What to choose - Askar 103apo vs Explorer scientific ed102 fcd-100
18 replies855 views
Ancient.Photon avatar
I am in search of a 4in refractor and I have narrowed my search to these 2 -
1. Askar 103apo + 1x field flattener ($1200)
2. Explored scientific ed102 fcd-100 + 1x FF ($1950). used ones around ~$1400
Is it worth (how much) going ~$750 extra for the fcd-100 glass on the ES ed102?
Will the Askar apo + pixInsight (& BXT) be equal to ES ed102 + basic free processing (no BXT) ? In terms of sharp imaging
i am a beginner but want to have a scope that I keep it for years. The fun part of this hobby has been going out in the dark and setups and collect all the data. I want to keep the post-processing part shorter and limited to free tools. pixInsight can cost upwards of $450+ with the ad-ons.
Any feedback/guidance is much appreciated. Please let me know if you have owned the ES FCD-100 telescope or the Askar and how’s your experience been?
Cheers and clear skies!
dummieastro avatar
Amit, I have the Askar 103 apo with the 1x flattener and .8x reducer.  I use it on the AM3 mount(usually with the counterweight), although not required. My cameras are the 533 and the 2600. It is a very good value and very well made. Optical quality is good, you may get some chromatic aberration occasionally. I like mine very much. My images are hindered more by my meager processing skills than the scope. If you go under equipment - telescopes you can see lots of examples with the 103apo. Mine are there under dummieastro.  However, if you want to take a step up I would go for the Askar 107phq instead of the Explorer Scientific. Get the counterweight for the AM3 which does not cost much. I don't think you will be disappointed with the 107phq.
CS, Bob
Thomas Rider avatar
If I can read spot diagrams correctly, the 120APO is the best corrected of all the Askar APOs. I would possibly go that route and I might go that route myself.
CA, Bob
thanks Bob, I have a AM3 as well and 533mc pro. I did have 107phq in my list but it was touching that $2000 mark which was getting way over my budget. I will keep an eye for a used one if available. Thanks.
Thomas Rider:
120apo definitely looks like a beast. Lukomatico’s review on 120apo did convince me to go 5inch refractor route but I think it may be a way too much for my AM3. I think there are a few images with 120apo + am3 here but not sure with tracking. Think oag would be a must at that focal length as well.
Look like I need to decide between 103 or 120.
thank you
Thomas Gaffney avatar
I use the Askar 103 APO with its field flattener and 0.8x reducer. It is really good considering its price. Does it have super premium opitcal quality? No, but it performs quite well and by using modern day editing tools, you can fix most minor optical issues. I can't speak to the quality of the Explore Scientific scope. Most of the images that I have posted are from the Askar so feel free to check them out. I also tried the 0.6x reducer, but I had issues with elongated stars in the corners. The standard 55 mm backfocus didn't seem to work.
Coolhandjo avatar
Ancient.Photon:
Thomas Rider:
thank you
Yes I jave an am3 and looking  at the 107phq or the 120. Be interested to hear am3 120mm aksar uses on guiding stat's
Mel Martin avatar
I  also use the Askar 103 APO with its field flattener and 0.8x reducer. It's on an AM3 which I think is a terrific mount. At the price the combination is unbeatable.
Many of my images posted were taken with the 103. There are many other examples up here. I think the images speak for themselves.
Looks to me 103apo at its price point is hard to beat.
anybody use 120apo with AM3+counter-weight. How is tracking?
Mel Martin avatar
I have not found counterweight is needed with the APO 103. Tracking is as good as I have seen.  I know someone who has the 120 and he has no issues on the AM3, but he considers a counterweight 'an option'.
Mel Martin:
thanks @Mel Martin , good to know.
Juan Chanclas avatar
I have the 102 essential series (not FCD) and I have the 127 carbon fiber with FCD100 lenses, the difference between both lenses is noticeable when you pay special attention to the chromatic aberration, but I recently acquired an Askar 140APO with the 0.8x reducer and I am surprised by the punctuality of the stars and I do not notice much chromatic aberration with respect to the 127FC, what I mean is assuming that the quality of the lenses of the askar 103 is the same as that of the askar 140, maybe they are a little behind the FCD100 lenses, but it is not a big difference so noticeable.
CaptnCook avatar
I have the Askar 103. Please look at my images which are mostly using that scope on the AM5. It's a great scope. However, I think you'll be missing a trick if you don't get PI and BXT.
Cheers
Gary
Ed Dixon avatar
I went through a similar decision a couple of months ago.  I looked at the Askar 103, the 120, and the ZWO FF107.  I ended up with the 107 and have been very happy so far.  The lack of a need for a flattener was a real plus.
Well written
Beat Wirthmueller avatar
Hi Amit - I personally use the Askar 103 with my ZWO ASI2600MC duo on a AM5 and I'm very satisfied with the results especially considering the price. Another point is the versatility of this telescope with the flattener and the two reducers. So depending on the object, the filter I want to use and the possible time I can invest I have a range from 420 to 700mm focal length and a focal ratio from f/4.0 to f/7.0 to choose.
You can read a lot about the poorer quality using the 0.6 reducer/flattener. You will see a vignetting and some elongated stars in the RAW Images. But using flats and the possibilities of modern software as PixInsight both of these issues can be controlled very well.
Don't hesitate to invest in software like Pixinsight and BlurExterminator - It really helps to get the most out of your pictures and makes this hobby even more enjoyable :-)
Awesome! Thanks for the feedbacks . Looks to me it’s better spending the money on post-processing software and go with the Askars.
Jon Bryan avatar
I have had a 103APO/ASI533MC/ASIAIR/AM5 setup for the past year, and I'm very happy with it. I have the 160mm pier extension on the TC40 tripod, and I pick the whole rig up and carry it outside using the pier extension as a handle. I would highly recommend investing in PixInsight and Croman's extensions, whatever scope you get.
Well written Concise
Tareq Abdulla avatar
I have many scopes but not in 4" category of refractors until last year, so i ordered 106mm f/6.6 and the seller included 0.92x with it free of charge and also hard case and all are free shipping, total was $1400, i even asked the seller to make a mask, aperture mask to reducer it from 106mm to 70mm so i can use the scope for solar sometimes making it as 70mm f/10, it is a triplet with FCD-100, i never tested or took it out of the shipping box yet, but i always trust anything i buy, because i am lucky enough with long patients, i never worry or care about stars, because for stars i will just buy a dedicated scope for it which is corrected as field and as CA, and a Quintuplet is the best idea for that, also thinking too much about stars halo or CA is very annoying these days, you can always eliminate or reduce that by post processing and also using some filters to cut it off, if you are too much crazy about it then just buy a reflector, believe me even a 10" semi APO or achromatic refractor can have that CA to a degree even not very noticeable and you still worry about it.
Now i have two 90mm triplets and 106mm triplet i only need a scope in that range 90-110mm giving me about 400-450mm focal length but being as a Petzval or Quintuplet and not so expensive, WO and ZWO scopes are $2000 or above for those range although other brands are cheaper, i don't pay attention much about the optics quality, my Askar FRA400 doesn't have CA, and even if it has it is very minimal that i can easily remove it if i want, i don't like to spend time with post processing also, so that i can try to find methods and ways to go around that, one of them is to have a perfect scope inexpensive for stars only, while for narrowbanding i can use even my sunglass or binocular for that because it is very narrow so CA isn't an issue.
Coolhandjo avatar
I just purchased the 103 with 0.6 0.8 and flattener. To pair with my 533mm.
I have the askar v already.
This 103 completely fills the gap of fov so now i cover just about every FOV you can image . The 103 gives me the perfect balance of image scale and aperature also.
I'm incredibly amazed at the askar v image quality and expect nothing less if not more from the 103
