Minimum gpu?
8 replies199 views
Mark Worthington avatar
Based on your experiences, what spec of gpu is the minimum needed to use this software to the extent you require?
Thanks
Mark
TiffsAndAstro avatar
For cuda a 1060 is probably minimum.
Bob Rucker avatar
The difference a 1060 provides is significant so I agree that is a good minimum. I built myself a new processing PC and upgraded my 1060 to a 4070 TI and that really bumped the performance up even more. My PC runs BXT and StarX more than fast enough to meet my needs so I think upgrading to a 4080 or 4090 wouldn't make enough of a difference to be justifiable.
I would add a caveat that this opinion probably caps out to APS-C image sizes. I'm guessing that the ultra high end cards make a significant difference for anyone churning through the mega file sizes from full frame sensors.
Bob
Helpful Insightful Respectful
TiffsAndAstro:
*Thank you. 👍
Bob Rucker:
Bob
*Thank you 👍
Bill McLaughlin avatar
Agreed. I just went from a 3060 to a 4080 and performance was better but only took BXT times for an APS-C from around 30 sec to around 20 or so.  Not worth it for that.  I did it mainly for gaming performance, however. The 4000 series may also may require a bigger PSU, depending on what you have. PCPartPicker can do an estimate for you.
If  I did not care about gaming, I would get a 3060 or 3070 and maybe even wait until the 5000 series comes out and get a 3000 series. They are now in the mid 300 range and would come down even more.
Benny Colyn avatar
Last I checked, AstroPixelProcessor (look at the forum this is in) does not use the GPU for anything except smooth rendering of the UI. No actual number crunching is done, a discrete GPU isn't needed for APP.
If you're buying with an eye on the future, all GPU acceleration of Tensorflow on Windows is in limbo as far as the future goes, with the exception of WSL2. Caveat Emptor
Joe Linington avatar
For APP, nothing. To accelerate the RC Astro plugins for PixInsight, A GTX 970 or GTX 980 with 4gb of ram is a minimum with a 6gb GTX 1060 or 8gb GTX 1070 offering better performance for a small difference in price.
Bob Rucker:
Bob
I'm glad your 4070 is an improvement over your 1060.
As it should be
Mini PC specs recommendations?
Hi, I ordered another mini-PC but this time it is from MeLe models, and i want to know how much RAM and drive storage you really need if you use it into astrophotography. I think i will be using it for anything, be it DSO or planetary or solar, for D...
Discusses hardware specs and RAM/storage requirements relevant to software performance needs.
Sep 8, 2025
Advice needed for first time dual setup with SGPro
Hi everyone. I'm going to start using a dual setup. I currently use SGP and want to continue using it. I'm configuring the program, but I wanted to hear about your experience with dual setup systems and using SGPro to avoid problems and get your advi...
Addresses software configuration and setup optimization for specific use cases.
Dec 16, 2025
