Mount stops responding after a certain time.
5 replies210 views
Haakon Rasmussen avatar
Hallo!
After buying a used UMI17 mount, and initially i had some fun with it, i now experience only  problem with getting it to work properly.  The problems are always the same. At starts it works normally, then after a time the mount stops responding to commands from NINA (3.1HF), or getting the PHD2 error:" Ascom driver failed checking ispulseguide". When at the time PHD2 was not active, i get no error messages from NINA, it just stops responding. (But still tracking). At this time it is not possible to photograph through the night.
I am using a Mele2 Quieter PC with Win11 Pro. The Mount is connected with Bluetooth, using the Onstep driver 3.18. (Or 1.042 from Stellarjourney.) (I have tried every driver i could find.) When this happens i am forced to close NINA and stop the driver with the Task-manager, sometimes i am forced to restart the PC. I am slowly thinking  this is a problem with the mount, and not a driver problem.
Can anybody help me figuring out what is causing the problems?
CS Haaakon
akshay87kumar avatar
I had a similar problem with my mount would occasionally getting disconnected. I changed cables, power adapter, etc only to realize that it would somehow get "overloaded" when I connected the guidecam to the usb 2.0 hub port on the mount. With time, i realized this problem happened only when I connected the guidecam to the mount, and then connect usb from mount to my pc. This wouldn't happen when I connected filter wheel or autofocusser. Ever since, I have stopped connecting the guidecam (i connect it directly to pc). My main imaging cam is usb 3.0, so it likely handles the load of the guidecam + filter wheel + focusser well compared to the mount which is only usb 2.0
Maybe you have a similar situation?
Edit: I have an iOptron CEM40
Helpful Concise Supportive
TiffsAndAstro avatar
I'll bet 1 dollar it's usb cable or usb socket related
AstroÅmazer avatar
Try connecting the mount over USB, not Bluetooth. Also use standard USB cable, not FTDi or something similar.
It sounds like a 'Bluetooth not keeping up with queued guiding commands' problem.
Well Written Helpful Concise
I have used OnStep mounts for ages and never had issues with their drivers. But I never connect through BT, which I consider iffy if not worse. Always connect through WIFI or USB2/3 direct to the mount. Camera and guiding are plugged directly on the PC.
I am happy to report  that since i asked you for help, and i changed from a Bluetooth connection to using a USB3 cable, the mount is functioning with out problems.
Again to you all: Thank you very much!
CS Haakon
Respectful Supportive
New Setup and ASCOM Error message!!
Hello. I am at a new setup (New Computer) and have installed ASCOM ver.6.6 and all the drivers for mounts camera etc… I now need in my small setup. But when I open the dialog box and want to activate my mount (Skywatcher EQ5) I get this notific...
Mount connection problems similar to user's EQ5 activation issue with ASCOM.
Jul 12, 2023
ASIAir stops Autorun for impossible Goto
Several times when I am executing an Autorun the process halt because ASIAir want to go to the target I am photographing. When it has med 5 attempts it halts and I have to push Stop and push start again to continue the process. Very annoying, especia...
Mount communication issues similar to author's halting problem.
Jan 27, 2023
