What Causes Siril To Fail A Specific Script?
8 replies143 views
Szijártó Áron avatar
Hello and welcome. I'd like to ask everyone who uses Siril to process their astrophotography images.
I have been using Siril for quite a while since I got into astrophotography.
I am not aware of any script failure that can happen when processing an astrophotography image I took.
I know the most common script failure can happen while registration can happen. But I still wasn't sure what could cause these script failures. Since they are not related to a working directory problem, I can only guess they are related to the astrophotography image that is taken. For instance, if u run an OSC pre-processing script on an Image that has fewer stars with the object in it, Siril will simply fail the script when it's about to register the frames. But still wasn't aware of these script failures. Does anyone can tell what are those things that can fail a specific script in siril?
Rajat Kumar avatar
Szijártó Áron:
System memory, calibration, uer-side errors in classifying subs etc. There are many many reasons scripts can fail.
Rajat Kumar:
Szijártó Áron:
So I'm assuming most of them are related to system memory, I think.
Most of the time, the script can fail when it's about to register the frames. Or at least for me thats the common one.
The only script failures I have seen is if there aren't enough stars to do a global star registration. This can happen in star poor areas if your subs are really short or using long focal length OTA. When that happens I just run everything manually so I can chose the registration method that works with the data. It's not difficult and there are a lot of tutorials on YouTube that will step you through the process.
Oh yeah. I saw a specific video about manual processing in siril by Deepspace Astro. I have not watched it yet. I was just unaware of the script failures cause I only met the most common one u talking about.
I really need to take the time and mod the OSC script so I have a version the uses other alignment methods, particularly 3 star.
Ethan Sweet avatar
You can also just use Sirilic and have all the options you want.
I almost never stack inside of Siril anymore. I find Sirilic handles flat correction better than the OSC script anyhow.
Rebecca Kent avatar
It can fail for a number of reasons. My most common ones are if the images are different sizes, or the folders have not been named properly. Sometimes it can not register the stars and has to be done manually. Most can be resolved on further investigation. I have had to delete the process folder and restart the programme before, this also helps as it can get confused with previous runs.
Ethan Sweet:
That's true but I like the speed and simplicity of the basic scripts. I always go back into the process folder to open the calibrated and registered lights to run the various culled stacks I use for my workflow. It's all very quick and straight forward.
How Does The LRGB, HaLRGB And HOO Scripts is works?
Hello and welcome! I would like to ask everyone who uses Siril for processing astrophotography images to share their insights. I've seen videos discussing impressive scripts like LRGB, HaLRGB, HOO and HaRGB. My experience has been primarily with ...
Both posts ask the Siril user community for help understanding specific technical aspects of the software's image processing capabilities.
Nov 24, 2024
Which imaging acquisition and processing techniques could I learn more about to increase image quality and accuracy?
Hello, I use a full-frame mirrorless camera, I mostly do daylight photography, some night photography and astrophotography too. I did hightlight in bold keywords to make it easier to scroll thru, for those that don't want to read most of my post. Bef...
Both posts are from users seeking advice or sharing experiences about astrophotography practices and equipment.
Dec 29, 2025
Stuck in a rut looking for some inspiration!!
Lately, I have been just kind of “down in the dumps” about the quality of the images I have been producing. I feel like no matter how I much try and learn or try to pay extra attention to my data when processing, The results haven’t been satisfactory...
Both posts discuss challenges and frustrations encountered during the astrophotography image processing workflow.
Nov 17, 2025
WBPP experiencing "Unknown exception" errors during "Measurements"
I have been having issues with Pixinsight WBPP failing to measure a significant number of sub-exposures during the Measurements step with the reason as “Unknown exception. I have posted this issue to the PI forum and this time been told to use FBPP b...
Both posts describe technical problems encountered while using image processing software for astrophotography workflows.
Sep 28, 2025
Crossing My Fingers - Player One Service
It has been a while since I was able to actively pursue astrophotography. Life keeps getting in the way. Over the last two weeks, I have been conducting a deep dive into NINA and Pixinsight, and I have been practicing what I have learned every night....
Both posts discuss troubleshooting and learning experiences with software tools used for processing astrophotography images.
Oct 22, 2025
