KIJJA JEARWATTANAKANOK avatar
This is my first post to the group. I would like to ask for constructive comments for my image. Or, just what do you feel when you look at this image will be helpful.
Clear skies,
Kijja
Cocoon Nebula, IC5146, LHaRGB
Brandon Tackett avatar
Wonderful image Kijja. Your star field and stars are great as well as you dark nebulosity. I am by no means an expert, but at full screen resolution without pixel peeping at full resolution I noticed two small things to work toward. 1) The white/lighter nebulosity is quite noisy especially the RGB component. I have have struggle with this in trying to bring out faint nebula or the IFN around M81. If you can use the GAME script in pixinight or selection tool in photo shop to select this area and subtly denoise using the chrominance layer it would clear it up. 2) The very of the cocoon could use a little more sharpening to bring out subtle detail. Again this would probably require more nuanced masking per above. Keep up the strong work and I enjoyed looking through your gallery of fantastic images! Clears Skies! -Brandon
Helpful Respectful Supportive
Hi Brandon,
Thank you very much  Your comment is very helpful.
C.S. Kijja
WBPP not giving me my total integration time or subs used for my file, when splitting my DSLR OSC data into RGB channels to integrate
Question for any long time Pixinsight users. I've been using the app for a few months now. I have not been doing my initial stacking in WBPP, I use Siril. One reason for this is I don't guide, I have an older LX200 mount that PHD2 just can...
NONE
Sep 1, 2023
[RCC] NGC 7023 - The Iris nebula
This is my first topic on the forum I'm kindly asking about constructive critique of my Iris nebula. Frames acquired from Poland, Bortle 5, maybe Bortle 4 around this sky area (lower LP). Nearly 14 hours, L: 7 hours and RGB: 6 hours. Camera: ASI ...
1: Both authors seek constructive critique on deep-sky nebula astrophotography images.
Jul 19, 2023
Should I Upgrade My Original Sky-Watcher Star Adventurer to a Sky-Watcher Star Adventurer GTi
Hi all, I am debating whether to just upgrade from my original Sky-Watcher Star Adventurer to the Star Adventurer GTi. I did post something on here a while ago asking what you guys think I should consider for my next mount purchase, but I still haven...
NONE
Feb 16, 2023
