Why does Seastar Decalibrate After Use?
1 reply54 views
Szijártó Áron avatar
Hello and welcome. I'd like to ask everyone who has a Zwo Seastar S50 device. Has anyone else experienced that after using Seastar, It suddenly decalibrates its level. Like even if u set it to the perfect level for astrophotography, it sometimes decalibrates, and u have to reset it to the desired level. Also, when you want to find an object that is way above the horizon, sometimes the seastar doesn't turn to that object; instead, it will look down to the ground and have to reboot it. Does anyone know what's causing this um issue?
I have never used on but I do know that any alt/az system will have issues when trying to point near the zenith. Most systems have a no go zone around that point of a few degrees.
Having Trouble With Leveling. What Leveler Adjuster You Guys Suggest For Seastar?
Hello and welcome id like to ask everyone who using seastar with leveler Adjuster. Since im started to use the device im kinda having trouble with Leveling while there some stuff i want to capture with it in the right time. Are there any fine leveler...
Sep 2, 2024
Both posts discuss technical difficulties users are experiencing with the Zwo Seastar S50 astrophotography device, specifically related to leveling and calibration issues.
Is Seastar S50 Limited To Stars?
Hello and welcome. I'd like to ask everyone that houses Seastar S50. Is the device limited to stars? Last night, I went to photograph some deep space objects like the California Nebula. When the device is about to process the image, it says it ca...
Aug 26, 2024
Both posts discuss technical problems users are experiencing with the Zwo Seastar S50 astrophotography device.
If The Device Allredy Stacked Images During Enhancement, These Cant Be Stacked In The Deep Sky Stacking Menu?
hello and welcome, I'd like to ask everyone that if I let my Seastar S50 do the stacking while it's enhancing the images, does this mean that you can't stack those images in the stacking menu in the app? Only those that if u do this manua...
Aug 27, 2024
Both posts are seeking technical support and troubleshooting advice from other users regarding issues with the Zwo Seastar S50 astrophotography device.
Can You Really Got Bored Of The Seastar?
Hello and welcome! I’d like to ask everyone who uses the device for astrophotography about their thoughts on the Seastar S50. Do you guys find yourself getting bored with it? It recently received a minor update, which introduced features like mosaic ...
Nov 18, 2024
Both posts are seeking user experiences and feedback about the Zwo Seastar S50 astrophotography device from the astronomy community.
