OAG vs guidescope at 700mm FL
19 replies387 views
Amit avatar
Hello,
I am considering going OAG route to improve my guiding. Currently with my AM3 mount plus 700mm telescope, I get around 0.8~1.2 rms guiding. Hoping OAG brimgs it down by atleast a third.
 I want to get the entry level ZWO oag + asi120mm-mini camera.
Is this combination good enough to provide sufficient stars for guiding purposes at 700mm?? or do i need to go up with the oag-L + 200mm mini camera to find sufficient stars?
any feedback/suggestion appreciated.
thank you.
Pete Bouras avatar
I use a 60mm guide scope on my SVX140T (970mm focal length) no problems at all, I get 0.6" guiding at my location.
As long as it is mounted sturdily you should have no issues.
The guiding rms is also a function of your atmosphere (altitude plays a big role here), depending on your location you may not be able to get better rms guiding if your atmospheric seeing quality cannot support it.
Pete
gfunkernator avatar
Golden rule for guiding error:
You guiding error should be at or below your primary image scale.
Niels_L avatar
Hi Amit,
I looked at the ZWO OAG some time before, but then realised I wanted the OAG-L but this only works with some ZWO camera's.  The OAG-L is screwed onto your camera and placing a spacer in between (in order to screw it to the camera) adds too much back focus for the typical 55mm...  Check out https://www.zwoastro.com/2024/09/26/the-best-solution-of-55mm-back-focal-length/ for suggested combinations.  Perhaps you can find another way but I stayed with my 32F4 guidescope.  Lately, I did get much better guiding after properly calibrating the guiding and using the settings.  Though all depends on your situation.
I do use the ASI120mm mini for guiding, bought it because of the price.  I have used the ASI120mm with my Celestron 8" F10, 6.8x reducer and Celestron OAG, but the ASI120mm struggled with the stars due to the small sensor... I would not use the ASI120mm for an OAG, rather get a larger sensor. Though, enough stars in the OAG also depends on your target - Stellarium has a nice feature for OAG framing.
Niels
Dave Rust avatar
Those numbers do seem a little high. Despite that, are your sub stars round? Have you tried changes in aggressiveness and guide scope exposure time?
A note of comparison:
I use a conventional Askar guidescope on a 9.25 EDGE-HD, which is 2350mm. Guiding is between .30 and .70. I've seen the number for a whole sub as low as .20…so most of the larger variation is coming from the atmosphere above. Not much that can be done about that without going to adaptive optics, which have their own issues.
The 925's main scope image scale is a theoretical .335…and most of my subs are close, averaging around .45.  Good enough for me.
I would think an OAG might not lead to a better image for you.  At 700mm, your image scale is likely over 1.0. Your guiding numbers are usually at or below that.
It's still worth seeing if lower numbers are possible. The images might benefit, and your expertise in optimizing your gear will grow.  Good luck tracking it down!
dummieastro avatar
Amit, I shoot with a 700mm Askar 103 apo on an AM3 mount with a traditional guide scope and asiair 120mini. 95% of the time my guiding is between .38 and .85. I consider .45 - .68 to be my normal.  At 700mm the AM3 should be able to do much better.  Perhaps if you are shooting with a SCT at 700mm there are issues I am not aware of since I don't use a SCT.  I would play around with your guiding settings before going OAG. There is some good information out there on fine tuning guide settings with a strain wave mount which helped me when I first started guiding. I shoot in Bortle 4 with average atmospheric conditions.  The only time my guiding gets bad is when I get near the horizon, which I try to avoid. I bet with a few tweaks on the settings and calibration you will get much better results.
CS, Bob
Helpful Respectful Supportive
Alex Nicholas avatar
So… There's all these rules and what not that people talk about about how you should always guide at at least 1/5th of the imaging scopes resolution etc.. But do you notice there is no maximum? That's because the more resolution your guider has, the sooner your guiding system can detect star movement, and then correct for them…
I use an OAG on all my set ups…
65PHQ + 0.75x reducer (312mm focal length)
65PHQ (416mm focal length)
120APO (840mm focal length)
and in the past, on my 8" RC @ 1634mm focal length and the C11 @ 2800mm focal length.
I currently image with an IMX294 sensor, that has 4.63um pixels, and guide with an IMX178 sensor, that has 2.4um pixels.
So on the Askar 120APO, I'm imaging at 1.14"/px, and guiding at 0.59"/px. I'm regularly guiding at or near 0.2" RMS, and on the other extreme, the 65PHQ at 312mm focal length is imaging at 3.05"/px and guiding at 1.49"/px…
Because my guiding system is essentially twice as sensitive to movement as my imaging system, I never have issues with guide error… and an error would have to be MASSIVE.. as in, the guide star would need to move 2 full pixels on the guide sensor for my imaging sensor to know about it…
The ONLY issue that can arise from having a super high resolution guiding system, is that seeing effects can be magnified… Running 1~1.5s guide exposures and using multi-star guiding can help to alleviate that, or in the worst conditions, I will bin my guide camera 2x2 and then be guiding at about the same resolution as im imaging, thus, negating some of the 'seeing induced error'
In my experience - Always use an OAG and save yourself a ton of struggles. Once you're used to using them, they are easy as pie, and I won't guide any other way.
Helpful Insightful
Coolhandjo avatar
OAG saved my imaging. On HEQ5 and AM3 the guiding error cut in half
David Russell avatar
I have a 50mm ED Doublet guidescope on my Tak FSQ106 which is 530mm focal length. works good.
I also have a 10 inch RC, which is 1484mm (reduced) and guide the RC with an 80mm Stellarvue Doublet which is 560mm focal length.
both seem to work fine.  I might replace the 80mm Stellarvue with something a bit smaller and lighter just to drop the weight a bit.
anyway if something works ,it works, and thats all that matters.
Amit avatar
Thank you everyone. very valuable information for me.
My previous guidescope did have some flex on the focusing tube and i was using it with the celestron C6 at ~985mm FL with my 533mc pro sensor. I also used a dew heater strap on the guide focusing tube. I have returned that guidescope and also moved to the askar103 as my main scope recently, So wanted to rethink the whole guiding setup.
I will just get a better guidescope(helical focus types) and make sure the setup is flex free and work on calibrations to see how it does. going OAG route with the larger prism and larger guide sensor is definitely some investment which I will look at some time in future.
Thank you.
Tony Carro avatar
My limited experience with an OAG is remarkable.  I didn’t use the ZWO oag and I used the Askar OAG and Filter which gave me precisely 55mm.  I am using the Asi120 and my stars are tack sharp.  My RMS dropped from 1.0-1.2 to .3 to .5 .  The mirror is huge and does not cover the main sensor.  I have an unused ASI224 that has larger sensor area I am going to try on it.  That’s what makes this superior to the Zwo OAG is the real estate of the mirror is larger down the main tube.  The price is better when you figure you are getting a quality precision focuser with the OAG and the ZWO-L you have to buy it.  Got a spare Williams Optics  guide scope now.  Your mileage may vary.
An OAG will only give you an improvement in your guiding if you are suffering from flexure. Also, keep in mind that the effects of flexure will not be apparent in your guiding RMS, only in your images.  Switching to an OAG setup will not improve your guiding RMS much, if at all and it will make it harder to find guide stars. It's hard to know what's causing your guiding numbers to be inflated without seeing an extended guiding graph and knowing more about your rig and conditions.
Derek Vasselin avatar
What is your current setup? Main camera, guide camera, guide scope?
0.8-1.2" RMS guiding is probably a little high, but it may be within the acceptable limits of your setup.
If you're still not happy with it, you can adjust the guide settings to improve the accuracy. I had to do this to get from ~1.5" RMS average down to ~0.5" RMS average. It was a bit tedious and frustrating, but worth the effort.
I created a dark library for the guide camera and played around with the RA & Dec aggressiveness and steps until I settled on a good guiding number. Also, I found my guiding is better with 1.5s - 2s exposures vs 1s — too much turbulence at 1s.
For reference, I'm using an 80mm f/6 main scope, 50mm f/4 guide scope, ASI2600MC main camera, and ASI120MM guide camera (both 3.76 µm pixels).
My main camera resolution is 1.62"/px, so my error shouldn't exceed that, which is how I knew bouncing around 1.5" RMS (and often over 1.62") wasn't good guiding.
You can go the OAG route and that will help the accuracy, but you will probably still need to optimize your guide settings regardless.
Tony Carro avatar
Forgot to mention that I used to do 5 minute subs and now doing 10 minutes.  Wish I would have done this from beginning.  Optics of main tube is so much better than from any dedicated guide scope for all the reasons that have been stated.
Amit avatar
Tony Carro:
10min subs.. woww. I could only go 2min with my previous setup i.e. C6 SCT at 985mm FL. I think my guide scope definitely had a little flex and putting a dew heater strap on it might have worsened it. I could only do 60sec to 90sec subs with good star shape.
Thanks for sharing.
And before you even get into tweaking you should do a good calibration followed by running PHD2's guiding assistant and accepting the values it gives you. That alone can make a huge difference.
Well Written Concise
If your guiding is accurate enough you should be able to go as long as you like with sub-exposure time and get round stars. It's also important that your error be balanced. You should see about the same amount of error in both RA and DEC.
Tony Carro avatar
The alignment is all done with asiair and zwo focuser.  I have it set to refocus every 30 minutes (3 exposures in my case).  Stars are sharp to the edges for my eyes , not doing pixel peeping.  Love the automation of darks and flats thru asiair.  Lost a guide scope and dew heater after going OAG.
Tony Carro avatar
 My 533MCPro,10mm spacer, filter holder, OAG.  2nd shot shows how big mirror is to sensor.
Tony Carro avatar
here is shot down tube
