Help me decide what scope to buy
VAnderlGTomScottFRobert Žibreg
36 replies797 views
Anderl avatar
Hello fellow astro friends,
there was recently a thread that showed that most of the people here on astrobin own way more than only one scope smile
i am planing to get a second one for quite some time now but i just can’t decide what instrument would best fit me and my situation.
rn i am using an esprit 120 at native focal length and with the 0.77 reducer together with an imx571 camera.
There are really quite a few setups i already thought about.
1. a second esprit 120. this would double my exposure time and allow me to get deeper pictures with and without the 0.77 reducer
2. either an 10 or 12 inch ontc/lacerta newton for small stuff and my esprit with the 0.77 reducer and a full frame chip to be able to get a big field.
3. selling the esprit and get 2 8 inch newtonians to get signal fast.
4. selling the esprit and getting an toa 130 for small stuff and an epsilon 130 for wide field imaging.
My budget is around 15k, i want 2 setups, my sky is around bortle 3 and my seeing is average Bavarian seeing, i am imaging in my backyard without an observatory and as i like being under the stars things should stay that way.
I know there is no right answer to this but i am interested in what you guys would do.
cs
andi
Robert Žibreg avatar
What focal length are you aiming for? Right now you are at 840/646, is that fine for you or would you like to go for more/less?
Anderl avatar
Robert Žibreg:
I like the focal length. I think around 800 to 1000mm focal length is very versatile. I could maybe gain more resolution until around 1200mm but any more than that? Doubt it
If you like that focal length get another Esprit 120, they are good scopes (that's what I would do). If you want more versatility and be able to hit 1000-1200mm get a quality refractor, something like APM LZOS 150mm @ 1200mm, with reducer that's 900mm (or something a bit smaller, they have range), but they are not cheap.
Concise
David Foust avatar
I would go for something with a longer FL so you've got more tools to chase those smaller objects.
I've been quite pleased with my Orion Optics Ideal 8 newt at 900mm. Holds collimation very well even though I take it in and out every night, and the aluminum tube is lightweight at 15 lbs (lighter than steel tubes at 21lbs or so) and cools quickly. I got some custom carbon fiber rings and Losmandy dovetail from Rouz Astro as well which have been great. Given this is close to your current FL, I have to imagine the OOUK Ideal 10 at 1200mm would perform similarly well (it's also only 25lbs instead of 37 lbs!) or the Ideal 12 or 14 (at 1200mm/30lbs and 1600mm/44lbs, respectively) could be a nice choice for smaller targets. They also have their AG top of the line astrographs that I'd assume perform quite well, though I have no experience with them.
If you did a dual setup, would it be on one mount or two separate mounts? I've seen lots of folks do dual 6" newts, (especially the Sharpstar carbon newts or the Apertura CarbonStar come to mind) but you've already got a scope around that FL, so you might as well get a second Esprit.
I'm jealous. I'd love a dual setup someday… But today is not that day 😂 Good luck with your decision!
I've got FRA500 and I'll probably get another one for dual integration time, since I'm fine with this focal length. It all depends on what you want to image really.
Anderl avatar
David Foust:
I'm jealous. I'd love a dual setup someday... But today is not that day 😂 Good luck with your decision!
I will buy a second mount ;)
ahh, it is just so hard to decide. A 10 or 12 inch newton with a focal length a bit longer would be nice. Maybe i just need 3 setups
Rick Krejci avatar
I find a 10" f4 newt with coma corrector gives me good resolution on smaller objects and with a 2.5x barlow is good for planets with a 2um pixel camera (5x rule).   I just have the 250 quattro, which I'm quite happy with.   You can go higher end with carbon fiber and better focusers and more optimized if you want.    It's also not too heavy to heft up on the mount.  You can go f5 if you want a little more focal length.  Mine holds collimation very well despite being a non-observatory setup
I also have a widefield small refractor (FF65) in the 300(reduced)-400mm focal length range for those wider fields.
Just a few options.
Rick
V avatar
Anderl:
cs
andi
With a budget of 15,000, I'd say personally, EdgeHD 11 with hyperstar and an F/7 reducer, and forego the double setup.
It'll do everything you want to do without having to maintain two seperate systems (Plus F/2 in bortle 3 is madness).
Honestly your EQ6R could probably handle the 11, but if you're worried about that, get a CQ350. For guiding, I'd get an 740, 800 or even 850 IR pass filter and a camera sensitive to IR inside an OAG, It'll defeat the seeing, and allow you to guide very well on the big scope.
Plus it means you can take advantage of the EdgeHD sale that's on right now.
It is a big scope, but to be honest they aren't THAT heavy.
GTom avatar
The Newtonians with a 2" coma corrector will be vignetting severely on the APSc sensor. If you want speed, check C11 Hyperstar or RASA 11. The C11 could do double use with the moderate f/6.3 reducer from Starizona (highly recommended reducer, best stuff you can get for an SCT).
tjm8874 avatar
Anderl:
Go big, TOA 150,  your telescope of a lifetime. Keep Esprit 120.
V avatar
At that price point, assuming going for a refractor, I'd rather just get an Askar 203, and a 6200mm setup for it. Takahashi prices reflect quality really well, but I don't see any point in buying a substantially smaller refractor for nearly double the price for performance that is nearly completely negligible in practice.
Honestly after giving it some thought, with this kind of budget, you could in theory get a CQ350, C14HD, and all the fixins and enjoy a huge range of capabilities, albeit it is going to be substantially heavier.
That's why I suggested C11HD instead initially.
Helpful Insightful
GTom avatar
The EdgeHD makes very little use for photography, people use STC's with reducer-corrector anyway.
The 8" Askar is a substantial scope. If any mobility is involved, that and the corresponding mount is definitely going to be a struggleware. On a permanent pier, by all means!
Alex Nicholas avatar
If I had that sort of money to spend….
I currently have a 65PHQ at 420mm focal length, and the Askar 120APO at 840mm.
I would sell my 65PHQ, and replace it with a sharpstar 150mm f/2.8 newtonian (giving me 420mm focal length… just 10x faster than the 65PHQ)
I would keep my 120APO, as the 840mm focal length is quite useful for lots of targets, and its a magnificent performer.
I would take the rest and put it into something like a 10" RC with a camera that has a little larger pixels. Something like the 6200MM Pro, but run it at bin 2 giving 15mp, and 7.52um pixels
This would depend on your mount/mounts I guess… a 10" RC would be much easier to manage than an 8" APO I can guarantee you that, it will pull in FAR more light, have much higher theoretical resolution, and on those few nights of really pristine seeing, you can run the camera bin 1 and take advantage of the amazing resolution that 3.76um pixels at 2000mm focal length provides.
That would be my thoughts…
Get something FAST and wide.
Keep your esprit 120, and maybe ditch the .77 reducer - so its basically double the focal length of your widest scope.
Get a 10" RC which will be about double the focal length (give or take 20%) of the Esprit 120.
Then you're covered for really large targets, right the way through to imaging tiny planetary nebulae and distant galaxies…
V avatar
I respectfully have to disagree with the first half.
EdgeHD is the most popular photographic system on Astrobin by photo and user volume (over 28,000 images total on Astrobin, and over 1900 users- not including the normal XLT and RASA systems).
With the ability to image at or above F/10 (11 on the 14), F/7,  F1.9-2.2 (depending on the type), and soon F/4, EdgeHD is a very good choice for imaging. That's why I use one.
Normal SCT's with the reducer-corrector, while decent for astrophotography use, cannot match the quality of field produced by the EdgeHD consistently.
Now, granted it doesn't come without it's problems, my biggest complaint being that the EdgeHD 8 can't fully illuminate my Full Frame sensor, forcing me into a different design, or a larger EdgeHD. (Not that I could afford either, thank you college.)
Now, I do agree that the 8" Askar can be a pain in the glass if mobility is concerned, but shooting from a backyard is a little less demanding then say, loading up your truck and driving to a dark site, so theres a bit more setup time, and leisure can be taken to make sure you don't obliterate your knees or back when powerlifting the big hunk'o'glass.
The CQ350 I recommend for that payload weight class is a big, bulky mount too, so it's a good thing you pointed that out. I think we need more mounts in that payload class, because theres really only a few to consider, and they all have massive pros, and some pretty gnarly cons too (Get your game on Celestron, make a strain-wave mount already!).
V avatar
Alex Nicholas:
If I had that sort of money to spend....
I would sell my 65PHQ, and replace it with a sharpstar 150mm f/2.8 newtonian (giving me 420mm focal length... just 10x faster than the 65PHQ)
This would depend on your mount/mounts I guess... a 10" RC would be much easier to manage than an 8" APO I can guarantee you that, it will pull in FAR more light, have much higher theoretical resolution, and on those few nights of really pristine seeing, you can run the camera bin 1 and take advantage of the amazing resolution that 3.76um pixels at 2000mm focal length provides.
That would be my thoughts...
Then you're covered for really large targets, right the way through to imaging tiny planetary nebulae and distant galaxies...
I actually see some merit to the 10RC, but the 8" APO is actually going to have a higher practical resolution and collecting area thanks to it being a straight-through design, The 10RC has a 47% obstruction afterall, which put in effect, actually gives the 8" APO ~26% better light gathering capability vs a 10RC.
But the 10RC will definitely be much more maneuverable (physically), and likely substantially better in terms of the observable optical performance on a full frame chip (nothing against Askar on this, but not releasing spot sizes for your flagship is iffy in my book.)
I threw the Askar 203 in the air due to the budget and the mentioning of the TOA150.
As I'd rather not spend that kind of money on a refractor, as before, yet again I'll suggest the venerable EdgeHD 11.
Helpful Insightful Engaging
GTom avatar
FYI: standard sct-s with the Starizona 0.63x CONSISTENTLY beat the EdgeHD with the Celestron 0.7x.
V avatar
I'd need to see spot data, but I do believe it, the 0.7x on the EdgeHD was designed decades ago, and hasnt seen much of an update. Thats why I don't use mine.
ScottF avatar
I'd never let that 120 go if I were you , and I'd only consider a dual setup once you have a more versatile array of scopes. I'd get something long, the SCA260 mm by sharpstar comes to mind at 1300mm and f5.
GTom avatar
It's also a stacked system eventually: the "Edge" optics is simply a corrector group installed inside the baffle tube. Adding a separate reducer behind is not ideal. Just browsing trough astrobin data, the Starizona results seem to be significantly sharper to me, than the Meade or Celestron reducers. Also, if the reducer optics is a good design, you can benefit  from some "MTF compression" effect, meaning that you can almost maintain the same angular resolution as with the long original FL. In daylight photography I got the same from my Metabones 0.64x (this actually might be an option for an EdgeHD + zwo astrocam combo)
No proper official spot diagram for the 0.63x unfortunately, this is the best I got:
https://www.widescreen-centre.co.uk/user/products/large/starizona_sct_corrector_web_01.jpg
V avatar
Impressive, maybe my next scope should be an XLT with that Starizona reducer instead, my only concern is I don't know if it'll illuminate an IMX410. The LF reducer probably would. Other concern is the lack of mirror locks, on my next scope I don't want to deal with mirror shift at all. Maybe I should keep thinking about a 12" RCT.
Anderl avatar
Thank you for all for your answers!
would it still be better to get an edge hd over an xlt as long as i only use it with the starizona 0.63 reducer? Mirrorflop etc?
how will the sharpness and the vignetting of an 9.25 or 11 sct paired with the reducer be if compared to a quality newtonian f4/f5 with an 2 inch focuser?
how often will i need to collimate an celestron sct? Every session?
one talked about the sca260 which seems to be a very interesting scope and i already talked to users here on astrobin about it. On the other side there is a lot of negative talk about that scope. Are all the potential problems solved with version 2 of this scope?
thx and cs
andi
Dunk avatar
Anderl:
I am not sure "sharpness" and edgeHD/xlt are often used in the same sentence ;-)
If you want sharpness, get a newt (and stop fretting about collimation - it's a non-issue if you buy a decent scope  and not hard once you have done it once or twice).
The edgeHD is more about having an incredibly versatile scope that can go both long and fast, but with compromises to both scenarios. You can use it for both planetary and widefield - there aren't too many scopes that can do this.
It's also big and heavy - which in itself may affect things like which mount you have to use, how often you setup/use etc.
Again I will mention the Epsilon (I am biased because it's what I use and I love it): light, fast and (relatively) inexpensive. Collimation holds for months/years. The focuser sucks and has to be replaced, but other than that its great.
...and its yellow.
V avatar
Mirror Flop is an issue on XLT's, I'd also look at the Starizona large format corrector if you intend to use a full frame sensor. You cant use the .63 on the Edge HD, as it is already aplanatic. I'd be curious to see if there are any reducers NOT designed for the Edge that would work.
If you want sharpness, forget the EdgeHD, put that 15k to good use and buy a used CDK14 (would say 12.5 but as its at the same weight, just get the 14).
An EQ6R will handle that, but uhh… Don't breathe.
But in all seriousness, any 8-12" Newtonian is a good choice.
The SCA260 is similar to a CDK in practice, but the aperture is offset moreso by a large central obstruction and an awkward focal length. I recall some people have had issues with the mirrors not holding collimation- at all.
I'd also like to recommend the Beamtech CDK250 as an alternate. It's built in, and ships from Australia, so it'll take a bit to get there, but its (very!) lightweight (for a CDK) at 10kg, and fits the budget nicely.
I just wish prices weren't more than a used car for equipment nowadays.
Dunk avatar
^^ THIS ^^
binning, f-ratio, pixel-scale, drizzle, onag vs oag and the consequences for my next imaging setup
Fellow friends of the night sky, Just two months ago, I opened a thread asking for your opinions on which scope to buy. Today, I’m back with a similar goal. I’m willing to invest a significant amount of money to either complement or replace my existi...
Both posts describe astronomers seeking advice on purchasing a second telescope to complement or potentially replace their current Esprit 120 refractor.
Dec 15, 2024
Full rig recommendations for beginners
So I put together this list of my personal recommendations for some beginner astrophotography rigs. It was an idea for a youtube video that I uploaded and I thought I share them here and see the community's feedback! One of the most frustrating t...
Both posts seek guidance on selecting appropriate astrophotography equipment for their specific needs and circumstances.
Aug 27, 2024
Big scope fever. Is big aperture only emptying your wallet?
Hello and good evening fellow astro friends, In case you are asking yourself why anyone would say things like i state in the title of this thread. —> mr. Timothy Martin here on astrobin is the answer. He and a lot of others to be honest. the first...
Both posts are from astronomy enthusiasts on AstroBin seeking advice or discussing equipment choices and capabilities within the community.
Sep 5, 2024
Esprit 120 w/ Nitecrawler vs TOA 130
Hello, I am looking for input from imagers who have experience with the Esprit 120 and the TOA 130. I am looking to purchase a new refractor solely for imaging, and am aiming for this to be a long-term scope. Here is some context for my use case: Ima...
Both posts seek advice on selecting a second telescope for astrophotography imaging purposes.
Apr 27, 2024
