Hi Martin,
thanks for the feedback!
Martin Junius:
- Everything is overly large, especially the category icons and the image details sidebar compared to the image itself, also fonts in general
Hmm I don't think so, and I haven't heard this one. Consider that the image viewer has been part of the search results for several months now for everybody except a few dozen people who opted out of the new search page. Can you send me a screenshot?
Martin Junius:
- Category icons don't show an image from the category?
I don't understand this one. Category icons?
Martin Junius:
- A "Delete" function in the ... menu of the image icons is a bit dangerous, don't you think?
You get a confirmation dialog after you click it, so it's fine. It's the same as on the image page. Click on the menu, click on Delete, click Delete again in the confirmation dialog. I get asked every week how to delete images, some people can't find it as it's now.
Martin Junius:
- The image details sidebar sort of overwhelms the image, especially landscape images
Can you send me a screenshot accompanied by the link to that image? I wonder if you have a particularly large or particularly small screen that I didn't test.
Martin Junius:
- Sidebar: some information is in dark gray, almost unreadable, why?
Which one specifically? Thanks!
Martin Junius:
- Sidebar: (i) doen't link to the IOTD stats as in the old gallery, but only to the generic IOTD info page
If you refer to the image's IOTD/TP stats, they're in the View menu.
Martin Junius:
- Sidebar: "Integration" and "Equipment" occupy far too much screen real estate, should be folded per default
Sorry but I totally disagree, and I think most people will also disagree. They both are the most important piece of information people on AstroBin want to see!
Martin Junius:
- Sidebar: "Description" should be above "Integration", and is now too narrow for more extensive information e.g. inline images
I disagree here too. Usually, the integration is more compact, and the description could be longer. First the data that one can see at a glance, then the long (or short) text that the user provided. Can you send me a screenshot of where it looks narrow to you? Thanks!
Martin Junius:
- Sidebar: "Image in the same area" yields strange result, i.e. a lot of astrolandscape accompanying my deep sky image
That's because it's based on RA/Dec, so landscape images will match a lot of RA/Dec ranges due to the FOV. I will make it so it only shows images with a similar FOV, thanks!
Martin Junius:
- Image detail: sky map and histogram require clicking the icons only visible when hovering on the left, image side
Yes, but I can't put everything on the page at the same time and not have it look like an angry fruit salad. If they're not behind a button, then they'll have to be below the fold and require scrolling an unknown amount depending on the length of the other data. At least this way they are in a predictable place.
Martin Junius:
- Adjustments doesn't work with Firefox, returns to the overview
I fixed that today, please try again!
Martin Junius:
- Smart folders and Equipment work in a somewhat strange way, I'd have expected a "filtered" gallery / category like view, not a sidebar opening with a list of images
Yeah, unfortunately this is not easy to do right in my opinion. If it's not a sidebar, and the images appear below the tags, that could be so low that users don't realize that they have to scroll. If the tabs appear on the side, then there will be a lot of wrapping text and this solution wouldn't work on mobile anyway.
Martin Junius:
Don't want to be rude, but right now I prefer the old version.
It's why I made it optional. I knew that it could not please everyone, tho so far I've received mostly very positive feedback! If you have time, please address my questions above so I can make improvements.
