Siril can't register my images?
5 replies271 views
SternwarteOrion2023 avatar
Hi!
I've some troubles with Siril. I photographed the Embryo neblula (NGC 1333) without guiding, so my sub exposures are only 15s long. If I try to register the images, Siril only registers half of the images. I don't understand, why Siril can't align the stars in the images:
Why is this image registered but
this image isn't?
The console only says "Cannot align the stars".
I use the 2 or 3 star alignment method, because every other method worked even worse. I use the bright star in the middle of the image and the bright star in the upper right corner.
Kind regards,
Sternwarte Orion
Quarkus avatar
Go to dynamic PSF. Click Star Detection. By changing the threshold and roundness threshold, all stars should be selected. Then do a global star alignment
Götz Golla avatar
I think you will get the best answer when you post your question directly in the Siril forum. The Siril developers usually react quickly and have excellent answers.
https://discuss.pixls.us/c/software/siril/34
Goetz
Well written Concise
TJ Bagchi avatar
Hi, from the images that you have posted, looks like very few stars. That may be the reason Suril is not able to align. If you are familiar with Deepskystacker, increase both star detection threshold and FITS brightness threshold and see if you get any better results. If not, you may have to increase exposure.
TJ
paddy36 avatar
Hi Sternwarte Orion ,
The signal to noise ratio is too low, so increase the time of acquisition for having more stars and signal as well..!
Paddy36
I shoot at 15 sec. all the time and have never had this problem but I do see it if I go much shorter, that's with a dual band filter. The best solution is to increase the star detection threshold as quark-coder suggested.
Problem with Star Aligbnment in PixInsight
I have 54 four- minute subs of M81 that I am trying to align, taken at a focal length of 1422mm. Many of the subs are failing to register. Which parameters in StarAlignment are most likely to help me align the maximum number of subs? And should I try...
Registration issues with short exposures; discusses alignment problems similar to yours.
Mar 17, 2023
Salute from Appenzellerland
Hi there. I just registered and send my greetings to you. I do visual observing of the skies because it keeps me wondering. Since I enjoy looking at some impressive photographs of yours, I plan to capture some objects with my phone and my panasonic-c...
Relevant - author plans to capture sky objects and may encounter image registration issues.
Jan 15, 2023
