Matan Buzaglo avatar
Hey everyone, after several attempts to figure out why I keep getting star trails and what's wrong with my alignment, I’ve decided to ask for help here. I’m trying to polar align my EQM-35 mount using ASIAIR. First, I manually aligned it using the polar scope, placing Polaris exactly where the polar clock indicated. After that, I checked the polar alignment with ASIAIR, and the RA/DEC error showed:RA: 00:30:00DEC: 00:05:00 I have no idea how this happened. Anyway, I tried using ASIAIR for polar alignment. When I moved the mount left or right, the up/down axis would also change—and vice versa. Eventually, I managed to complete the polar alignment, with ASIAIR showing:RA: 00:00:05DEC: 00:00:10 But when I slewed the mount back to the home position and checked the polar alignment again, the error values had changed to:RA: 00:30:00DEC: 00:10:00 Next, I slewed to a target and started guiding using my guide scope. After calibration, the guiding started, but I noticed the following: RA: Initially climbed to 10° and then stabilized between 1.0 and 1.3.DEC: Climbed to 50–60°, then stabilized around 1.8. Sometimes, the DEC would suddenly drop to 10–30° for a few seconds before returning to normal.I’m confused about what might be causing these alignment and guiding issues. Any advice would be greatly appreciated
That is my rig
Eric Gagne avatar
It sounds like incorrect settings.  Did you make sure the coordinated and date/time are correct in the device that runs the app and synced with the mount ?
I wouldn't bother with a visual alignment first, there's no advantage in it. Just point your mount north and roughly adjust for latitude. software will do the rest. On the numbers changing, that's going to happen with a light setup like this. You should certainly look for anything obvious, something loose or soft or shifting ground. Other than that, get close with the AIR and start shooting. It's generally better to see a problem in the images and correct it as apposed to looking for problems that might not matter in the long run.
Tom Boyd avatar
One other thought on the numbers changing. I assume you are leveling your tripod? If level is not perfect, error in dec and azimuth will not be independent.
Eric Gagne:
Yes
Tom Boyd:
Yes i level the tripod, with north, pa manually with polar scope and then complete the pa in asiair
TiffsAndAstro avatar
Matan Buzaglo:
Tom Boyd:
I tried using polar scope of my sw GTi twice it was not fun. Then I got Nina and could use it's 3 point polar alignment for easy accurate results and never used polar scope since.
As others have said, use the polar alignment to routine in your asiair
Bob de Bruin avatar
Hi Matan,
I have owned the same mount and also experienced a lot of difficulties. I suspect your problem has nothing to do with the polar alignment but just the ability of the mount to properly track at all. My copy of the mount was not able to do a goto because it just skipped and ended up somewhere random. What did help a little bit was a power supply with 14V instead of the 12V (and yes there is a risk in doing so)
The mount was also impossible to balance well because there was way too much friction to do so. After disassemble and re greasing this was partially solved.
In the end I exchanged the mount because it never was 100% reliable.
Good luck with problem solving and start with the basis as I sail I don't think polar alignment is your issue.
my 2cts, Bob
TiffsAndAstro:
Matan Buzaglo:
Tom Boyd:
Can i connect nina to asiair? Because all my rog connected to asiair
No, you have to use one or the other. Of the two, NINA is more capable.
What i need to do to connect nina to the equipment?
Once you have all your needed ASCOM drivers,  Green Swamp server or EQMOD for the mount and PHD2 installed you should be able to load everything up in NINA. Of course you won't be able to do this through the ASIAIR, you'll need a separate PC to replace it. It might seem like a lot of work compared to the AIR but you'll have more control and flexibility in the long run.
Well Written Concise
Oh ok thank you!
Matan Buzaglo:
TiffsAndAstro:
Matan Buzaglo:
Tom Boyd:
Your asiair will have its own feature to polar align.
Maybe watch a YouTube video there are bound to be lots. It's pretty simple and quick once you know what to do.
Mount axes swapped?
Hi, I am trying to get started with this mount and I am getting more and more the impression that my axes are swapped, meaning that DEC changes actually cause RA changes and vice versa. This happens during three point alignment, where the RA axis sho...
Mount axes swapped could explain RA/DEC errors during polar alignment checks.
Aug 28, 2025
Platesolving Issue after All-Sky PA with ASIAIR
Hi there! New ASIAIR Mini user here - purchased for imaging from a spot in my yard with no view of Polaris. The all-sky align has been working OK, but I've run into an issue trying to establish the mount's position post-alignment, so that I c...
Polar alignment issues with ASIAIR; author also uses all-sky align method.
Feb 15, 2023
CEM40EC Handset: "Unknown Position" - What does it mean?
I may be a little paranoid after suffering a tripod collision due to a known (but not to me) software compatibility issue between the ASIAIR and the CEM40 series of mounts. But I just noticed that as soon as I begin to slew after setting the mount ze...
ASIAIR compatibility issues may relate to alignment error detection problems.
Jan 28, 2026
ZWO AM5, ASI AIR Plus: Polar Alignment
Just a question: when I'm doing the polar alignment with the AM5 using the ASI AIR plus, using the All Sky procedure, I noted that the AM5 is not tracking. I was thinking that after the third picture and after plate solved the mount should track?...
Directly addresses polar alignment problems with ASI AIR and tracking issues.
Jan 19, 2023
iOptron GEM28 controlled with ASIAir Pro failed Plan
Hi Everyone, I had a strange issue last night with my setup that I have not experienced before: I had polar aligned early in the evening and since the weather was cloudy until later in the night (and my target was obscured for the first hours), I pro...
Addresses polar alignment issues and ASIAir problems relevant to your setup troubleshooting.
Feb 22, 2023
