ASIAIR+ has gone crazy
Ferran Bosch (S.A.C.)allen456Johannes Maximilian MösleinTony Gondola
30 replies1k views
Ferran Bosch (S.A.C.) avatar
Hi all, this afternoon it seemed that the clouds had gone and I have mounted the equipment, when I started with the autoguiding there came a moment when the stars deviated a couple of seconds, as if the mount stopped tracking and then abruptly returned to its position, I changed the cables, I installed the latest firmware and it did not work either, finally I removed this asiair+ and I put the mini, also updated with the latest firmware, and voila, everything worked correctly. Has anyone suffered this problem? it happened to me once with the mini, but it was fixed mysteriously, I don't know what to think anymore. Thanks for reading me.
Ferran.
Fred B avatar
I had something similar happen to me a while back.  Recalibrating the guiding solved the problem.  I believe I tapped on the icon with the 2 perpendicular lines that represents guiding.  It then allows you to "clear" or "recalibrate".  The asiair then does a new calibration of the guiding and that should solve the problem.  I'm sorry I can't remember exactly how to do it as it has been a year or more ago.  If you google it I'm sure there will be some directions.  Hope that helps.
Jon Bryan avatar
I started getting spikes in my guiding not too long ago, and when I watched the guiding screen noticed that one of the guide stars the ASIAir had picked was very close to another bright star, and the box was jumping back and forth between them. I restarted the guiding and manually selected a star, and it started behaving.
Jim Case avatar
I clear the guiding and recalibrate each night on my ASiair which has been recommended. Sometimes the guiding goes crazy during a session and recalibrating guiding can sometimes fix the problem as well.  I believe there are more advanced tools in the full version of the software that the ASIAIR uses for guiding that might be useful but are not available unless you use a laptop and the full version of the software.
Glenn Bargabus avatar
I had a similar issue. I started by shutting down and disconnecting the power. Then I powered the ASIAIR back up and that fixed it.
Well Written Concise
Stephen Jones avatar
When this occurs I clear the guiding also.  I use the dark library for guiding which works well.
Thanks to all, reading your comments I remembered that the last time it happened to me, it was because asiair chose a double star and went crazy jumping, curiously the drift has the same duration as the exposure time of the guiding camera, it is as if during the exposure the tracking was stopped.
Thank you for your advice
Ferran
allen456 avatar
Has anybody experienced an issue where the guiding graph looks good but the stars move slowly but steadily from left to right.  This is with ASIAir+.
Al
Al
No, it is a very strange thing
This could be differential flexure
allen456 avatar
Tony Gondola (Gondola)
Don't really know what that means.
If there is any movement between the imaging scope and the guide scope during an exposure you will get star elongation or trailing even if the guiding is perfect. There doesn't have to be much mechanical flexure to throw things off by a few seconds of arc and thus be noticeable in your image. The main and guide scope have to be very solidly coupled to prevent this.
Well Written Helpful Concise
allen456 avatar
OK I understand you now, but I can assure you this was not the case this time.  It has been going on for over a week and ensure there was no flexure was one of the first things I checked.
Al
Johannes Maximilian Möslein avatar
How is your power input? Every device powered on its own? The AIR often behaves very funky if the input voltage/amp is to low.
I don't think so, it's a rhythmic movement, it's as if the mount suddenly stops and starts again
Johannes Maximilian Möslein:
220v/3Amp
It's not that, next time it happens I'll record a video, it's a rhythmic movement, synchronized with the exposure time of the guide camera, for example, if it is making 2" exposures, the mount stops guiding for two seconds and then returns to the star, rhythmic and constant.
Daniele Borsari avatar
Are you sure your polar alignment was good?
Ferran Bosch (S.A.C.):
220v/3Amp
But what was the DC input? Should be around 12V/2-5A. Did you check it in the AIR while it was running?
Did you try different USB cables? Those are often the culprit.
You mean it completely stops tracking? Like it stops moving, then the guide exposure comes in, it corrects back, and stops moving completely again?
Daniele Borsari:
Totally
Yes, sorry, 12.7 volts and 3 amps.
Exactly, that's what happens, if you look at the tracking screen, the stars walk away and after a moment they return to the starting point, it's amazing, I changed the cables and everything remained the same, I changed the unit for another one and it worked correctly. It is a mystery.
I'm not sure if I understand that, how can you see the stars "walk away at the tracking screen", if you only see the subs from the guide cam? What's your guiding equipment?
How, if you open the guidance screen, you see the stars that the guidance camera is capturing, those stars move away and come back, move away and come back, in 2” intervals. I'm talking about the guide stars. I refer to this screen (taken from the internet):
That looks like a pretty normal guide graph to me.
Opps!
Nexstar hand controller firmware update failed, display showing odd squares
trying to update firmware on nexstar hand controller, every time i try it says update unsuccessful, tried resetting and but didn’t work, then tried use newest cfm but that didnt work, contact celestron support but they are having holiday party today ...
Firmware update troubleshooting relevant to mount control system issues.
Dec 5, 2025
ASIAIR Mini and ASI2600MC exposure failures despite troubleshooting attempts
Hello, I have been using the ASIAIR Mini coupled with the ASI2600MC camera. My current set-up has been working flawlessly for a long while. Last night I had a little initial trouble with the start-up, the camera advised an exposure failure while I wa...
ASIAIR Mini troubleshooting directly matches author's equipment and problem.
Oct 11, 2025
2600MC Pro disconnection issues
Hi all, Having an issue with disconnects every since getting a new 2600MC Pro. I am using an ASIAIR Plus and have had over a year of use with a DSLR without this issue ever occurring. This my 3rd night of using a new 2600MCP and on each night have ha...
ASIAIR Plus disconnection issues similar to author's tracking problem.
Nov 25, 2025
What do you do when PHD2 sees ghosts?
I have been chasing a problem in my guiding for several hours yesterday night and tonight. I use an OAG with a SCT (C8); PHD2 (managed by NINA) is the brain. The experienced problem was that, for a specific target, guiding would work well “in most ca...
Autoguiding problems with tracking deviations similar to author's experience.
