Edge HD 9.25 and Esatto 2" focuser
11 replies377 views
Jerry Gerber avatar
I am installing an Edge HD 9.25 with the Esatto 2" focuser at a dark sky site.
I understand there's 146.05mm of backfocus. i will be imaging at native focal length (2350mm) and will not be using a reducer.
Image train will be something like this:
Scope - 2mm adapter - focuser (67mm) - OAG  (?) - filter wheel (20mm) - ASI 2600MC camera (17.5mm).
The problem seems to be the OAG.  Although it's 29mm in thickness, it needs an SCT adapter (or does it?) on the scope side and 12.5mm adapter on the other side.  This doesn't seem like it's going to work.
Anybody using the Edge 9.25 with the Primaluce Esatto 2" focuser and the Celestron OAG?
Thanks!!
Jerry
Scott Badger avatar
If you’re not using a reducer,  don’t you just need to make sure you’re optical train length puts you in the middle of the focus range vs a specific BF length? Put another way, aren’t you changing the “backfocus” length whenever you adjust focus? I thought BF is a set distance between a reducer/flattener/corrector (if you’re using one) and the sensor. All that said, some diagrams of the 9.25 edge show a corrector built into the primary baffle….
Scott
Jerry Gerber:
That is the optimal backfocus but not necessarily the one right for you and in fact small variations (of few mm up or down) won't make a lot of difference in the end results. In addition you can remove the tilt plate and fasten the FW (assuming it's ASI compatible) directly to the back-face of the camera, as shown in the ASI website, thus gaining an extra 5mm. Also use a ASI OAG-L will fit the bill.
John Hayes avatar
Jerry Gerber:
The tolerance on the back working distance varies with the size of the sensor.  Since Jerry is planning on using a “full-frame” sensor, he’ll need good image quality out to a 42 mm image circle.  Getting the spacing right is critical to minimizing astigmatism in the field.  I know that on the Edge14, the tolerance at an image height of 24 mm is roughly +/- 50 microns.  I’m not familiar with the Edge 9.25 but I’m sure that the spacing tolerance will be much tighter than “a few mm”.   Using an external focuser to make very small adjustments to within ~ +/- 3*DOF will work but it wouldn’t be my first choice for holding focus on a SCT.  I personally think that the SMFS system from Optec is a better way to go.
The OP's intended sensor is an IMX571 so 28 mm image circle diameter and I'll reiterate my original statement, few mm difference won't show up in a meaningful way in the image circle. I also know as I tested it on a friend's scope a while ago.
Jerry Gerber avatar
Yes, I've thought about a full-frame sensor, but will most likely go with the ASI2600MC, not quite full frame, but not small either.  I'm already dealing with 50MB subs and my SSD drives are filling up fast.  The file size of full-frame are over 100MB per frame, so I think I'll stick with the ASI2600, which gives excellent results.
John Hayes avatar
Right.  I some how flipped 2600 to read 6200.   If you've tested it on the same scope with the same sized camera and found that that +/- 1-2 mm doesn't make a difference--and you carefully checked the astigmatism, then I'll buy it.  It is a LOT more restrictive on a Edge 14 with a larger sensor.
Jerry Gerber avatar
I am assuming that the image train for the Edge 9,.25 and the Esatto 2" would be as follows:
SCOPE - 3.3" adapter - Focuser - Celestron OAG - ZWO filter wheel - Camera
Does this seem right?   Since I will not be using a reducer I am not sure I need to worry about backfocus as the Edge 9.25 has 146mm of backfocus, which should be enough.
Anyone disagree?
Thank you!
Jerry
Website
Astro Music Videos
Charles Tremblay-Darveau avatar
Can someone confirm that this focuser works for full frame with and without reducer on the edge 9.25? Any vignette or reflections/scatter?
ScottF avatar
Charles Tremblay-Darveau:
I asked that question to someone I know that uses it with full frame on an edge 14" and he says he has no vignetting issues.
ScottF avatar
Jerry Gerber:
Anyone disagree?
Thank you!
Jerry
Website
Astro Music Videos
I have almost the same setup. I racked the focuser out to the halfway point and then used adapters/spacers to get my 146mm BF distance; sequence is sct adapter, 2" esatto, adapter to two OAG-L, 2" FW, and 2600MC. Due to other ongoing projects, I haven't managed a night with it yet, so I can't say how well it performs. However, I am almost done with my present object list and will be mounting it shortly.
Kostas Papageorgiou avatar
With this setup you reach 135.5mm of backfocus...so you are off 10.55mm.. i think you can focus with main focuser on telescope then extent the essato focuser to reach optimal back focus.. i was looking too for this. Maybe this will help you:
https://eu.primalucelab.com/aplanatic-schmidt-cassegrain/celestron-edgehd-925-with-losmandy-bar-and-esatto-2.html
Kostas.
Edge 8" Image Train with OAG and ASI2600MC Camera
Dear Astrophotographers, I recently bought the Celestron Edge 8 and am waiting for the OAG. I have no idea what the backfocus should be when I use this scope with the ZWO ASI2600MC camera. ZWO recommends a backfocus of 55mm, but I am not sure that ap...
Discusses backfocus measurements for Edge HD scope with imaging camera.
Dec 23, 2022
Manual Focuser for the Edge HD 8"
Hi, I recently purchased an Edge HD 8" scope and require a better focuser for astrophotography, I'm not using this telescope for visual observation. At this time I am not interested in an electronic focuser. I understand there are two kinds ...
Edge HD 8 with Esatto focuser installation and backfocus discussion directly relevant.
Jan 14, 2023
Backfocus question
If I am using an Edge 8" with the OAG and a reducer, the backfocus should be 105mm. With the current adapters and spacers I have, my backfocus comes to 105.3mm. Is this critical enough that I should get different spacers and try to get closer to...
Edge HD backfocus calculation example with similar imaging setup concerns.
Dec 26, 2022
AM5 Mount and the Edge HD 8"
Hi! I've been getting very good imaging results using the ZWO AM5 mount with the Esprit 100ED refractor. I also have an Edge 8" and haven't yet imaged with it. I know it's going to be much more challenging, but is it doable? What dif...
Edge HD focuser and backfocus considerations for imaging setup.
Mar 1, 2023
External focuser on an SCT; What about temperature change induced focal shift and back-focus?
It seems like every serious astro-photographer is putting external focusers on the back of the EdgeHD telescopes and locking the mirrors. I picked up a nice little EdgeHD 8" and a Primaluce Lab Esatto 2" LP focuser and gave it a try myself....
Directly addresses external focuser installation and back-focus considerations on EdgeHD telescopes.
13 days ago
