Advice for someone starting with auto-guiding?
11 replies494 views
Nick Large avatar
Howdy,
I've been imaging for just over a year now and so far I've been very happy with my gear (IOptron Guider Pro + WO Zenithstar 61 + Nikon D5300 astromod)
But I've finally took the the next step in my AP journey...... Auto-guiding.
My setup is now improved with a WO uniguide 32, a ASI 120 mini, and the ASIAir Pro.
I gave it a try for the first time a couple of days ago with some test exposures on the Sadr region and I was super happy that I was successful on my very first attempt. It is really exciting to know that I'll be able to go past 3min subs.
I know there will be times where the guiding won't work as fine or that there may be ways to improves. So if anyone has pieces of advice about auto-guiding or things to look for or things to avoid please let me know.
Thx & CS everyone,
Nick
wsg avatar
The asiAir Pro is designed to be fairly foolproof and indeed a press one button and go process.  One bit of advise is to do a fresh calibration once you have your target framed, even though your prior Cal is saved I have found the guiding settles faster with a new calibration.
    1- set your guide camera gain to 50% of max gain and exposure to 2 seconds then "clear" calibration data
    2-calibrate guiding before starting Autorun
    3-start guiding mode in auto DEC with corrections switched on
    4-set both RA and DEC aggression to 50
    5-let guiding settle for a complete screen pass. it should be very good as it is but if RA is continually correcting and has a value over 70 or higher raise the RA aggression by 5 or 10.  If your seeing is average or better this is often enough.  If you are raising you RA agg, above 85 or so your seeing is shit or you have a setting that is not correct
    6- once your guiding is settled change your guide camera exposure time to 3 or 4 seconds
Let Air Pro chose the star to insure MultiStar guiding is activated.  Let the guiding settle before deciding to make changes and make only small changes at a time.
There is an excellent write up about fine tuning asiAir Pro guiding here:  https://eastwindastro.blogspot.com/2021/02/how-to-adjust-asiair-guide
scott
Rob Calfee avatar
scott
Sage advice. I second this.
Olaf Fritsche avatar
I recommend the same approach as wsg. with a small correction:
The iOptron Skyguider Pro corrects only in RA, not in DEC. Therefore you have to switch to RA only in the ASIair Pro
Nick Large avatar
Thanks guys for the thorough feedback. That is definitively very useful.
The parameters I used are mostly the ones by default in the ASIair app, like Aggressiveness.
The exposure time I used is what I found in various posts, and youtube videos. I'm still learning about various aspects of auto-guiding. For instance I still have no idea what the aggressiveness is. I'm guessing is somehow related to how frequently or how strongly the corrections are made. Something to learn more about because that seems to be something pretty important.
In my case, since I'm using a Skyguider Pro so I can only guide in RA and not in DEC as @Olaf Fritsche pointed out. But since I'll eventually (hopefully) get a goto mount at some point in time, that's still interesting to know.
I didn't' know about the multistar guiding. How do you do that? I haven't seen anything in the ASIair interface about this. Is is something done automatically? From my sole try It looks like it's just guiding on one star.
Thanks for the link @wsg . I'll definitively have a look.
For instance I still have no idea what the aggressiveness is. I'm guessing is somehow related to how strongly the corrections are made.
Exactly.
Nick Large:
When you go to guiding, just press the cross hair. Then the AISair itself looks for several stars suited for guiding.
Do not select a star by your own. The the ASIair uses only this single star for guiding.
Nick Large avatar
Thanks @Olaf Fritsche. That's very helpful.
I did select a star on my first try. I did know what type of star to select but I wasn't aware of the multi-star functionality.
My bad :-)
Jure avatar
finally registered here after lurking for a while. About time, too!
I'm in the same boat as you are, Nick! I've been gazing at stars since 1977 but only now I have started imaging DSO. Planets were easy through my 250mm Newt compared to what I am experiencing now.
My imaging gear:
Star Adventurer
60mm APO F/6
AsiAir Pro
ZWO 30mm mini guide scope
ASI 120mm Mini guiding camera
Canon 80D
first off, AsiAir Pro is worth it's weight in gold for such a small and mobile setup. IMHO. And beyond, I guess.
Anyway, Nick, I suggest you install this superb utility: "PHD2 Log Viewer" which can be found  here and examine your Guiding log! In the last two imaging sessions I ended up with 4 hours worth of images with elongated stars! After looking at the log it turned out that my aggression is way too low for SA! Which resulted in a "nice" sinusoid R.A. line, oscillating between +5" and -'5".
This is my M31 still with 70-200mm F/2.8 Canon lens - and Default AsiAir Pro settings, before I got "smart". Examining the PHD2 log I can even here see a slight sinusoid which means that SA has quite a severe periodic error.
In general, what I have gathered in the various forums and in my very brief imaging "career":
- play with aggression, increase it if needed, but do not overdo it. When you look at the guiding log the R.A. line should be straight (relatively, of course)
- decrease the interval in which corrections are sent if needed
- in bad seeing increase exposure of your guide camera to around 4 sec or so. AsiAir will take the average value. Or else guiding will be "hunting seeing"
- balance your imaging train so it is slightly pulling to the east and the R.A. gear will be engaged all the time
- if you are not dithering your images (which is otherwise strongly recommended for undersampled images), make sure dithering is OFF in settings
- look at your PA error in the log viewer, that's valuable information, too!
And since I'm a newbie at imaging myself, please feel free to correct me and/or add something I've missed. I could use some advice myself, especially about PA with AsiAir Pro. It's... erratic and I cannot rely on the results for some reason.
Other than that, I'm hopelessly addicted!
Cheers!
Nick Large avatar
Jure:
My imaging gear:
Star Adventurer
60mm APO F/6
AsiAir Pro
Canon 80D
Cheers!
Hi Jure,
Sorry for the late reply. It looks like I missed the notification when you posted.
We have very similar gear, that's nice.
The tips are really useful, thanks. I've been imaging with auto-guiding for about a month now and I think I'm starting to have a descent grasp of it. I'm routinely guide (in RA only) between 0.5 and 0.8".  From what I understand this seems to be pretty good.
I also think I'm balancing my setup much better now. For the PA, I'm using the PA routine in the ASIair app. That's pretty awesome, I can routinely achieve a PA with a total error of 20" or less, and I've definitively seen an improvement on the stars.
Thanks for the link to the Log viewer, that's seems pretty cool. I'll play around with it and see what I can learn from my previous guiding sessions.
I, too, am hopelessly addicted. :-D
CS -- Nick
Respectful Concise Engaging
Jure avatar
Hi Nick,
no worries… smile
You've managed to tame the AsiAir!  0.5 to 0.8 is great! Now my fingers itch, but I am clouded out, weather just won't cooperate! And no clear skies in sight in the near future.
20" PA? I must be doing something wrong… can you please share your routine? I tried with SA drive switched on and off, I put it in the "home" position as accurately as I could but somehow, I cannot get under 1'. Either it is 1' to one side and after a really tiny adjustment, it is 1' or 2' to the other side. I really don't understand it. Something is not right. By the way, my polar scope is calibrated.
In the meantime I got hold of a few minor upgrades for my StarAdventurer over at astrokraken.fr. Declination "setting circles", so it will be easier to position SA at the same spot as on the previous imaging session. I found out that in AAP you can save your object which you are imaging and  it will remember the exact coordinates. So, comes the next night it will guide you to this same spot when you select it. I haven't had the chance to try this yet, but if this works, well, it will be much easier to image the same object on successive nights! Great for us without GoTo! smile
Cheers!
Jure
Jay Stanley avatar
Only way to fly in my neck of the woods. Automation at it's best. Thanks Scott for all the help!!
TRADE: Web/Graphic Design for Astro Gear
It's worth a shot… Is there anyone out there that has superfluous gear and is in need of Web/Graphic design work? I'd be happy to discuss a work trade.
Author seeks design work trade; candidate discusses auto-guiding gear, not relevant.
Mar 12, 2020
ASIair Pro Guiding problems with EQ6-R Pro USB port
Hello,Let's see if someone has experienced the same thing. I have a recently purchased EQ6-R Pro.I want to use the USB port to connect it to the ASIair Pro (my tool for the entire workflow for the past 3 years).Since the ASIair Pro does not detec...
ASIair Pro guiding problems; author recently implemented ASIair Pro auto-guiding setup.
Oct 1, 2023
Hello from Buckinghamshare, UK
Hi all - I started my journey into astrophotography about 9 months ago and have been building my imaging rig ever since. I use a 200/1000 reflector on a heq5 mount and have just recently started auto-guiding from which I'm see great results so fa...
Recently started auto-guiding; seeking advice on technique and results.
Aug 1, 2020
Telescope options for HEQ5 Mount. Suggestions/Advice please!
Hi, My HEQ5 will be here next week. Now I need to decide what scope is best to start with. I have been considering the following scopes. Can you let me know what you think may best best and why? - William Optics ZenithStar 61 @ $500 - William Optics ...
Author starting with HEQ5; candidate uses WO 61 with auto-guiding on similar mount.
Mar 14, 2020
