Strange blue bands on images...
11 replies287 views
Harry Karamitsos avatar
Hi everyone,  I installed a used QHY600 M pro (early bird) in my skywatcher 150 esprit. I have been using Baader narrow band filters and have noticed these blue wide vertical bands on my images.
I use the .77 reducer/flattener for the Esprit.  I previously had ASI2600 MM w/o any problems. Can anyone figure out what is causing it?
This is a partially stretched image...  See the 3 blue bands...
Oscar H. avatar
try the CanonBandingReduction script on your OIII image
I'm guessing the root cause probably has something to with calibration
I tried cannonbandingreduction but it looks for horizontal bands and I don't see a setting to change it. I tried a number of flats with no avail…
Oscar H. avatar
Harry Karamitsos:
I tried cannonbandingreduction but it looks for horizontal bands and I don't see a setting to change it. I tried a number of flats with no avail...
just rotate the image 90 degrees right or left
starpixels avatar
Could it be rolling shutter artifacts from an LCD / Flats panel?  …Possibly if your QHY has different flat exposure time requirements than your previous camera? If it were me and I also suspected the sensor, I'd stretch the flats to check that as well. In that case the cancellation might not be happening because of a pedestal value, darks, etc..
Maybe, I’ll work on that tonight
Sean Jackson avatar
I don't know if this is relevant, but I once had trouble with faint horizontal bands with this camera.
When I adjusted the offset they went away.
The manual says:
https://www.qhyccd.com/astronomical-camera-qhy600/
OFFSET SettingThere is no fixed “best value” for OFFSET. To set OFFSET, you should take the bias frame and dark frame at a certain GAIN value, then checkthe histogram of the frames.The histogram distribution is a peak-like curve. While changing the OFFSET value, the histogram will move left or right. We need toguarantee the range of the whole curve won’t be chopped off at the end. At the same time, we need to keep a little residue on the left side,just over 0 a bit.Pay attention that under different GAIN values, the width of this peak varies. The higher the GAIN is, the
I have been using 56 for the gain and 50 for the offset.
Sean Jackson avatar
An offset of 50 for a gain of 56 sounds good. So I’m sorry, my idea was a red herring! Sorry to waste your time.
Well written Respectful
It’s never a waste, come on! The whole point of this is to share ideas and I thank you for yours.
Tim Ray avatar
I have had similar issues with a ZWO 533mcPro.  All came down to me capturing subs at a different offset than I had used to create a masterdark for that sub length.  In the end I created a new MasterDark with the settings the Lights, Flats and Flat-Darks used at capture.
CS Tim
I’ll give that a try too.
Help - Vertical bands - Flats is the culprit - Can someone help me understand what's happening ?
Hi, Recently I am noticing some weird band like structures in my images. My setup - QHY600PH-M + Takahashi Epsilon 180ED + Astronomik Filters. I Captured RGB images in QHY 2CMS-1 Readout mode at 56 gain for broadband images. (mistake) After noticing ...
Vertical bands in images; similar camera and filter setup troubleshooting.
Nov 23, 2025
Over correcting flats with fix
Howdy all. I've been rather bummed with the quality of my images for the last 9 months. I have data collected for two projects that I never finished due to the poor quality. Recently I discovered that my flats were over correcting my LRGB images ...
Flat correction issues causing artifacts; relevant to band problem diagnosis.
Aug 17, 2025
Weird Artifacts when shooting with SCT
Hi, I’ve noticed I get a weird border artifacts on all sides of the picture when shooting with my SCT. I did not have this problem when I use the same camera/filter on a refractor. Anyone know what is causing this and how to fix it? I’ve shot multipl...
Border artifacts with different telescope; similar optical system artifact investigation.
Sep 22, 2025
Dark vertical streaks in stacked image
I've been struggling with trying to understand the source of these streaks I see in some recent stacked images. I'm hoping someone here can offer an idea as to what the source is. I'm hoping it's not the camera itself. My set up is a ...
Vertical streaks in stacked images; directly similar symptom and troubleshooting.
Aug 21, 2025
