Artefacts in registered images....what am I missing????
18 replies270 views
Christian Bennich avatar
Hi All
I am imaging a dusty region, and when stacking, I can see that my flats have not correctly removed a particular artefact.
Any input on what I might be missing here??
I cannot understand what I am not doing correctly to prevent this annoying artefact from showing up in my registered images.
Example files from all steps of my process is included, all settings in WBPP as well.
If I can provide anymore information, please let me know.
Any input on what I can improve or change to remove this is much appreciated.
This is a "boosted autostretch" showing the artefact in a registered image.
I can see the artefact in my Lightframes, very faint though (2 raw frames, from 2 different nights):
2024-11-21_22-57-09_L_0.00_300.00s_0048.xisf - https://drive.google.com/file/d/1UD7lDrBsmN4My-6dL6AoccgQq_ZoLqXC/view?usp=drive_link
2024-11-26_22-10-44_L_0.00_300.00s_0089.xisf - https://drive.google.com/file/d/1U1_OBXNoHHlDI-a4dOVjvXy0OJgg_mXa/view?usp=drive_link
I can see the artefact ONLY in my Luminance (L) Flats, which leads me to believe it's a dust moat or similar on the filter:
Red channel master flat (NO Artefact): https://drive.google.com/file/d/1mX1QHc5j0qdxZe05gjFKONfjucn0Rf03/view?usp=drive_link
Luminance master flat (Artefact): https://drive.google.com/file/d/1hy5tH0yXJMN6nEhHoP8VgvTaA0UVF09d/view?usp=drive_link
Luminance RAW flat example: 2024-11-22_00-41-29_L_0.00_2.50s_0007.xisf - https://drive.google.com/file/d/1KLSmbWJ0K4N-ed2MUmrGrHlDsKF11-vH/view?usp=drive_link
Example raw DARK used to calibrate FLATS: 2024-11-27_22-44-25_L_0.30_2.50s_0009.xisf - https://drive.google.com/file/d/1iZtKqFCndk3EDOWW_t052rmGrD6A-mR3/view?usp=drive_link
DARK Master created from above frame (20 in total): masterDark_BIN-1_6248x4176_EXPOSURE-2.50s.xisf - https://drive.google.com/file/d/1LJE4QWxRS-UflfnWzwXXFVjn-WxQRfec/view?usp=drive_link
In the registered output from WBPP, I can see the artefact still (same 2 files as above just after WBPP):
2024-11-21_22-57-09_L_0.00_300.00s_0048_c_r.xisf - https://drive.google.com/file/d/1c2ZmDrYARLiFKPA7Y4vAZ3wYwiHwnKOS/view?usp=drive_link
2024-11-26_22-10-44_L_0.00_300.00s_0089_c_r.xisf - https://drive.google.com/file/d/1o-vrWS5HcigOyoyZCYNfSzt8x8frFSHM/view?usp=drive_link
My setup is permanently mounted, and changes to the image train, angle, etc., have not been made during my sessions.
All images are with temperature 0 and Offset 0 on the camera. (ASI2600 MM)
I have redone both dark frames and flat frames to see if that "helped," but sadly, it has not.
My WBPP settings (pretty standard):
Helpful Respectful Engaging
As far as I can see you are correcing for a dust mote that doesn't exist in the light frames (luminance I get). Do you have master flat without that dust mote so you can use that instead. When did you take the master flat frames, before or after the sequence being taken?
If the artefact happens to be in an area where there are just background stars you can clone it out of existance. Otherwise, use Graxpert to see if that brings benefits (usually it does for the opposite case of removing dust bunnies shadows so it may work here too).
The dust mote is definitely also in my Light Frames.
If I manually stretch it with HistogramTransformation, it's undoubtedly there. Faint, but definitely there
I don't understand why the Flats don't correct it away then.
The flats are taken after my session on the 22nd, and I find the Dust Mote in frames from all sessions.
Unfortunately I don't have a flat without the dust mote in it that I could try. At least not with the camera in same position etc. which will yield the flat useless, as I understand.
I will try and see what GraxPert might be able to do, as the dust mote is not in a region with just background.
To understand fully about the issue I need to access the files which I can't because you protected the repository. Post them with filebin.
HA, OMG what an epic failure smile
Thanks for letting me know.
Links have been updated - you should have access.
Thanks Andrea!
I'll give it a look
Of the 2 test light frames one gets (ending with 48) fully corrected because it has a matching dust bunny. The other one does not because:
a. there is no dust bunny
b. the flat doesn't do a good job, probably because of additional light sources other than the sly.
See below for the fully corrected frame:
Stay tuned for how to get around the issue.
So, this is the frame with no dust bunny corrected with the wrong flat:
This is the same frame corrected with a synthetic flat frame:
To produce the/a synthetic flat frame select all the frame with no dust bunny and calibrate them with just dark/bias (but not both!). Then stack them up as is, no alignement or anything.
Apply Graxpert to the stacked up frame and save the synthetic background from Graxpert as the new master flat frame. The re-calibrate these ones with the standard procedure, whatever that might be.
Thanks, Andrea. I will do some more testing. Great insights; I never heard of a synthetic flat before.
I have checked both Light Frames, and the Dust Mote is without a doubt in both, but much fainter in the one ending on 89.
The 48 one
The 89 one
I will go and make a new set of flats to see how they look.
Strange that the Dust Mote is getting fainter......
Christian Bennich:
*That happens when you have local light sources (rather just the sky).
Could it be that in some way a little bit of dew or something has formed on the filter and now it's slowly evaporating or something?
That might explain the fact that it's dissipating?
Not really
Christian Bennich:
The flats are made in a completely closed "observatory" with the only lightsource being the Flatbox on top of the scope.
I can't imagine what source of light would creep in - but you never know. Stranger things have happened
I was referring to the light frames, not the flat.
Thank you @andrea tasselli for you guidance.
I now have a properly calibrated stack of Light frames.
A new set of flats to calibrate some of the images - with the faintest Dust Mote and another set to calibrate the rest.
I still do not understand how something that absolutely does look like dirt or a dust mote on the filter, can dissipate like that over days.
Oscar H. avatar
so, the graxpert synthetic flat method worked?
Nope, creating a new set of “proper” flats to calibrate the part of the data that had the least visible dust mote or whatever it was/is
Strange artefact in Luminance data
Hey Yesterday I started collecting photons on NGC7023 (Iris Nebula). I stacked last night's luminance data and played around with stretching and DBE etc., on the target. I have found a strange, more or less horizontal artifact or something in the...
Discusses artifact removal through proper flat calibration techniques.
Jul 11, 2023
[RCC] Need help processing M13
My first attempt at imaging M13 in Bortle 7 skies and I can’t seem to eliminate the background aberrations in PII. The image posted was done with DBE and some IC. M13 I posted the raw stacked master and flat and bias here: https://drive.google.com/dr...
Flat calibration issues can cause background aberrations similar to your problem.
Jun 23, 2023
Is something wrong with my reflector?
I purchased a coma corrector for my ProNewton but I am not sure I'm getting better results. In fact, although on the left side of the image it seems the situation is slightly improved, on the right side it's making it definitely worse. Do I h...
Reflector optics issues may cause artifacts; relevant to troubleshooting imaging problems.
Aug 19, 2025
Flats adding to images instead of subtracting in PixInsight WBPP
Astro Friends, I have been imaging for about 5 years and have been successful using refractors and mono imaging. I have branched out this year and now have an SCT and mono setup. I am seeking help with my flats which seem to add themselves to my imag...
Directly addresses flat frame calibration issues in PixInsight WBPP workflow.
Jan 2, 2026
Why Sii frames have this ?
Hi, Why my Sii master frame have this weird black ring and how I can remove it? is it because of light pollution or issues with flat frames? this is total integration of 270x180" I'm using Antlia filters 3nm, the frames were calibrated with ...
Flat frames not removing artifacts is directly relevant to poster's calibration issue.
Dec 22, 2022
