Random Blank lines of Pixels
5 replies•284 views
GiffS avatar
Last night for the first time I had several images that had random horizontal blank line's part way through them. They would appear in one sub then disappear for a few then return in a different position. I was having some other issues, so I turned the camera off and back on then I restarted my ASIAIR and the problem went away. Anyone else have this issue or know what it might be?
TiffsAndAstro avatar
Nope. Have you changed the cameras power supply recently?
Or usb cable is on its last legs
GiffS avatar
TiffsAndAstro:
I suspect that the USB cable is the culprit. It's been in service for a couple of years and just the other night it might have gotten pulled a bit during a flip.
The0s avatar
I'd second that's its probably an issue with the USB cable - I've had similar issues pop up with my ASI533MC Pro, too. We're you using the default cable, and if so, was it cold outside? I typically start experiencing issues when the temperature goes below freezing.
Concise
GiffS avatar
Yes to both. I need to find a good source for the USB A to B angled cable.
TiffsAndAstro:
GEt a replacement, keep the old for desperate emergencies only
Strong Horizontal Banding
In the last few days I found that the images acquired by the Altair A26C (a rebrand of the Touptek equivalent IMX571C-based camera) is starting to show significant and variable horizontal banding and I'm wondering whether the good people of AB ma...
Horizontal banding in images matches author's blank line artifacts.
Dec 9, 2025
Issue in ASIAIR autostretch preview, or actually FITS corrupted?
Good morning everyone. For some time now, I’ve been experiencing a strange issue during acquisition with ASIAIR PRO using the ASI678MC on long exposures. The phenomenon is particularly easy to isolate and observe by acquiring dark frames, so I’m shar...
ASIAIR acquisition issues with image artifacts similar to reported problem.
Aug 14, 2025
2600MC Pro disconnection issues
Hi all, Having an issue with disconnects every since getting a new 2600MC Pro. I am using an ASIAIR Plus and have had over a year of use with a DSLR without this issue ever occurring. This my 3rd night of using a new 2600MCP and on each night have ha...
ASIAIR Plus connection/restart solutions relevant to author's troubleshooting approach.
Nov 25, 2025
