ASIAIR GoTo and Plate Solving near NCP
1 reply137 views
Frank Lothar Unger avatar
Hi folks,
these days I tried to capture NGC2276, near the northern celestial pole.
ASIAIR worked fine for PA and all other routines but failed to center NGC2276. Theplate solving ended after 1 second and no failure was mentioned.
The only problem was that NGC 2276 was nearly half of the frame off.
I corrected framing manually and the sequence run perfect until clouds came up. After a while the sky cleared up and obviousley ASIAIR recentered the frame to the FOV before my manually corrected FOV, all following frames were trash :-(.
Now my question, has nayone had similar issues?
Thanks in advance and CS
Frank
Oscar H. avatar
well I had issues with the NCP, with some similarity:
I tried to Goto Polaris, but I was always slewing to a place near it (the NCP I guess?) and never centering the actual star; I had to manually center it through the app
then I tried to calibrate guiding, but that wasn't working; star wasn't moving enough; I had to change the Calibration Step (I think it was that) to a longer duration
then when guiding calibration was complete, I tried guiding, and the guiding was horrible, so I gave up on Polaris
you might ask why I wanted guiding, well, I guess my PA was bad (which doesn't make sense, because my PAs are always under an arc minute in either axis); my mount was perpetually drifting one way and so if I just stuck to tracking, then the target would go out of FOV within a half hour probably
Plate Solving Failure
Hi! I've had no problem plate-solving with the ASIAIR Plus using an Esprit 100 refractor, an AM5 mount and an asi2600mc camera. My autoguiding is consistently around .2" to .5" on both RA and DEC axis. Tonight I tried for the first time...
ASIAIR plate solving issues near celestial pole similar to author's problem.
Jan 24, 2023
Rotation shift after meridian flip (no electronic rotator)
Hello, I recently noticed that during my last two sessions of shooting that I experienced a shift in the field rotation after the meridian flip. All images taken before the meridian flip are same orientation and matches with framing assistant, and al...
ASIAIR plate solving and framing issues similar to your centering problem.
Oct 28, 2025
