Controlling Camera Fan Speed in NINA
N.I.N.A. Users 9 replies220 views
Jerry Gerber avatar
Dear Astrobinners,
I have a ZWO ASI2600MM camera and am trying to figure out if I can adjust the fan speed in NINA.  I googled it and it seems to be possible, but I cannot find the setting.  With ASIAIR there's a switch for High or Low Fan Speed, so I know the camera itself can be adjusted.
Anyone know how to do it?
Thanks,
Jerry
https://www.youtube.com/@astromusicvideo
Jim Waters avatar
With NINA it comes on when connected if using the native driver.  I know of no fan speed setting.
Jeff Rothstein avatar
I, like Jim, know of no setting in NINA.  You might look at the ZWO native ASCOM driver to see if there is a setting there.  I don’t recall one, but I wouldn’t have been looking for it.
Jerry Gerber avatar
Thanks Jim and Jeff, I'll check the ASCOM driver, I haven't installed it.
Jerry
Well written Respectful
Timothy Martin avatar
There's no setting for this. The camera controls the fan speed. And as best I can tell on the 8 or so ASI cameras I own, there are only two speeds: (1) Off, and (2) full blast. Not sure why this is an issue for you. The fan is there to cool the internal electronics. Presumably, the ZWO engineers selected the fan that would get the job done.
Well written Concise
Jerry Gerber avatar
Timothy Martin:
It's not much of an issue, but today when I started making darks I was using ASIAIR as the controlling software, and it has a switch for Full Fan Speed and Half Fan Speed.  I could hear a very slight noise when I put it on Full but it was silent when at Half Speed and at Half Speed it cooled the camera fine in a room that was about 70 degrees Fahrenheit .   So I know the camera is capable of responding to different speeds.
Apparently NINA doesn't have that setting.   As so long as the fan noise doesn't cause any vibration, it should be OK.
The ASI2600MC I've been using also makes a little fan noise but it's never affected imaging so the 2600MM is likely going to be fine.
Jim Waters avatar
If you are worried about fan vibration, one of about 10 links somewhat fixing the problem.  Do a YouTube search - "ASI2600 fan vibration"
https://www.youtube.com/watch?v=WwaT_HVLI98&ab_channel=Robservatory
Frédéric Ruciak avatar
Hi, as far as I know the camera is controling the fan to manage the sensor temperature. Without fan, you cannot reduce the sensor temperature as the radiator of the thermal coolers need to be ventilated to extract the heat. If you have significant vibration you have to find another way to equilibrate your fan.
CS Frédéric
SonnyE avatar
Hi Jerry,
I don’t know of a way, but it is a DC motor so possibly the ASI Air sends it a reduced output to the camera.
That is one way DC motors can have their speeds reduced.
I take my ASI2600MC Pro and blow it out with compressed air (or canned air) to blow as much dust off the fan blades and the cooling fins. Just a preventative maintenance thing.
Rick Krejci avatar
My player one cameras can control the speed, which is nice especially when ambient isn’t too hot. But no Zwo cameras I’ve had can.
Mysterious star trailing solved: a cautionary tale of fan vibration with a fan cooled (especially ZWO) camera.
Suddenly after no problems with star shapes, the next night out they were just terrible! Below I show a gif comparing two 2 hr stacks, one with the good stars, and the next with elongated stars. In this example the distortion was vertical. But later ...
Fan vibration issues directly relevant to ZWO ASI2600MM camera fan speed control.
Nov 18, 2025
