What star reduction techniques?
23 replies1.2k views
Cfreerksen avatar
What star reduction techniques do you use and recommend? I have used the EZ processing suite reduction and like it. I recently have been using morphological transformation process, using morphological selection. I used it on my last capture https://www.astrobin.com/full/7l3rk7/0/ and it worked very well.
Chris
Lynn K avatar
I just used Russell Croman's StarXTerminator Photoshop plug-in.  It is designed for CC, but I got it to work with PS5.  Superior to StarNet but not free. $60.
Lynn K.
Cfreerksen avatar
I was looking for Star "reduction", not removal. I rarely like images with no stars. Too many stars can overwhelm the image. That is why I asked about a reduction to suppress them.
Chris
Well written
Lynn K avatar
Sorry, Chris. I understand.  I see you are pleased with the results you are getting.  But. removing the stars, processing and then adding the stars back in, may give you the smallest controllable stars.
Lynn K.
Niels V. Christensen avatar
I use the deconvolution method,  and StarShrink in PS,
StarShrink (rc-astro.com)
Cfreerksen avatar
Lynn K:
Lynn K.
Thanks for the tip. I will give this a try on my next project. I have started acquiring a 4 panel mosaic of the Cygnus Loop. My first mosaic.
Thanks, again!
Well written Respectful
Dale Penkala avatar
Cfreerksen:
Chris
The process of removing the stars and then adding them back in gives you more control as to what you really get or want so its really part of that “reduction” process that @Lynn K  & @Gianluca Montanari are talking about which btw is better IMHO.
If you don’t want to work with that process then the way I did it before Starnet++  (even after on some things) In Gimp used the Select Color option (with a threshold of about 35) click on a star and Grow to 3-5px/feather 3-5px then go to/Filter/Value Propagate and check “more Black” deselect and use your Opacity slider to control reduction factor.
Randall Magnuson avatar
In the data processing techniques I think some thought might be given to the authenticity of the change. Is cycling star fields correcting for misrepresentation of size for brightness at the expense of disappearing stars?
It would seem stars part of the evolution of a nebula, for example, demand uncompromising accuracy so full evidence of the interaction is available.
Just a thought as to where the line is between accuracy and tampering of evidence.
I also look to correction for blooming stars that still maintains some sense of relative brightness other than by diameter.
After all, most of the general public think astrophotos illustrate actual star size.
Stephen Richards avatar
Lynn K:
Lynn K.
Thanks for the tip @Lynn K . I’ve always used starnet++for my processing but starxterminator is so much faster and easier. A game changer for me. 👏
George  Yendrey avatar
I've used the Starizona Star Killer add on to Photoshop, and the EZ Star Reduction Script in PixInsight.
I've also used Starnet to extract all the stars, Adjust the Curves to increase color saturation while at the same time, pulling back luminance to tone them down a bit and found that sufficient.
I don't care much for starless images, but I do like to reduce the stars slightly to put the focus /emphasize the nebula features that I'm typically imaging.
One caveat is I'm finding that the plate solver function in Astrobin does not care for the the image files that result from the EZ Star Reduction script in PixInsight.  It doesn't really say why; a question I've asked Astrobin support.
Bryan avatar
Cfreerksen:
Chris
For star reduction there are many ways to accomplish the task as previously mentioned.  I feel using Starnet to remove/mask while editing the DSO, then adding them back offers the greatest amount of control.  Once the star mask is added back, EZ star reduction is still an option.  Cuiv just posted a video on his process within Pixinsight further explaining the way.
star-watcher.ch avatar
I know there are a lot of different techniques to reducing star size, but I'm wondering: Is no one using StarMask and then Morphological Transformation in PixInsight to reduce star size anymore?
It works pretty well IMO, I still use it to reduce star size, but maybe I'm not aware about new better techniques ;-)
https://www.star-watcher.ch/image-processing/reduce-star-size-in-pixinsight/
Karol
Karol
  The EZ Star Reduction in PixInsight  automates the entire  process and it gives you two choices of methods - the morphological and one based on Adam Block's process that he teaches in his PixInsight courses (except the EZ suite automates it).  I tried both methods in the EZ Star Reduction and like the results based on Adam Block's method better.
On my image that I was testing it on, the morphological achieved approximately the same star reduction but increased the background levels which would require a curves adjustment to compensate for.  The Adam Block option did a good job of reducing the stars, preserved the dark levels and, surprisingly, enhanced some of the fainter nebulosity very slightly but noticeably.
In my PI installation the EZ Star Reduction script defaulted to 5 iterations, which I did not change.  The tutorial I saw on the script showed a default of 2 iterations but that was from a user with a beta version of script.
YMMV
Mike Dobres avatar
Hi Chris,
Startools' Heal module works very well to reduce the intensity of stars. See this link for a dsicussion and examples. .Similar to other apps, you separate out stars from nebula, adjust/sharpen the nebula and then put the stars back in at the intensity you want.
https://forum.startools.org/viewtopic.php?f=7&t=244
I used it to reduce the intensity in a very short integration of the Bat Nebula https://www.astrobin.com/h1poo0/
Best
Mike
John Hayes avatar
I sometimes use a combination of MorphologicalTransformation in PI and StarShrink in PS to "dial back" the prominence of a star field.
Andy  Brown avatar
Stephen Richards:
Lynn K:
Lynn K.
Hi Stephen & Lynn,
I've just tried StarXterminator after using the star reduction tool in the Beta version of APP. I agree the results are far superior using StarXterminator with PS:
Clear skies,
Andy
Karol
YMMV
George, thanks for the hint!
I installed the EZ Processing Suite and it's great! It comes with many useful scripts.
Karol
The irony of the fight against light pollution, so we can see more stars to remove. Now you see them, now you don't.
Well written Insightful Respectful Engaging
Andrew Klinger avatar
I do not completely remove the stars from my Luminance (Ha), but I do use StarNet to help make the perfect star mask. Original-Starless and then use HistogramTransformation to squeeze the white point way in, and finally a small Convolution. With that mask on the almost-final image I will run MorphologicalTransformation to the point where the stars are still there but small. It is okay if they are too squishy looking because my final step is to run a very light UnsharpMask using that same mask to tighten up the stars. The end result is much smaller, and deemphasized stars.
Cfreerksen avatar
Andrew Klinger:
I don’t understand why one would want to use Ha as Luminance. Would that not leave a bunch of the data out? I am shooting a 4 panel Veil at 500mm fl and there are tremendous differences in each narrowband data set. This applies to many targets that are not extremely Ha dominant.
Cfreerksen:
Andrew Klinger:
You're correct. Do a blend of the Ha and Oiii for some.
[RCC] feedback on NGC 6188 photo (HOO PALETTE)
Stacked and processed in Pixinsight . Following steps (after stacking): 1. Green removal with SCNR. 2. Dynamic Background Extraction. 3. Noise reduction (EZ suite). 4. Sharpening (EZ Suite). 5. Soft stretch (EZ Suite). 6. Star removal with Starnet. 7...
Discusses noise reduction and processing techniques relevant to star reduction methods.
Jun 4, 2023
Looking for guidance on controlling star bloat when stretching a stars only image after using StarXterminator.
Does anyone know of any video tutorials with masked stretching techniques for star only images? Once stars have been pulled out of an image, I am looking for techniques on how to stretch them and keep the brighter ones tight and not bloated while sti...
Addresses star handling techniques including masking strategies for star management.
Jan 31, 2023
Improvements to my PixInsight workflow
Hi all. I'm trying to improve my processing but feel I've hit a bit of a wall in Pixinsight and I'm not sure what to look at next to try and imprive. Here is my current workflow: Stack in DSS. Open in pixinsight. Screen transfer function ...
PixInsight workflow improvements may include star reduction technique discussions.
Feb 14, 2023
