ASIAir mini 12V output ports
4 replies197 views
David Ebbecke avatar
Hello, I just acquired the ASIAir mini for a second rig and can't figure out how to switch on the 2 output ports.  The options aren't there when I hit the wifi icon on the app.  I'm looking to power my dew heater.  No issues with my ASIAir Plus.   Any help would much appreciated!
Joshua avatar
Here is the AI answer:
It sounds like you're having trouble accessing the power output controls on your ASIAir Mini. Here are a few steps you can try: 1. Update Firmware and App: Make sure your ASIAir Mini has the latest firmware, and that your ASIAir app is also up-to-date. Sometimes features might not appear if there’s a mismatch between the app and device firmware.  2. Check Power Management Settings: In the ASIAir app, after connecting to your ASIAir Mini, look for the "Power" tab or power management section. It should show the power ports if they are supported by the ASIAir Mini. Since your ASIAir Plus shows them, the Mini might have a different layout or interface.  3. Restart the Device: Try restarting both the ASIAir Mini and the app, ensuring that your device is properly connected via Wi-Fi.  4. Check Device Compatibility: It's worth confirming that the ASIAir Mini supports powering external devices like dew heaters. While the ASIAir Plus supports multiple powered devices, the Mini might have limitations.   If none of this resolves the issue, checking with ZWO support or online forums dedicated to ASIAir users might help, as there may be model-specific nuances.
I like option 4. I say this because I thought all ports are full on/open by default. If they are on and unable to supply the power, it may be the cause.
Jorg Haschke avatar
There is no switch on the mini. They are powered all the time
Jim Bishop avatar
David Ebbecke:
I use an ASIAIR mini and as far as I can tell, there are no controls for any of the outputs. They are on by default. It is one reason I want to go to a "better" version. Have you tried just plugging it in?
Duh, I didn't even consider the possibility that the ports deliver power when the mini is on.  I was going solely on my experience with the ASIAir +.  Thanks everyone for your help!
2600MC Pro disconnection issues
Hi all, Having an issue with disconnects every since getting a new 2600MC Pro. I am using an ASIAIR Plus and have had over a year of use with a DSLR without this issue ever occurring. This my 3rd night of using a new 2600MCP and on each night have ha...
ASIAir Plus user with different device; may have relevant troubleshooting insights.
Nov 25, 2025
ASIAIR Mini and ASI2600MC exposure failures despite troubleshooting attempts
Hello, I have been using the ASIAIR Mini coupled with the ASI2600MC camera. My current set-up has been working flawlessly for a long while. Last night I had a little initial trouble with the start-up, the camera advised an exposure failure while I wa...
Same ASIAir Mini model; may contain relevant setup or troubleshooting information.
Oct 11, 2025
ASIAIR Mini Amp Problem
Hello, I'm having trouble with my ASIAIR Mini concerning power supply, especially Amps. Recently it's behaving very strange, and the internal measurements show 12V, but only 0.1A. After seeing that, I tried multiple PSUs (2 official ZWO 12V5A...
ASIAir Mini power/amp issues; potentially related to output port problems.
Aug 20, 2025
Power solution for AM5N + ASI533MM Astro rig
Hey guys! I have the ZWO AM5N, ASI533 MM Pro, ASIAIR Plus, 120mm Mini, and dew heater for the Carbonstar 150mm reflector. Is the Bluetti AC70 (1000W and 768Wh) capable to power this setup comfortably? What other batteries do you guys suggest for a se...
Dew heater power setup with ASIAir Plus; relevant power configuration example.
Jan 4, 2026
