Starizona SCT Corrector IV - 0.63X Reducer / Coma Corrector (Backspace requierments)?
12 replies351 views
Ed Litoborski avatar
SO I have an older C8 and I was encouraged to invest in the Starizonia .63 reducer.   Info I found was to establish a back space of 90.3 mm "but at 90.3", the telescope does not focaus clearly.  The ASIair can't establish the scopes focal length..
(I doubel checked Collimation with a tri-bahtinov mask)  I am using a ASI2600 MC camera.
Question for those who have this Scope, Starizonia reducer and the 2600 camera, what back spacing are you using?
Or do you have any other suggestions to check?
Thanks in advance.
Craig Harding avatar
90.3mm. The SCT corrector comes with a 35.3mm adapter. So, just configure your camera as if you are doing 55mm backfocus and then add the 35.3mm adapter before attaching it to your reducer.
Bill Griswold avatar
I have a similar setup with a QHY. I believe 90mm was very close but used an adjustable spacer to get it nailed. Will doublecheck later.
BTw, that reducer on the C8 is actually right around 0.71x. Don't have an ASIAir but if you had to enter the reducer…it may be off.
Bill
Frederic RICHARD avatar
Je l'utilise sur un vieux C8 (voir mes photos), je l'utilise avec une caméra Atik + roue à filtre et j'ai rajouté un jeu de bague allongé pour atteindre un BF de 90mm en tout, si tu veux plus de détail, n'hésites pas..
Mike H - Sky View Observatory avatar
I have and use an 1981 orange tube C8. The Arizona reducer would not let the camera come to focus or it was right against the stop. Forget autofocus. I went with the stock Celestron reducer. Although most on AB despise them, I’ve had good success. Stars are round almost to the edge of the field of a 294MC Pro. Autofocus works with NINA.
Mike
that's precisely how its set up now
Lynn K avatar
Age of Celestron C8 shouldn't matter.  As far as I know all have F2 primaries with secondaries that magnify x5 to get F10. All have 200mm corrector rendering 2000mm FL.  The focus distance distance movement on the baffle tube may vary.
To state the obvious,  the 90.3 is from rear of reducer to chip. Did you subtract the backfocus of camera, filterwheel, etc.?
Lynn K.
The age of the C8 does matter. That’s why I stated the the type and age. I tried everything including seeking advice from Starizona,  Celestron, CN and AB. Apparently it doesn’t have the travel of a more recent unit. Are you thinking I didn’t want it to work? I bought the unit and spent a lot more trying to get it work before I finally sold it to someone who had a newer unit and it worked for him. Please don’t say “it shouldn’t matter” unless you know for a fact. I had the physical pieces and I’m not green. It didn’t work, period.
Mike
Lynn K:
Lynn K.
yes
Herbert W Hamber avatar
90.3mm as stated in the instructions,
https://www.youtube.com/watch?v=FReYgPUMAfs
Exactly how I have mine set up, (as I wrote in my post)  hence the reason I reached out for advice
randcpoll avatar
You will have to manually enter the telescope focal length in ASIair. (1260mm)
the SCT corrector on a C8 is 1440mm focal length. Oddly, the same unit in a 9.25 is 1525mm focal length.
Advice on Coma Corrector and reducer
Hey I have a Skywatcher 200DPS f/5 8” newtonian and are looking to add a Coma corrector to my setup. I have the default focuser that came with the Telescope and currently imaging with an EOS 50D - which will soon be replaced with an ASI2600. Any sugg...
Relevant — discusses reducer/coma corrector backspace requirements for imaging
May 7, 2023
Collimation RH200
Hello. What technique and what tools do you use to calibrate the RH200? Has anyone ever used the SCT Collimation using HOTECH Advanced CT Laser Collimator?
Discusses SCT collimation tools and techniques relevant to RH200 calibration questions.
Jul 24, 2023
OOUK ODK10 mirror spacing & corrector placement
Hello, I acquired an ODK10 from an German Observatory for a very good price and received it today. It’s used and has seen better days, but I want to see if I can make it work. Mechanically it looks OK and the Observatory fixed the weird unstable cork...
Discusses mirror spacing and corrector placement issues similar to reducer backspacing problems.
Dec 23, 2025
Optimising an SCT for APS-C DSO Imaging - Bright Star Reflections
I would very much like to optimise my trusty old C8 SCT for Deep Sky Imaging. I appreciate that I am never going to match the perfromance of an APO Triplet but that's no reason not to aim for it. It's a great all rounder and I have the benefi...
Starizona reducer/coma corrector directly relevant for C8 SCT optimization and deep sky imaging.
Feb 12, 2023
