How to register with large atmospheric distortion?
5 replies255 views
HR_Maurer avatar
After capturing a lot of imagery with comet C/2023 A3, i'm struggling to stack those images because of imperfect registration. This comet has been standing very low in the east during dawn.
The subs i want to stack were shot with a Sony a7iii and a 135 mm lens, mounted on a star tracker. Nearly all include the horizon, which is ~1.5° below the point of observation. Looking a loong way through atmosphere. There is a large area of ~undistorted star field in the images, which can be registered. Towards horizon, distortion increases and becomes very large. Since the images are tracked and stars were rising, the distorted area is different in different subs. And on top of that, dawn has begun and there are large and changing gradients in the sky.
I've been trying to tweak Image Registration parameters, and also tried repeated registering, but none of that worked so far. I think the registration model is important, as well as the method of interpolation. But im not 100% sure if the stars in the brighter image areas have been detected at all.
Ive been trying to create an undistorted artificial reference. But so far ive been failing to plate solve one of the subs. So, at the moment i ran out of ideas.
Manual registration.
Scott Badger avatar
In Pixinsight, DynamicAlignment.
Scott
HR_Maurer avatar
Okay 👌
I did this before. This is the last option. I'd rather write my own registration code in Matlab.
Tromat avatar
"Thin plates splines" instead of standard "projective transformation" in Pixinsight should be able to manage this.
HR_Maurer avatar
Okay, so here's what i did for proper registration:
1. calibrate (of course)
2. remove background gradient
3. eventually remove median
4. Register, using Thin Plate Splines, and star matching: Quadrilaterals. I used 8 detection scales under star detection for my specific images
worked.
Problem with Star Aligbnment in PixInsight
I have 54 four- minute subs of M81 that I am trying to align, taken at a focal length of 1422mm. Many of the subs are failing to register. Which parameters in StarAlignment are most likely to help me align the maximum number of subs? And should I try...
Addresses image registration challenges with atmospheric distortion affecting star matching.
Mar 17, 2023
