POLL: What mode, gain and offset do you use?
Stellar NomadsShannon FoyeChris White- Overcast ObservatoryKevin MorefieldJohn Hayes
42 replies1.5k views
Stellar Nomads avatar
hello folks
I have the previous version QHY600 and I also have the Astrodon I-series LRGB as well as Antilia Ha 3nm. I would like to know what everyone is using for setting? I am using it with an OOUK AG16 F/3.8 newtonian.
Thanks so much for your input and time.
Robert Lowenthal avatar
For Narrowband filters: Readout Mode 1 (High Gain Mode), Gain = 56
For Broadband filters: Readout Mode 3 (Extended Full Well  Mode - 2CMS), Gain = 0
I currently have Offset at 20, but from what I’ve been reading I’m considering bringing up to 50 or 60.
Pete Bouras avatar
CMS-0 Gain 26 offset 30 for LRGB
CMS-1 Gain 56 offset 30 for SHO
David Koslicki avatar
2CMS-0 Gain 56 Offset 76 for everything. I'm also using Antlia filters
Paul O’Brien avatar
Very interesting to see the variety of settings people use.  I use one setting for all my NB and broadband imaging with very good success: Mode 0; Gain 27; Offset 10.
thank you all. Mind also sharing what F ratio are you using and what exposure times please? I know there have been a LOT of questions around this subject, and I want to sort consolidate it in one place.
Again, you are appreciated.
GalacticRAVE avatar
LRGB: extended full-well 2cms, gain 0, offset 52
narrowband: 2CMS-1, gain 56, offset 52
Christian Koll avatar
High Gain Mode, Gain 56, Offset 50 for everything. using a refractor f/5.6 and also Antlia LRGB and 3.5nm NB filters.
Chris
Greg McCall avatar
Mode 5, gain 56, offset 40 for all images. Mostly bin 1x1
i originally used no offset and then a small offset but was wondering why I got black speckles in the stacked image.
after some research, I learned what it could be so picked a bigger offset.
40 seemed reasonable but it will be interesting to see what others get
Paul O’Brien avatar
I image everything at f/7.0 using Astrodon LRGB and 3nm Ha filters along with Antlia 3nm OIII and SII filters.  Exposures range from 60-120 sec for LRGB and 300-600 sec for NB.  All unguided.
Thank you so much all, much appreciated.
any thought about binning to get a more acceptable pixel scale ? I am down to 0.51"/pixel with the 16 inch newtonian, so 1"/pixel would be a little better in my estimation. Also, the enormous file size of 1x1 binning will NOT be missed :-D
Paul O’Brien avatar
I've thought about it but have not pulled the trigger so far.  My pixel scale is around .76", which is not ideal for my skies but manageable.  The biggest factor to do it would be the file size issue, as you pointed out.  Full scale pre-processing of nebula can take a long time even with my new fast desktop so I'm now cropping everything to the extent possible before running WBPP, which has helped my processing times.  Still, those smaller file size using binning would be awfully nice to have.  smile
Well Written Insightful Respectful Concise Engaging
Paul O’Brien:
I did a pretty substantial project involving M33, I ended up with 97GB in WBPP !!!!!!..  my 14700K powered desktop took over 2 hours to run WBPP
Paul O’Brien avatar
Paul O’Brien:
I know what you mean!  Been there, done that.  I did a big project and had almost 100GB and it took a while to run.
Shannon Foye avatar
Camera is a QHY268M
Narrowband
   - High Gain Mode
   - Gain 56
   - Offset 25
   - USB Limit 25
   - Minimum ADU of bias sub exposures range from 250 to 280
Broadband
   - High Gain Mode
   - Gain 0
   - Offset 25
​​​​​​​   - USB Limit 25
   - Minimum ADU of bias sub exposures range from 260 to  290
Shannon Foye:
Camera is a QHY268M
Narrowband
   - High Gain Mode
   - Gain 56
   - Offset 25
   - USB Limit 25
Broadband
   - High Gain Mode
   - Gain 0
   - Offset 25
  - USB Limit 25
Thanks
alistairmac avatar
The setting I use are -
QHY600
BB mode 3, Gain 0, offset 30
NB mode 1, Gain 56, offset 30
QHY268
BB mode 4, Gain 0, offset 50
NB mode 5, Gain 56, offset 50
QHY600
QHY268
thanks. Mind sharing the exposure length as well ?
Kevin Morefield avatar
Mode 3, Gain 25, Offset 20.  I use that for all filters.
F3 DeltaRho: 120 Luminance, 300 RGB, 600 NB
F3 FSQ106: 300 LRGB, 600 NB
John Hayes avatar
Kevin Morefield:
Same here Kevin!
Kevin Morefield:
Thanks Kevin
John Hayes:
Kevin Morefield:
Same here Kevin!
Thanks John
John Hayes:
Kevin Morefield:
Same here Kevin!
Well I stole it from you!
John Hayes avatar
Kevin Morefield:
John Hayes:
Kevin Morefield:
Same here Kevin!
Hahaha!  Right...good move.
Gain settings
Hello! What gain and offset settings do you use in your cameras? Are these settings analogous to those in the ASI 2600? I ran a test in Sharpcap - sensor analysis - and the result showed that the unity gain should be 300.
Gain settings — Hello!What gain and offset settings do you use in your cameras? Are these settings analogous to those in the ASI 2600?I ran a test in Sharpcap - senso
Aug 31, 2025
Gain/Offset settings
Hi all, Thank you very much for posting your images from this brand of cameras, i appreciate it, and i hope i can get images with mine too, and see more and more images posted here. So, what is the settings as Gain and Offset you settled on so far? A...
Poll about gain and offset settings across different camera modes.
Jan 21, 2023
Gain settings for the QHY 168C
Hello Just wondering what gain and offset you use with your qhy 168c. I currently use gain 10 offset 50 from my bottle 6 UK back garden. Thanks for reading.
Directly addresses gain and offset settings across different camera models.
Mar 20, 2023
