Askar 130 PHQ field Flattener
9 replies239 views
Jerry Gerber avatar
Does anyone know if the field flattener is in the drawtube of the focuser or if it's in the scope's tube?
I ask because I am replacing the stock focuser and won't be able to use the Esatto 3" if the flattener is inside the focuser.
Jerry
Alex Nicholas avatar
I think, for it to work the way that it is intended to work, it must be in the telescope tube, as that is the only way that it could be at a constant distance from the objective lens at all times. If it was in the focuser, its distance from the objective would be different at all different focus points, resulting in altered correction between focus points..
Flatteners can work two ways.
1 - Optical path is static between flattener and image plane.
2 - Optical path is static between objective and flattener.
In case 1, (normal triplet APO flatteners), there is a specified backfocus distance between the corrector and the image plane (usually 55mm). and as long as you're at the specified distance, and in focus, you should have a corrected image.
In case 2, (petzval setups) the specified distance is between the objective lens, and the flattener. And the result of that, is that it does not matter where the image plane is in relation to the corrector, so long as the corrector and objective are spaced correctly, the image plane will be corrected.
You should be able to check this pretty easily by removing your camera from the back of the scope, shine a torch up the focuser tube, and rack it in and out multiple times, you should see the reflection against the corrector, and be able to notice that it is static, compared to the end of the drawtube that is moving.
Helpful Insightful
Jerry Gerber avatar
Alex Nicholas:
Thanks Alex.   Askar just wrote me back and said the flattener is in the tube.  The Askar 130PHQ is a Petzval design.
Jerry
Yep, assumed so mate.
Good to go then!
Jerry Gerber avatar
Alex Nicholas:
Good to go then!
Well, not exactly, as the focuser I want Primaluce does not make an adapter to fit the focuser on to my scope.   I'd have to get one made custom, which I've always tried to avoid.   I may have to go with the Moonlight focuser which is more than I wanted to spend ($2900).
Jerry Gerber:
Alex Nicholas:
Good to go then!
Does Precise Parts make the part you need?
Jerry Gerber:
Alex Nicholas:
Good to go then!
GASP! My morning coffee is on the wall now....
Jerry Gerber avatar
Jerry Gerber:
Alex Nicholas:
Good to go then!
Don't know, haven't tried them yet. I know they are very expensive...
Jerry Gerber:
Jerry Gerber:
Alex Nicholas:
Good to go then!
Depends on one’s perspective of expensive. Regardless I would look into it.
Ashraf AbuSara avatar
To be fair the moonlight night crawler includes a rotator and adapters for your OTA. If you add the rotator to the 3" estato it will be $2300 without any adapters. The NC will be $2600. The 3.5" version is $2900 which is larger than the Estato.
That being said if you don't need the rotator, the Estato seems to be very reasonable.
EdgeHD 800 -- How long is the threaded tube on the back of the telescope?
Take a look at this Primalucepart: Adapter ESATTO 2" LP for telescopes with SC thread You'll see the threaded central hole goes completely through it. This means this part can screw down onto any tube even if the tube itself is longer than t...
Discusses Esatto focuser compatibility and back-focus considerations for SCT telescopes.
Sep 16, 2025
External focuser on an SCT; What about temperature change induced focal shift and back-focus?
It seems like every serious astro-photographer is putting external focusers on the back of the EdgeHD telescopes and locking the mirrors. I picked up a nice little EdgeHD 8" and a Primaluce Lab Esatto 2" LP focuser and gave it a try myself....
Addresses external focuser installation on SCT telescopes and back-focus issues.
12 days ago
