Comet processing - TIFF files
3 replies118 views
Arun H avatar
Hello,
I have a series of comet files that I would like to process, taken in CR3 Raw format. To avoid too much trouble calibrating, I applied profile corrections in Adobe Lightroom and converted to TIFF. However, PI's comet alignment routine does not accept these files as it seems to be looking for the Date and observation time header in FITS format. Is there a way around this? I realize I can start with RAW files (which I did for other comets in the past), but that would require me to calibrate at a minimum with flats to correct the vignetting.
You can always insert the time stamp in the files once converted into fits format. I appreciate it might be cumbersome for large numbers of files.
Well Written Concise
Arun H avatar
Thanks, Andrea. I knew that was an option. I have 60 files though. Probably easier to go the raw route.
Rob Kiefer avatar
There is a script "BatchFITSKeywordEdit" from Mike Cranfield. I have not used it, so I cannot tell you if this will work for your files. But maybe you can have a look.
Rob
RAW/FITS Compatibility Issues with ASIAIR
Hi folks: I've just switched from Astroberry to ASIAIR for image acquisition. I use a Canon 600D/T3i, and previously all downloaded images were saved in RAW (CR2) format. I have an extensive darks library all saved in RAW format. When I stack, As...
Addresses RAW format processing and calibration workflow considerations.
Mar 27, 2023
Comet Lemmon Data Up for Review – Banding / Pixelation Issue
I’m returning to DSO astrophotography after nearly eight years away, and needless to say, my PixInsight skills needed quite a bit of refreshing. I’m using the same setup as before, but I’ve switched to a Sony A7 IV DSLR for imaging because of its ver...
Discusses comet data processing and PixInsight alignment issues similar to author's problem.
Oct 14, 2025
