what i was looking for! Someone who has tried and tested it! How are you finding the scope?
It works pretty well for me. I’m just an old guy doing his thing. The R/F is not great but I’m a WO guy. Up until  2 months ago I had a Redcat, GT81, FLT 91 and FLT 132. Thinking about another 132 to dual on my MX+ mount
Roy Hagen avatar
Hi Ricky
I would be very surprised if the EAF doesn't fit the focuser on the FLT 91, as I have the focuser installed on both my telescopes, The FLT  132 and the Zenithstar 61.
The bracket is a bit to short to reach to the opposite side of the  giant focuser on the FLT 132, but there are more threaded holes.
Go for it👍
Best of luck
Roy
BACK FOCUS ISSUE - Williams Optics FLT91
In my recent sessions with my WO-FLT91 with the Flat6AIII flattener, I have noticed that the stars in all four corners are elongated, indicative of back focus issues. I checked this in the aberration inspector process in PixInsight and I am consisten...
Discusses William Optics FLT91 scope compatibility and potential mechanical constraints.
Sep 29, 2023
William Optics FLT Dew Shield
Hello, I want to ask if there is a way to remove the dew shield of the William Optics FLT91 scope? I know it can be retracted but l'm trying to remove it to be able to put it in a travel bag. Can you please share with me if that's possible an...
Addresses William Optics FLT91 physical modifications and accessory compatibility questions.
Mar 15, 2023
