Is a top level barlow lens worth the price difference?
10 replies260 views
Single choice poll 18 votes
89% (16 votes)
11% (2 votes)
Olaf Fritsche avatar
Dear Stargazer,
Finally my Celestron EdgeHD 925 has arrived and I am experimenting with Jupiter and Saturn. My camera is a ZWO ASI462MC. I did the first tests with and without 0.7x reducer. The results are mediocre. There is still a lot to learn.
I also took pictures with a cheap 2x Barlow lens for visual observation. The images were larger, but did not show more details. Maybe that was due to the seeing.
My question: Is an expensive Barlow lens worth it if the seeing is good? After all, the price difference is almost a factor of 10. I am willing to spend the money later if it increases the quality of the images.
What are your experiences?
Thanks for tips and opinions!
Olaf
Dale Penkala avatar
Olaf Fritsche:
Dear Stargazer,
Olaf
Hello Olaf,
There are a lot of threads on this very subject over on CN (Cloudy Nights) but IMHO I wouldn’t use “cheap” barlow on the images we take with our equipment that costs $1000s. It then becomes the “weak” link in our setup. Over the years I’ve done alot of visual (and still do) and still endup going back to my TV barlows. 2x & 3x. These are the “standard” models not the Powermates that many like to use.
Now I do have a GSO 2” 2x ED barlow that is very good on the moon and in fact I use that for shooting lunar images when I can’t get to my TV 3x because of seeing. Even though its an ED barlow on colored images I get a slight color tinge around bright stars etc.. which I’d have to say would be CA so shooting in BW or on the lunar surface I don’t see any problems. BTW the only reason I had the GSO ED barlow is I got it in a package years ago before I got into more serious imaging and found it to work ok.
Bottom line at least in my eye’s I wouldn’t cheap out on a lesser barlow then a good Tele Vue or AP barlow.
Dale
dkamen avatar
Hi Olaf,
Yes it's worth it because a Barlow like every other glass introduces aberrations and you want those kept to a minimum. So you don't want cheap glass. Particularly for high res planetary.
I have a very cheap Celestron Barlow and it actively worsens the result, it is simply useless even for visual observation of the moon on a night with excellent seeing, even for birdwatching. You are better off doing 2x drizzle or even 2x simple interpolation if you want the extra magnification.
I must note that with the 925HD seeing will be the limiting factor anyway and you probably need excellent conditions and very lucky imaging to get a good result even on native FL. Don't go Barlowing up unless you have mastered your native FL and are sure that is your limiting factor.
Dimitris
Ruediger avatar
Hi Olaf,
I use the Baader “Fluoride Flatfield Converter FFC”, which is expensive, but worth any cent. I can adjust any magnification and has a great resolution.
Rüdiger
It depends on what cheap is supposed to mean. Some are inexpensive but still deliver the goods (some older Celestron and Meade 2x barlows come to my mind). Very fast scopes require, OTOH, optically accurate barlows to provided on-axis and off-axis performance (e.g. no degradation due to spherical chromatic aberration and no coma at wider angles). Unfortunately there is no way to know for sure (unless is a matched amplifier from the same manufacturer of good standing, e.g. Takahashi). Some very expensive barlows have been found wanting when put to the stress test. Buyers beware…
Stjepan Prugovečki avatar
The quality always comes with a price tag (vice versa not always the case though).  As mentioned above,  there is no medicine against bad seeing . Extremely short exposure maybe helps , but Barlow just makes it slower…
One thing to have on mind , Barlow does exactly opposite to focal reducer , so using them together is not the most optimal.
Master your imaging on a native FL (without focal reducer) , and judge how often would your seeing conditions be as a such that Barlow would make sense. If you go for Barlow, get yourself a high quality one .(not to mention well known brands here)
Concise
Ruediger avatar
Stjepan Prugovečki:
To overcome seeing restrictions you can use a barlow and lucky imaging techniques. So seeing is not the limiting constraint for a barlow application. There are situations you breach the limits on purpose. E.g. I work sometimes at a EFL of 8m which is far beyond any seeing would allow.
I totally agree to the argument for long DSO exposures.
So seeing is not the (only) criteria, it is more the use case.
Rüdiger
Ruediger:
Rüdiger
Well , lucky imaging has some limitations . You can shorten the exposure time , but it ends at the point where you do not have enough light or your communication with PC can't handle the frame rate. With Barlow your exposure time goes up, so your chance to win the seeing by faster recording decreases.  What I want to say is that if your lucky imaging results without Barlow are not  good, Barlow will not make it better
Thank you all! Your answers have helped me a lot.
As you advised, I will first practice the technique without Barlow lens until I am comfortable with the equipment. (I had only used the reducer in the beginning because it made it easier to find the planets).
As soon as I have the optics under control, I will check whether the seeing at my observation point already sets limits to the resolution.
If there are enough nights with good seeing, I will get a good Barlow lens from one of the well-known companies.
For the planetary photos I always use lucky imaging. There I can also learn a lot by adjusting the parameters. Deep Sky I do anyway with another camera and without Barlow lens. Depending on the object I use the reducer or even my refractor.
Thanks again to all!
Clear skies!
Ruediger:
Hi Olaf,
Rüdiger
Wow! That's really a prize!
The reviews are gushing about it. Let's see if my budget is that big, if a Barlow lens is worth it for me.
Ruediger avatar
Olaf Fritsche:
Ruediger:
Hi Olaf,
Rüdiger
Hi Olaf,
I know! It is really expensive - like almost everything in our hobby. But here it is like always: You get what you pay for. Good calculated and crafted optics is expensive.
If you only go for planets (small center of FOV) then probably there are cheaper and also (very) good solutions. But if you want a Moon surface over complete FOV it is paying off. Also you do not need to buy multiple Barlows. You can scale the FFC as you need it without optical losses. Just add distance tubes.
I also never heart any complaint or negative feedback about the FFC.
Rüdiger
Concise
