Artifact in the picture but not in the flat frames.
3 replies104 views
inhuslight avatar
Hi everyone,
While taking pictures, I noticed a strange artifact on the subs. Blue circle with a green border. It was also visible after the meridian flip, but it moved from the position in the image compared to the before the flip.
I noticed that I had a somewhat transparent stain on the filter, but I did not clean it. I suspect that this stain is the cause of this artifact. I was hoping that calibrating with flat frames would remove this artifact, but that didn't happen. No stain is visible on the flat frames. I have not yet had a chance to clean the filter and try again to confirm this assumption.
Has anyone had a similar case or has more knowledge about this? If it's not this stain, then I don't know what the problem would be because I've never had this kind of appearance in pictures before.
Attached is an integrated image and master flat frame.
It looks like your flat was taken with no filter so in that case, it's not going to tell you anything. You didn't say what kind of filter you're talking about but if you have a filter in your imaging train that shows a visible defect, I certainly wouldn't use it.
inhuslight avatar
I just noticed the same thing on a different spot in the picture. Now I have no idea what this could be.
Flats where taken with the filter asswell. It is just a UV/IR cut filter hence I don't specify it anywhere. Its OSC camera.
I had no problem with the filter in the past on other objects.
Dan Brown avatar
Looks to me like lens flare. The blob on the right may be caused by the star Electra.
Dan
BXT Update
Anyone else getting weird star artifacts after BXT update? I am not sure if its the update or problems with the data I downloaded from telescope.net
Troubleshoots artifact appearance in astronomical images and flat frame analysis.
Jul 27, 2023
Odd "circle" in imagery when taking photos
Hi all, Starting with: This is a 12” newtonian (1200mm), with a Poseidon-M connected to 50mm (round) filters and an OAG-MAX (with a coma corrector) - 56mm back focus So I’ve been banging my head against a wall trying to figure out what this is… I fir...
Circle artifact in imagery; filter stain causing optical obstruction similar to yours.
26 days ago
Problem with Flat Frames
Hi all, I haven't really been happy with an image I took of LBN 1093 back in May. I did do an initial edit which turned out ok, but I would like to re-edit this data with new techniques I have learnt over the past couple of months. Whenever I try...
Author troubleshooting stacking artifacts; similar image processing problem-solving.
Jul 21, 2023
FLAT with a strange pattern, I can't properly correct the LIGHTS / SkyWatcher APO ESPRIT 120 / x0.77 Reducer SkayWatcher / QHYY 268 mono / Chroma 3nm SII 36mm and OIII
Hello, I have a problem I can't seem to solve. If anyone can shed some light on it, I'd appreciate it. I'm testing a new setup: SkyWatcher APO ESPRIT 120 / x0.77 Reducer SkyWatcher / QHY 268 mono / Chroma Ha 5nm 36mm / Chroma SII 3nm 36mm / Chroma OI...
Flat frame calibration issues; artifact correction problems with optical setup.
20 days ago
Problems generating my flats
Hi! Does anyone know why my flats shots have two circles in the center of the image? My equipment is a WO RedCat v3, and in the optical train I have a ZWO filter drawer, a filter wheel, and my ASI 294mm Pro camera. I have the filter drawer because I ...
Circular artifacts in images; flat frame generation troubleshooting relevant to your issue.
Aug 5, 2025
