Hello,
I'm an absolute novice with respect to astrophotography as an activity, but on the technical side I'm quite well-versed in computational photography and image signal processing as I've published academic research and patents on CMOS/CCD denoising algorithms that are used commercially. Within astrophotography, I know there's a ton of things for me to learn and ideally it's probably more typical to organically increase my equipment complexity as I become more familiar with the field.
However, I'm in a unique situation where there's a significant one-time cash infusion coming and also a time constraint where there's a strong financial advantage for me to make any large purchases before year's end, so my somewhat naive/uninformed thinking is to go all-out on a single beefy "expert" system that will last me for years (maybe even a decade or more), and the budget is quite flexible (anything under $50K is doable, but I think it's probably gonna be $10-20K). Given all this, what would your suggestion be for the suite of equipment (telescope, mount, camera, etc.) I should look into for DSO imaging? Do you think there's any benefit to consider getting two setups - a simpler system and an advanced system, to help with the transition?
I apologize for any awkward vibe this post gives off but my predicament and interest are genuine. Thanks very much in advance for your insights, and looking forward to participating and learning from you all in the months and years ahead!
