How Does The New Mosaic Feature works?
11 replies678 views
Szijártó Áron avatar
Hello and welcome! I would like to ask everyone who uses SeaStar to process their astrophotography images. How does the mosaic feature work in SeaStar? I'm new to this feature, so I'm not sure how it creates additional subframes. Does the new mosaic mode first build up the image and then enhance it, or does it work like the default mode, enhancing the image while taking subframes? If anyone has experience with this, could you please explain how it works? Thank you!
Ralph avatar
It starts like the normal imaging mode in the middle and adds more and more images out the center until the whole bigger frames is filled. There is a recommendation of the minimum time in the seestar app. And after some time the complete frame is filled with data - rather smooth ...
Here is an example in a German forum - with bigger selected frame already almost filled:
https://www.astrotreff.de/index.php?attachment/89566-1730089223746-jpg/
I think this is more useful than text ...
Clear skies - Ralph
Nazmus avatar
It's not like a traditional mosaic where it takes just a handful of panels. Instead each individual exposure spirals from the center until the frames take up the field of view you selected. As a result, the signal to noise ratio can be very different from one part of the image to another. It enhances the live stack as it takes them so you can slowly see it build up. Here are a few screenshots of M 31 at different stages of the mosaic. I'm working on creating an animation to show all the frames as they are captured (but not stacked).
Eric Gagne avatar
Cuiv the lazy geek made a video about it recently.  Maybe check it out on YouTube
Andreas Heertsch avatar
Unfortunately it is (as far as I see) not very detailed documented. The S50 scans the selected area with stacking of a few (ca. 1 min.) pictures, then it moves to the next position (witch a lot of overlapping)
At the end you get pictures like this:
as you can see, M31 is not in the center. But in the frameing window it was. The framing windows is cut to the smartphone-screen. You see also, that the non overlapping areas lack in resolution (off course).
The pitty is, that the fit-files are not stackable in Siril. Or has someone found a way to stack these framed fit-files?
Btw: the name of "Mosaic" is in S50 is "framing" (found in Stargazing => StarMap => Framing (green rectangle on the right side) )
Andreas
Andreas Heertsch:
Andreas
Well, that sucks. If it cannot be stacked. Unless one of the popular astrophotography channels has made a video about it, for example, Deep Space Astro, aka Rich. Although I saw a video in which someone managed to stack these frames, only in Pixinsight did not watch it yet, but I saw that video. But unfortunately for me, I'm so new to that software yet. So I can only use Siril.
Szijártó Áron:
If ZWO would mark all stacked fit's connected to the same view in their names eg. with a ascending #, it would be possible to stack every view by Siril and combine theses stacked views  with Microsoft ICE. But ZWO did not.
Andreas Heertsch:
Szijártó Áron:
Hopefully, they will make their frames stackable in future updates, including changing the format of the images. Until then, we may need to find ways to enhance these images to improve their quality.
Ralph avatar
I have tested to stack the sub frames  from a mosaic - working in siril without any trouble.
I have used a siril script (German forum astrotreff.de siril script in version 8c).
Greetings - Ralph
Ralph:
Greetings - Ralph
And what script is that, if there's a specific script for processing the mosaic frames? Like seastar mosaic proccesing  or Simply OSC Mosaic Processing? Or can you use any script for it?
Ralph avatar
In the past I made mosaic in Siril Script 8c - max in German Astroforum astrotreff.de from Aludobson (Eric):
https://www.astrotreff.de/forum/index.php?thread/289728-siril-scripte-f%C3%BCr-seestar-s50/&postID=1694153#post169415
Just download and remove the suffix (.pdf) and save it the script folder defined in the menu - Properties scripts - typ.:
C:\Users\USERNAME\AppData\Roaming\siril\scripts
C:\Program Files\SiriL\scripts
I usually move the point of interest in the Seestar-App and also use the mosaic option in the seestar app. Putting all .fit files together in one folder, point the "Home-directory" of siril to this path and run the script 8c max.
I usually select the area of interest in Siril and cut the picture. Depending on the quali´ty of the results you may use oner the reult images in the result folder ...
Hope that helps - greetings
Ralph
Ralph:
Ralph
 Weird When I run this kind of script, the software fails to finish the script, but when I open up the image, it does look like it did the thing. What now?
Does this script work? Or can do that with the regular seastar pre-processing?
Seastar Stacked Images VS Manually Stacked Images? Which Would Look Better?
Hello and welcome, id like to ask everyone who is using Seastar and stacked their Images with both method, with seastar and with Siril software. Just expericed its deep sky stacking menu. And it rised me some queations. If u restack those images that...
Sep 1, 2024
Both posts are asking the astronomy community for advice and experiences with SeaStar astrophotography software, specifically seeking explanations about different processing features and methods.
Does Anyone Tried To Use The Seastar With This Tripod? And How To Use With It?
Hello and welcome! I would like to ask everyone who uses the Seastar or is familiar with the Skywatcher tripod for telescopes. Today, I tested the telescope and its compatibility with this tripod, but I ran into a problem. When I tried to move the te...
Jan 29, 2025
Both posts are from newcomers seeking technical help with astronomy equipment they're having difficulty using properly.
Which EQ wedge is the most Easiest to use With the Seastar?
Hello and welcome! I would like to reach out to everyone who is using the Seastar with either the Skywatcher wedge or the wedge designed specifically for the Seastar, which is planned by ZWO. I'm having trouble setting my Seastar into EQ mode, an...
Jul 2, 2025
Both posts are from users seeking advice about using SeaStar equipment for astrophotography, with one asking about the mosaic feature and the other about wedge compatibility for equatorial mounting.
