High Current 2.1 dc power cables
5 replies221 views
RICHARD BREKNE avatar
I am looking to run virtually my whole set up through a Pegasus Power box using a Albrect SW102 power supply.  The power supply has banana plug outs so I need a cable with banana plugs on one end and a 2.1 dc connector on the other… AND it needs to have a 10 amp rating so I dont risk any problems.  Perhaps over kill with 10 amps but just so.  I'm finding it rather difficult to find cables with any ampere rating and difficult to find banana to 2.1 DC.
These kind of power supply boxes are sold on many astro equipment supply stores.. but cables are sadly lacking…  Anyone know of a resource for such things. I am located in Bergen Norway
Rostokko avatar
You may not find amp rating, but you typically do find the AWG (gauge) of a cable; for 10 amps you want a 16 AWG cable (which is not big at all). Anything smaller than that (yes, AWG moves the opposite direction of amps) is way overkill.
Concise
Bill McLaughlin avatar
That is pretty specific. I suspect you would be better off making your own with plugs and silicone wire (especially the latter in Norway due to temps).
D. Jung avatar
The main problem is voltage drop if you use longer cables. If you can keep the cable length short (<1m) you can probably get away with the standard cheapo cables.
I've been using something like this for several years without issues to distribute the power on my scope. It carries 2 cameras, filter wheel, 2 heaters, Auto focuser and a mini PC. Power supply is off the shelve 12v 10A. Total cost for power supply and cable <40€.
Habib Sekha avatar
RICHARD BREKNE:
I am looking to run virtually my whole set up through a Pegasus Power box using a Albrect SW102 power supply.  The power supply has banana plug outs so I need a cable with banana plugs on one end and a 2.1 dc connector on the other... AND it needs to have a 10 amp rating so I dont risk any problems.  Perhaps over kill with 10 amps but just so.  I'm finding it rather difficult to find cables with any ampere rating and difficult to find banana to 2.1 DC.
These kind of power supply boxes are sold on many astro equipment supply stores.. but cables are sadly lacking...  Anyone know of a resource for such things. I am located in Bergen Norway
Teleskop service in Germany sells them. I have it for 13.8V  10-12 Amp supply. Edit: mine is also an Albrecht.
https://www.teleskop-express.de/de/montierungen-stative-schellen-schienen-stromversorgung-14/stromversorgung-81/ts-anschlusskabel-12-v-mit-5-5-2-1-mm-hohlstecker-3-m-laenge-17563
Hei @Habib Sekha .  Thanks for the link !  I see that the ampere rating is not included, but I suppose given they sell with the same power supply it will be strong enough.  I wrote TS and asked if they could check it for me.
Power cable for astro-cameras
Hi, I bought my first dedicated astronomy camera (ZWO ASI533MC Pro) one month ago and I did two imaging sessions since then. I don't use the original ZWO power supply, but I use one from Amazon, which has a cable with an angled connector. I find ...
Author seeking power cable solutions for astronomy camera setup.
Aug 3, 2023
Camera failing to download
So I'm loving the 2600mc pro and I think my last couple of images came out really nice (Orion and Pleiades please to have a look and any comments/feedback would be much appreciated.) However, I've had issues with my camera sporadically failin...
Discusses Pegasus Power Box power supply setup, directly relevant to author's power issues.
Jan 8, 2023
"Smart Buck" Custom Power-Tool Battery Powered 12V Supply for AP Equipment
After I purchased a ZWO ASI183MC back in January of this year, I ended up going down a DIY rabbit hole which ended up producing what I consider a potentially useful gadget. I only own one 12V 5A rated wall power supply which I use to power my iOptron...
Discusses high-current DC power delivery, directly applicable to powering astronomy equipment.
May 15, 2023
Power Station for occasional use
Hello all, I know this topic comes up a lot, but i’m trying to consolidate my research with a few opinions of those who might be in the same boat as me. My normal set up at the moment is a SA GTi mount, with a REDCAT 51, ASI533MC Pro, filter wheel, E...
Power Station for occasional use — discusses power supply consolidation and opinions.
Aug 31, 2025
