Menelaos avatar
Hi guys! I’m looking for a good reliable focuser to upgrade my SW150explorer. Ideally I want it to have 2 things, rack and pinion, and ball bearings. However i cant seem to find one that has both. Most of them are just regular crayford (no rack an pinion). And it was actually suggested to me to get this one https://www.astroshop.eu/focusers/omegon-steeltrail-2-newtonian-dual-speed-crayford-focuser/p,45073  is there a reason not to get it?
of course i plan to use it for astrophotography and currently i have a decently heavy setup an ASI2600mcpro with a filter drawer and off axis guider but maybe i would upgrade in the future to mono and filterwheel. Any ideas?
I don't see why you shouldn't.
I like the low profile, it should handle the load but is it EAF compatible?
Michael Nemetz avatar
Get a Baader Steeltrack Diamond NT.
Maarten Broess avatar
How about a Moonlite focuser. I love mine. Exchanged the focuser on my SW MN190 for a Moonlite. https://focuser.com/
MaksPower avatar
I have this focuser on one of my scopes, it’s pretty good and it will take an EAF.
Stephen Jones avatar
You might want to look at the RAP2DEL and adapter from Teleskop service.  It allows you to keep the SW base of the focuser (no drilling).  Email them for details if it also suitable.  I use it on my SW 250PDS with a 2600, FW and Paracorr etc without a drama.  Similar to the one in the link.  I have only just started to use it.
Concise Supportive
Peter Graf avatar
Last year I also wanted to switch to a rack and pinion focuser for my 150PDS. I remember that this was quite frustrating though, as many of the focusers seem to be only fitting for 8" (like 200P) scopes and above - what is not obvious in most of the descriptions. Also the customer support of one of the shops here in Germany was not 100% sure which one would be fitting for 6" scopes. And support for the ZWO EAF was also needed. For the time being, I am therefore using the default focuser.
So I will follow this thread closely. :-)
Helpful Concise Engaging
Tomasz Kaminski avatar
For this telescope with the ASI2600MC PRO I decided to use the CYCK focuser, praised by Cuiv in one of his videos. It's rack and pinion,  worse than the one proposed, but cheaper and much better than the factory-fitted one. It has some pros and cons, but it is fully compatible with most popular autofocusers and fits the SW focuser base. I was more interested in stiffening the telescope tube around the focuser.The sheet metal here is soft and bends under the weight of the attached devices, causing the camera to tilt. The device works perfectly with my autofocus controller (AstroLink) and both images uploaded to Astrobin show that it was a good choice.
Advice on Coma Corrector and reducer
Hey I have a Skywatcher 200DPS f/5 8” newtonian and are looking to add a Coma corrector to my setup. I have the default focuser that came with the Telescope and currently imaging with an EOS 50D - which will soon be replaced with an ASI2600. Any sugg...
Relevant — addresses focuser upgrades for Newtonian telescopes
May 7, 2023
Roller bearing and grease advice
Hello everyone, I am in the process of tuning my Explore Scientific Exos 2 mount with the hope of improving the guiding enough so that I can switch my Samyang 135F2 for my Sharpstar 76 EDPH which has considerably more reach ( 342mm ) and weights a bi...
Discusses bearing upgrades for telescope mounts, directly relevant to roller bearing replacement.
Feb 9, 2023
Esprit 120 Slippage / Sesto Senso 2
Hey Guys, some time ago I was quite astonished to hear that there are tak toa users that support their focusers with rubber bands to get rid of slippage. First time hearing that people support their premium scopes with rubber bands I thought, that ca...
Discusses focuser issues including slippage problems relevant to focuser selection.
Jan 19, 2026
