This is such an apt reply and perhaps I will get some ideas / suggestions.
I own a Sony Full Frame camera and a 70-200mm F2.8. Took multiple 2 secs exposures to get my first Andromeda shot.
Dug in several YouTube videos and webpages, and decided to get myself a Sky-Watcher GTi.
My question is if this is a good mount or should I get a bit more advanced mount - which one?
Also, which scope can / should I go for?
Thanks a lot.
I own the SA GTI as well as an EQ5 Pro and two EQ6(R) Pros. I think, the answer to your question is always quite difficult. It depends on you, your interests and your ambition to go deeper into this stuff.
All three mount types basically work the same. They all can do what I want and there is no huge difference in the basic functionality. However, they have three different goals in mind and with an increasing price, they handle different scopes in different ways. That's where you have to decide yourself.
The basic advice always is, If you try to do astro photography seriously, to spent as much money on the mount as possible. You typically get what you pay for and if you want to be future proof, you have to think this way. The mount was always my weekest part and now I know. There is no cheap solution if you want to get good quality images. But we can make some differences for you.
If you like to stay with your Sony cam and the 70-200 then buy a StarAdventurer GTI or similar. The GTI is nice, because it is motorized in both the RA and the DEC axis. This is very helpful and allows you to do all the real stuff in astro photography. I bought an Omegon 61/335mm APO Triplet telescope for this mount and it works well. But with filter wheel, camera, focuser etc. it might reach the limit of what the mount can handle for my taste. So an upgrade to a bigger scope is not recommended.
If you want to get bigger, you can buy an EQ5 like mount. Even better is the HEQ5 version. It can handle more payload and carries some slightly bigger scopes. My guiding is better with it, although it's not perfect. It took me quite a while to handle it well. The reason is the mechanics. But once it worked, I never had issues. It turned out, that I use this mount exclusively with my 71/350mm Quatruplet APO fully equipped with rotator, focuser, filter wheel, camera and so forth.
If you are really ambitious, then I would recommend something in the EQ6 class. These mounts can handle a lot of payload (usually 20kg) and you are quite future proof. These mounts work really well. You might look for harmonic drives like the AM5 or at least for belt driven ones. But they all are quite expensive. Quality has its price.
I don't want to recommend specific models. But everywhere you look, it seems that getting a class up in quality you have to double your expenses. The EQ6s are all i can afford at the moment. But they are really worth it.
Basically, I've given three advices. You have to decide for yourself in which category you want to place yourself. I know there is a lot of other stuff you will need. But most of us are sure the mount has the most impact on image quality. If you want to know which is the best mount, you may have to find some reviews and compare them yourself. I exclusively use Skywatcher mounts and they work for me. But I am sure, other mounts might work as good as mine.
Hope this helps...
Christian
