Jim Waters avatar
This is my current process flow for OSC processing without and with a general LP filter.  The process flow is a little different using Dual, Tri ...etc band filters.  I will update the process flow for PixInsight 1.9.2 MARS later.  Something to do when its cloudy outside.
C&C Welcome
Jim
Rev 1.0
01/06/2025
hughsie avatar
The only point of difference in my workflow is I remove the stars after completing your second round of BlurXterminator whilst the master image is in linear form. I then process the background separate to the stars.
Before introducing the stars into the stretched and processed background I use SETI Astros star stretch script. I like a stretch of 5.2 and saturation of 1.25 with SCNR applied.
If the target is an open cluster with no gas then I remove the stars as a simple way of creating a star mask and reintroduce them into the background once I have the mask and continue processing from there.
Thank you for sharing your workflow, it’s always helpful to see see how individuals go about this dark art!
astrojuanan avatar
[pre]I think this section is a great idea, since many of us often have a mess with our work flow. Thanks for sharing your wisdom. We could all do the same and improve every day. Thanks. I don't upload it because my flow is a mess hahaha.[/pre]
Astrogerdt avatar
Just adding my usual workflow here (but in a less fancy presentation ;) ):
Starting with a linear masterfile generated from DrizzleIntegration:
- Dynamic Crop
- BlurXTerminator in correct only mode
- ImageSolver
- SPFC
- MGC (fine-tuning of scale and smoothness parameters)
- SPCC (with custom ROI and all the filter curves)
- BlurXTerminator for general sharpening
- StarXTerminator to obtain obj and str images (containing background and stars respectively)
obj workflow:
- NoiseXTerminator
- MaskedStretch (to a brightness of 0.8, 100 iterations)
- (LocalHistograEqualization if I want to bring out some faint localized structures without boosting the contrast)
- CurvesTransformation, saturation adaption included
str workflow:
- HistogramTransformation
- CurvesTransformation (for saturation adjustments only)
Final combination is done in PixelMath using "combine(obj, str, op_screen())". After that, I apply ICCProfileTransformation and done!
Regarding the workflow at the top providex by @Jim Waters : Why do you apply SCNR after you used SPCC? If you already corrected the colors, there should be no reason to change them again. I, regarding my own images, always treat a reason to do so as a sign that I did something wrong during SPCC.
Additionally, according to Russel Croman, StarXTerminator works better before NoiseXTerminator is applied, so maybe changing the order in that regard may be beneficial to you.
CS Gerrit
astrojuanan avatar
- Dynamic Crop
- ImageSolver
- SPFC
obj workflow:
- NoiseXTerminator
str workflow:
CS Gerrit
I don't know why imagesolver always gives me problems, I have Galia installed but I don't know why
Astrogerdt avatar
If you want, I could take a look at that, probably a configuration issue.
Write me a PN or tag me in a separate thread, wouldn't want to hijack this one as it may contain a lot of useful workflows for others at some point in the future.
CS Gerrit
Supportive
Jim Waters avatar
I have seen others do this too.  Does this produce a better image?  Are the stars better?  I think Adam Block has a video on this.
Jim
Jim Waters avatar
CS Gerrit
Good question on using SCNR if I have already used SPCC.  Force of habit from a previous method.  I will have to modify my flow.  I will look into Russel's process flow.  Thanks for the heads up.
Jim
Astrogerdt avatar
Jim Waters:
CS Gerrit
Jim
One more note here, just for the sake of completeness:
For me, the goal is to produce an artistically pleasing yet as accurate as possible representation of reality. I like to think of my images as "showing what could be seen if we were closer and had better eyes" + a bit of art.
The goal of SPCC is to produce an image that is accurate in terms of colors. Applying any color corrections after this deviates from this purpose.
Depending on your goals, this either aligns with them and produces a "better" image (probably in case you are doing more art and less science) or it diverges from them and produces a less accurate image (in case you are doing more science and less art).
Note that I don't judge here, both ways have their own reasoning and importance. They are just hard to compare and make it impossible to define one "good".
Well Written Insightful Respectful
Jim Waters avatar
CS Gerrit
I agree.  Its likely a configuration issue.  I ran into this last year.
Jim
Jim Waters avatar
Jim Waters:
CS Gerrit
Jim
Good points Astrogerdt.  I just deleted SCNR from my process flow.  I also added Dynamic Crop to eliminate WBPP stacking errors and meridian flip issues.
Jim
Jim Waters avatar
I changed the flowchart name to Basic OSC Process Flow.  I will work on a more advanced process flow that follows Adam Blocks method of extracting stars / background in the linear phase after I play around with that method.  It was pointed out that doing SCNR on stars after SPCC doesn’t make sense and may alter the corrected star colors.  Dynamic Crop was mentioned but WBPP Auto Crop should address any issues.  I will check on Russel Croman recommended use of NoiseX and BlurX.
Again, this is something to do when its cold and cloudy.  Thanks all.
Mono camera advice: 2600mm vs 6200mm for bortle 8+ astrophotography
I currently have a 2600mc that Ive been using for a little over 3 years and need some camera advice for a possible mono setup. I live in bortle 8+ and only get to dark sky once a month or so. I’m more into clusters and galaxies than nebula, but I end...
Discusses mono camera setup; author mentions updating process for different filter types.
Dec 7, 2025
Adding Dual-Narrowband data to an OSC image
Hello everyone. After 2 months of cloudy nights I finally caught a night when I can take my telescope outside. For my next target I decided to image M 33. I bought a UV/IR cut filter and have been using that for the first night of collecting data. I ...
Directly relevant; author explicitly mentions dual/tri-band filter processing workflows.
Sep 19, 2025
Keep or sell my Optolong filters?
Hi, I have Optolong SHO filters with 6.5nm and 7nm 36mm since 2018, and i used them several times in the past without nice results due to LP in my area, and later when i added 3nm filters i no longer using those Optolong 6.5nm/7nm filters anymore, bu...
Relevant; discusses narrowband filters and LP filter considerations in processing.
Aug 22, 2025
