Luminance eccentricity issues
7 replies210 views
Chase Davidson avatar
Hi everyone, I'm having a particular issue that I can't seem to get around. I've been taking subs of the fireworks galaxy for the last week and after each night I usually do a quick subframe selector to see what I need to gather for the next night. I generally use this as my approval and weighting:
Approval:  FWHM < 6 && Eccentricity <= 0.6 && Stars > 500
Weighting:  SNRWeight
I've generally gotten 90+% of acceptance with this when I have a clear night...except with my Lum data. It's very frustrating. I understand Lum data needs to have a much lower exposure so I do RGB at 120 second and Lum at 60 seconds...but they are still coming out terrible in eccentricity. Anyone else know what's going on? My tracking has been between .2-.3, autofocus ever hour, so I don't think it's the mounts fault. In fact I even take Hydrogen data before Lum the last two nights and every hydrodgen sub has been accepted. Whats going on with my lum?
You can see the Lum data vs the RGB (right side) acceptance in the screenshot below. Should I increase the acceptance to .65 eccentricity (it'll add another 3 hours of acceptable lum data) and just live with it?
Oskari Nikkinen avatar
You should investigate the source of your eccentricity problems as a start. I am not convinced your tracking accuracy is as good as your stats indicate, so how are you guiding and with what scope? There could be differential flexure problems if a reflector without an OAG, or just an unstable guide scope mount if thats what youre using. Eccentricity of 0.6 is really not very good so i am quite sure you have some issues to work out.
Another possible reason is dropping altitude. I see that you started with the target decently placed at 58 degrees, but towards the end of the night this means you are quite low in the sky and RGB separation due to atmospheric effects will play some role in this. There is also a suspicious drop on quality towards the end, which could be local seeing effects for example from thermal currents rising from buildings down range or something like that.
* edit: ignore the last comment above, i read your graph wrong as the last data is the best. Still some issues to work out.
Helpful Insightful
Oskari Nikkinen:
The seeing conditions very well could be the issue. I use an OAG on the astro-tech at130 edt but I've been taking Hydrogen shots for the first 3 hours of the night and then taking Lum shots when it's low in the sky. I did capture 3 hours of good Lum data a few nights ago (middle of the graph above) but I think it was when the target was high in the sky.
As you get very short on integration time, variations and seeing and guiding will be more apparent and will be more likely to have non-round stars. All those things have a tendency to average out over 2 or 3 minutes so it's easier to get round stars.
At your image scale you shouldn't take luminance frames below 40 deg or better still below 45 deg.
Take a look at this article: https://britastro.org/2017/atmospheric-dispersion-and-its-effect-on-high-resolution-imaging
The article refers to planetary imaging but the dispersion due to altitude also of course applies to long exposure DSO imaging. Scroll down a bit and you will find a nice graph showing how much the red and blue ends of your luminance are dispersed by altitude. At 50 degrees its already 1 arc second, and it only gets (rapidly) worse with lower altitudes. Try to shoot L at high altitudes and do RGB otherwise is the take away here.
Helpful Insightful Concise
Another night, another bit of odd lum data. I started before the meridian flip last night and it seems everything before the flip had good tracking. I'm starting to wonder if I have a weight balance issue or a wire is pulling once the flip happens. I do notice a strange loud popping sound when the AM5 tracks to the right every now and then.
I stop taking subs before the target got below 40 degrees last night but as the data shows, the tracking issues started at ~47 degrees right after the flip.
Oh gosh, a big clue there. I wouldn't think the AM% would be too bothered by slight balance issues. Something changed after the flip though, a mystery to track down for sure. I have no idea what that pooping sound means for a harmonic drive but it doesn't sound good.
FWHM vs Eccentricity - How to filter the good frame in Subframe Selector in PI
I had a really good night of imaging the Statue of Liberty but the following night was not as good. I use PI's Subframe Selector with the below settings to filter out the good from the bad. As the Subframe Selector calculates an average over the ...
Both posts discuss using PixInsight's Subframe Selector tool to evaluate and filter astronomical image quality during data collection.
Feb 4, 2025
Culling choices
This is something that I’ve been observing for awhile now and wanted to share. My usual culling routine would be to reject images with both high eccentricity and high FWHM. But when taking a closer look it seems that a lot of my subs with high eccent...
Both posts discuss using FWHM and eccentricity as quality metrics to filter astronomical subframes during image acquisition and processing.
Feb 17, 2026
How do you organize your lights, flats, biases and dark frames??
Hi folks, I need some suggestions.. per my subject line, how are you all organizing your lights and calibration frames?? I image with a ASIair… and generally I plug in a 16GB usb thumb drive into one of the USB ports for the night to store my i...
Both posts discuss practical workflows and organizational strategies for astrophotography data collection and processing.
Aug 11, 2024
Rescue mission: stacking of NGC 5128
I'm at my wits' end and would like to ask for some help to save the data from a session imaging NGC 5128 that I thought would be an absolutely stunning image. I'm new to big telescopes, stacking and post-processing. I have Celestron 9.25 ...
Both posts describe challenges encountered while collecting or processing astrophotography data from deep-sky objects.
May 11, 2024
