Help with large ring in images
2 replies•151 views
Kieran Gunessee avatar
Hello,
I have recently started to get this large ring in my images (see below). I believe my flat frames are causing it but I don't know why.
I have cleaned my optics thouroughly (filters, coma corrector, mirrors), yet the ring persists - it's the same before and after cleaning. Flat frames calibrate various dust spots and the like, but it keeps this large ring. I also can't see this on the flat frames directly.
To test, I stacked my light frames with no darks (ring still present), then no flats, which didn't show the ring, hence my conclusion that it is related to the flats.
I'm using a Skywatcher 130PDS, ZWO533MM Pro, Optolong LRGB Filters and a ZWO Filter wheel.
To create my flats, I simply use the 'white t-shirt' method, by putting a white t-shirt over the end of the scope and placing a diffuse light panel on top. This has worked well for years, but has just started giving me this issue.
Weirdly, this ring doesn't show on my narrowband images, only LRGB.
Any help would be appreciated!
Thank you,
Kieran
Well Written Helpful Respectful Engaging
Arny avatar
Hi Kieran,
I had a similar issue getting these donuts despite taking flats and none of it showing on the flats, which drove me crazy.
Try setting ZWO filter wheel to unidirecional:
when you take flats vs. lights, you might approach a filter from different directions, which create an ever so tiny shift between dust moats on the filter.
Going unidirectional on the filter wheel fixes that by always approaching from the same side.
Takes a bit longer, so you might want to wait a sec before taking an image.
Hope that helps!
Arny
Helpful Insightful Respectful Supportive
Either a light leak during either flat taking session or during light frame captures or somehow something has changed in the imaging train. Way more likely the former than the latter. If the FW doesn't get in the same exact position for each filter change this is also a possible cause. You don't see the effect with NB filters because there is hardly any background.
Concise
Taking Flats with the Edge HD 8"
I've found a way to take flats with my Esprit 100 ED refractor that seems to work well. After achieving good focus using a Tri-Bahtinov mask and locking down the focus lever, I take a photo of the image train and drawtube focusing scale so I can ...
Large ring in images may result from improper flat frame acquisition methods.
Jan 16, 2023
Weird SPCC graphs?
What does it mean when all your integrated pictures have a SPCC graph that looks like this one? For background, I'm using a C8 + Hyperstar 4 + ASI2600MC Pro + ALP-T Highspeed dual narrow-band filter on NGC6960. On another, but possibly related no...
Discusses artifacts in images potentially caused by flat frame problems.
Aug 11, 2023
Vertical Banding
Hello all, I hope you're doing great. I've purchased the Touptek2600c (tsoptics rebrand) around 2 or 3 months ago, as per usual, the weather wasn't cooperating, so I had to wait arund a month before I could start shooting. My plan for cle...
Flat frame problems commonly cause ring artifacts and image defects.
Jul 21, 2023
Flats adding to images instead of subtracting in PixInsight WBPP
Astro Friends, I have been imaging for about 5 years and have been successful using refractors and mono imaging. I have branched out this year and now have an SCT and mono setup. I am seeking help with my flats which seem to add themselves to my imag...
Flat frame calibration issues in PixInsight could cause ring artifacts in stacked images.
Jan 2, 2026
Question about LED flat panels
Hello! For those of you that are using one of the following flat panel (basically a flat panel available in EU that's NOT and EL panel): * PLL Giotto * Artesky * Pegasus LED Can the brightness be lowered so that I don't have to stack anything...
Flat frame issues may relate to brightness problems with flat panel equipment.
Feb 13, 2023
