Aastro123 avatar
Hey everyone! here are some minicat 51 images, raw only with STF and aberration inspector. I included stacked image, before and after blurxterminator.  The goal of this post is so those considering buying the minicat 51 can see what to expect regarding star quality in the corner. Not as much of a review of blurxterminator... I think we all know how powerful that is.
Minicat 51
ASI2600mc air
Star Adventurer GTI
Bortle 5/6 backyard
Images are drizzled 2x for more round stars
Below is a single 60s frame only with STF
below is the stacked, 8hr worth of 60s exposures. Only with STF applied
Below is the single 60s frame, inspecting corners
Below is the stacked 8hr image, inspecting corners
Here is the 8hr stack with blurxterminator and STF.
And finally the corners after applying blurxterminator
I understand theres some controversy regarding this scope. I bought it because I wanted to test the quality and have a portable setup with wide FOV
Should we expect more given the price and the name brand William Optics?
If we use blurxterminator in our workflow, does it really matter?
Curious what you all think!
Final image I processed on my profile : )
Photon_Collector avatar
Nice test!
I would expect better stars in the corners on an APC sensor like that…
Nice test!
I would expect better stars in the corners on an APC sensor like that...
Agreed. Pretty poor correction and it shows even after BXT. I'd never ever ever buy anything so poor, given the price.
Charles avatar
What is the purpose of the minicat 51 versus the regular cat 51?
Courtney Cameron avatar
If the mini was at least $250 cheaper, maybe it would be worth it. The corners are not good, especially when the RedCat 51 is the same price.
Luka Poropat avatar
Even a Rokinon 135mm below F3 has better performance than this on APSC.
Shame for this trend, creating a mediocre telescope and justifying it by telling people "software" will fix it  "don't be a pixel peeper".
TiffsAndAstro avatar
Minicat 51
ASI2600mc air
Star Adventurer GTI
Bortle 5/6 backyard
Bigger stars seem to resemble packman?
Like a little cutout on each, in same position?
Other than that looks good to me.
Karl Theberge avatar
I find wiliam optic generate a lot of bloating stars and to have some of the worst flattener/reducer ever.
I feel a lot of new comers got the "Wiliam Optic hype" from Astrobackyard.  There is no way those scope would be as popular otherwise.
Maybe at some point in time their product were better. Since a few years tho, all review I see from their scope offer the same average result.
Dan H. M. avatar
Minicat 51
ASI2600mc air
Star Adventurer GTI
Bortle 5/6 backyard
Yea, you should expect far more from this scope and named brand, it’s dire TBH, you may as well but a cheap 50mm Ed scope like the skywatcher evoguide and just use BlurX, it will give pretty much the same results, what is the point of spending loads on good or in this case poor optics only to have to use BlurX, just buy cheap to start with and use BlurX…🤷🏼‍♂️
It’s a shame but this BlurX was and is a game changer, and not exactly good for some up market scope manufactures, so Williams optics have realised this and just put out a poor optics scope and selling it at a premium price and tell you to use BlurX in the marketing material, so even they realise there is no point any more for companies to fork out a fortune on quality optics, just put a poor cell in a trusted and well known red tube. Other manufactures will follow now ☹️
In what universe is $900 a premium price?
Dan:
For a finder-sized scope? In mine for sure.
Dan H. M. avatar
Dan H. M.:
Minicat 51
ASI2600mc air
Star Adventurer GTI
Bortle 5/6 backyard
For a 50mm scope with such poor optics, it’s deffo a premium price, and I’m glad that you had enough money that $900 to you is not a problem me you can afford to waste on such a poor performing scope, but personally, £900 to me would be premium.. 🤷🏼‍♂️
I didn’t buy it, and I likely won’t.  Just pointing out that $900 is not premium in this hobby, like it or not.
Rick Krejci avatar
I believe  your single frame/corner and 8 hr stacked/corner images are identical…same noise pattern.
Rob Lyons avatar
I use mine with a full frame 6200MC Pro. I’m happy. https://www.astrobin.com/2ybx5d/
Well, actually that image shows the fingerprints of BXT all over the place…
Gert Eriksen avatar
Please note that WO actual point out at their website, that there are problems with the stars at the corners, if using a APS-C sized sensor and they recommend to use BXT to correct it:
Due to the nature of MiniCat’s fast aperture optical design, edge stars may not be as round as with other RedCats. However, our tests show it still outperforms conventional lenses. With aberration correction software like BXT, peripheral distortions can be perfectly corrected on APS-C sensors, while Full Frame may need some fine-tuning for even better results." Link
Rob Lyons avatar
Rob Lyons:
Well if that image is with full frame and with no BlurX used, which it does not look like it has had, then it’s excellent, and such a massive difference to the OP’s scope and the optics are 1000% better, so how can they make such varying examples of the same scope it’s ridiculous…if I was the OP I would be sending it back and getting another version
I used BlurX. If you look st the description it has before and after aberration inspections. It’s not a perfect scope, but it gets the job done.
Aastro123 avatar
Rick Krejci:
I believe  your single frame/corner and 8 hr stacked/corner images are identical...same noise pattern.
You may be correct... it looks identical. My mistake
Aastro123 avatar
Hey everyone! OP here! I wanted to emphasize a point that I shouldve made clear in my original post. I was curious to try it out! I originally bought this because I enjoyed my redcat 51, but I wanted something more widefield and maybe a touch faster. This scope on paper seems to fit that want.
With my experience using the redcat 51, my stars were never perfect with multiple cameras. the corners always presented with some degree of coma. I used a rokinon 135 prior to the recat. I also own a askar fma 230.
I do enjoy using the minicat 51, but it certainly does not perform as well as it should. those stars are not at all what I would expect from WO. I was very much aware of the warning on their website regarding the need for BXT in post. I personally dont think this is acceptable. If you NEED BXT in post, then your scope isnt that great.
I will say I have never owned a "perfect scope", but have owned many. I have had a 8in newt, have a 10in newt. both of which struggle to have "perfect flat fields", despite multiple CCs, laser calibration, Cheshire eye pieces etc. I owned an Askar 130 phq, which had great corners with native FL, but poor performance with the reducer. This scope also suffered from "pacman star distortion", even after I sent the first scope back to Askar for recollimation.
My point is Ive never owned a perfect scope thats has 100% flat field, is fast, with an interesting FL. Maybe one day Ill take out a mortgage on a Planewave LOL.
Im going to keep working with the minicat for some time, I think I can do some cool stuff in the future, weather permitting, with my current setup.
Im happy I got to display my findings for others, so they can make the decision on purchasing this scope. That was another key point of my post.
Andy
Charles Barker avatar
Thanks Andy for taking the time to experiment and more importantly share, the good and bad. This kind of post is great for those of us who are just starting out in this hobby and looking to start building their first rigs!
Minicat 51
ASI2600mc air
Star Adventurer GTI
Bortle 5/6 backyard
I'm afraid this is a very good point. AI software is advancing quickly, I fully expect for the ability to correct all sorts of optical aberrations to be available in the near future, BlurX is just the beginning. I would expect that the market will respond with lower quality at the same price or crow about perfect stars and push pricing even higher because there will always be people who want the perceived best at any price. All in all I think this is fine because powerful software allows everyone to dig deeper into the data and show amazing things. In the end what matters is the final image on the screen or wall. Marketers will continue to work their money grubbing ways one way or an other. As always it's buyer beware.
Ancient.Photon avatar
Well the minicat 51 has 2x super ED glass element so it has a premium glass but i feel they somewhere down the design of it pushed it too far at 3.5 focal ratio and defending it with BlurX was definitely a poor move to justify it. The askar SQA55 also has one SD glass and it looks like the sharpest even at full frame. Hope they soon release a revision version II of this minicat (maybe at f4 the stars at sharper)
Alex Nicholas avatar
I would personally not spend that sort of money on a scope that won't even accepably cover APS-C sensors without AI intervention.
I look at the raw images from the Askar SQA-55, the Redcat 51, the SV555 etc, they are all far better, and around the same or lower price.
Then look at the FRA300, better again.
Look at the 65PHQ - even better again.
Both at the same price point.
There are hundreds of instances of scopes that are cheaper that will produce better or equally as good images for less… Even a Nikon 180mm f/2.8 lens or the Nikon 105mm f/1.8 lens. Canon 135 F/2L or Samyang/Rokinon 135/2…
They should never have released a telescope that needed a disclaimer on their website to state that it would not produce a corrected image, and that you would need to fix the images with AI tools.
Despite the fact that blurxterminator will correct the images (mostly), BlurXterminators purpose is not 'correcting crappy optics' its performing iteratively converged deconvolution in order to yield the most sharpness out of your data without introducing deconvolution artifacts like dark rings around stars… Yes, it will tidy up sloppy PSF's and eccentric stars from poor optics, poor focus or tracking errors - but it works best on GOOD data.
Its the old 'You get out what you put in' idiom…
If you dump garbage data in, the result will be slightly sharper garbage.
Helpful Insightful
Rick Krejci avatar
It has been a trend in the terrestrial camera world to make uncorrected and even heavily vignetted optics and correct the images in-camera.  I’m afraid this trend will continue.
I think the important thing is that manufacturers be transparent about the performance of the systems they make. As far as I know, Redcat in this case has been. No optical design is perfect but as long as you know what the performance is, you can make your mind up based on that data and your requirements. In general, I'd look for a set of spot diagrams for the full field of the system. If that isn't available then I would really think twice about purchasing the system. Or at least make sure that I can return it for a full refund if it's found wanting.
Well Written Concise
Enol Matilla avatar
Now in 2026, is there any sub F4 telescope similar to the minicat for about the same or less price? No camera lenses with adapters and custom brackets.
I’m searching for a fast scope for a complete automatic rig with less than 250mm of focal lenght and sub F4 if is possible.
The SQA55 has mechanical problems with the native brackets and thread inserts, also helical focuser, the minicat51 problems with stars quality, the sv555 and sv545 have helical focussers but seems to be the best compromise between all, etc. No scope seems to ve perfect.
Greetings.
Askar 130 PHQ
Hey everyone! I just got an Askar 130PHQ and have limited testing with it due to poor weather What does everyone think about this new telescope? From what Ive been able to tell its pretty darn good Images below
Author sharing telescope images; raw image processing examples directly applicable.
Jan 5, 2023
Canon EF 300mm f/4 L astrophotography comparison: non-IS vs IS version
Hello all, I am excited to share this test report I wanted to make ever since I acquired both lenses, in an effort to help the community. I will also attach it to the thread for easy download. Enjoy your read and I hope this comparison helps you make...
Relevant comparison of optical equipment performance for astrophotography quality assessment.
Feb 3, 2026
To Cull or not to Cull (for seeing; FWHM)
I was in Florida where we typically have good seeing, and I would cull a over about FWHM = 2, with much of my shots < 1.5. Now in NC seeing sucks (this is a technical acronym for Sky Undergoing Continual Kinetics Sometimes). I’ve been building tim...
Relevant discussion of image quality metrics (FWHM) and star quality evaluation.
Oct 23, 2025
Sky Rover 50 SAW review
I have been searching for a telescope with the shortest focal length, the largest aperture possible, and which would work with a full-frame sensor. My first one was RedCat51, which was quite OK, but I wanted something shorter. I found Askar ACL200, w...
Relevant telescope review discussing optical performance with full-frame sensors.
Feb 10, 2026
