How to Connect to AM5 from ASIAIR+ ?
5 replies199 views
Andyb90 avatar
Hi everyone,
I’m trying to connect to my AM5 mount from my ASIAIR+ via WiFi, but I keep getting a connection error.
This is what I have done so far.
1. Powered up the AM5 and connected the hand controller.
2. Used the SkyAtlas app to update to the latest hand controller and mount firmware.
3. Noted the hand controller ip address in the SkyAtlas app. That is the ip address in the AMH Management System -> Hand Controller WiFi Info section of the app.
4. Input hand controller ip address in the ASIAIR+ mount settings and attempted to connect to the AM5. This is where I get the connection error.
I did see the help info in the ASIAIR+ says to put the mount into station mode for the wifi connection, but I can’t see how to do that. Not sure if that is what I’m missing or something else.
If anyone could help me with how to make the connection work I’d be grateful.
Thanks,
Andy
Tom Boyd avatar
Hmmm. Can't really help as I've never tried to Wifi directly to the AM5. But, curious as to why you want to do this? Why not ditch the hand controller all together, hardwire the AM5 directly the ASIair and then wifi to the ASIair?
Andyb90 avatar
Tom Boyd:
I thought I could avoid having the cable running from my ASIAIR to the mount as I’m always worried about cables snagging. I got the Wi-Fi working but slew commands are hit and miss via Wi-Fi so will just stick to usb.
donsinger avatar
A WiFi connection to the mount is unreliable. Do as suggested by connecting the Air to the mount via usb and then tablet to asiair via wifi…solid as a rock
AYYYOO I'M GALILEO avatar
1)Enable station mode on the AAP+
2) set the AM5 to join the AAP-created network. Note the ip and port for the AM5.
3) on the AAP under mount, set to WiFi and enter the AM5 IP and port
apennine104 avatar
Regarding reliability, when I used an ASI Air/AM5 combo, I ran them wirelessly for mount control and never had issues through several multi-night runs. So, while a cable is more reliable, the wifi seemed fine IMO.
Well Written Concise
AsiAir Pro compatibility with Nikon D3500
Hello, I was wondering if someone tried to connect the Nikon D3500 DSLR with the AsiAir Pro. And if so, how did you do it? ​​​Thank you in advance and clear skies!
Addresses connecting equipment to ASIAIR via WiFi; similar connection troubleshooting.
Dec 20, 2022
ASI533MC Pro Cooling Fluctuation!
Hello, Coming from DSLR, I Just got an ASI533MC Pro and trying it for the first time. I'm connecting it to ASIAIR Plus (Both power and USB 3). I set the cooling to -10 C and took the light frames with no issues. When I'm taking Flats and Dark...
Not relevant - different equipment (AM5 mount connection issue).
Mar 6, 2023
Nexstar hand controller firmware update failed, display showing odd squares
trying to update firmware on nexstar hand controller, every time i try it says update unsuccessful, tried resetting and but didn’t work, then tried use newest cfm but that didnt work, contact celestron support but they are having holiday party today ...
Nexstar hand controller firmware update issues similar to mount connection problems.
Dec 5, 2025
A Few iOptron HAE43 setup questions
I just started setting up a travel rig with a newly purchased iOptron HAE43C mount. It connected immediately to NINA, but I have a few housekeeping questions. BTW- no manual came with it. So, I had to download but it still did not address my question...
iOptron mount setup and connection troubleshooting relevant to your AM5 setup.
24 days ago
EQstar double motor system won't connect to iPhone with SynScan pro
So I own an EQstar double motor system. When I first installed it I owned Samsung phone and tablet, and I got everything to work as it should have. Now after having been ignored in the storage shed for several years, I now own an iphone, and I cannot...
Hand controller WiFi connection issues with mount control system.
Nov 17, 2025
