John Schreiner avatar
Hi All, need some help with DSS. I have been using it for 3 years but today I am totally lost.
I took 66 images in HA last nite, stacked today in both 32bit and 64 bit and every time I am getting an image of
a different star field...its operating normally and I have tried uninstalling and reinstalling the 64 bit version. Same issue.
attached are my stack image and then a single ha frame..the star fields dont match??
I use darks and flats..tried stacking just 5 images with no calibration frames and this same star field is coming up..its not the image I was processing?!?!
What's going on?
Any suggestions appreciated. I must be missing something stupid...
thanks, clear skies
watcher avatar
Show us your other image.
Adel Kildeev avatar
I also recently had some problem with DSS- bad alignment and glitches with flats. I changed settings but still it works not so well. The same time my imaging program SIPS suddenly dropped all settings to factory ones- realky strange. All this s..t happened after Windows update- is it related to these issues?
Hello and thanks for the replies. I "fixed" the issue by checking in Settings the "Bilinerar Interpolation" method of Bayer Matrix Transformation after seeing that I had checked "Create Super-Pixels….." . I checked that since it was recommended for HA data but appears not in my case.
Once I did that, my stack came out right…of course after reinstalling the 64 bit version, really who knows what happened, but its working now.
Clear skies…
Concise
Adel Kildeev avatar
I am trying to refresh my skills, but feel really rusty. I got a very nice set of fits files but wasted few hours trying to register images. For some reasons DSS (I upgraded to 5.1 version) register the files but they disappear, I cannot find them. Normally registered files should be in the same folder as final images but they are not…. The program shows successful registration and even stacking but , there are the registered files, God knows. I also tried Maxim 5 but again failed. Aligning files are problematic even manually with two stars, getting double stars and unclear image. Somehow I managed to align the images but not perfectly. I cannot use PI (my laptop will not survive this software), but old soft does not work well for me too. Any ideas?
QHY268M correction issues with camer in pixinsight
I have had this camer for a couple of months and I have not been able to properly correct images. I am coming from a 294mm and mc and I am using 33 darks at matching temp and 33 flats at matching temp. flats are calibrated with flat darks. Images are...
Camera correction issues may relate to calibration frame problems causing misaligned stacks.
Sep 9, 2023
Flats problem with long-focal length Mak imaging?
Hello, I'm wondering if anyone has ever had a problem with flats calibration with long focal length Mak imaging. I'm testing out a new setup (details & example here: https://astrob.in/ij748l/0/) and for the life of me I cannot understand ...
Flats calibration problems could explain misaligned star fields in stacked images.
Apr 17, 2023
