I can't add much to what
@John Hayes had to say as far as the most perfect setup one could want for a C14. His work with a C14 is what the rest of us aspire too! That being said, the setup he mentions works just perfect but it is pricy. I just started imaging with my C14 this past spring. I shut down for the summer but I'm in the process of putting things back together for the fall. (Phoenix has had 113 continuous days OVER 100F this summer, and we are still having weeks on end over 100F. Tough to cool a camera to -10C when it is 40C at 10pm). My C14 is set up on my AP1600AE mount, which is the bomb.
That being said my Phoenix skies in the fall/winter/spring time are Bortle 6 - 7. I found a few things. As
@John Hayes mentioned, you need to guide a C14 with some type of OAG or in his case ONAG. I tried 3 different guide scope/camera combinations and I could not make any work successfully. (Stars would not be round and I was getting streaks). I switched to an OAG setup. I have a Moonlite Compact focuser specifically for SCT's but you can't fit a Moonlite on the back AND use an OAG. There is not enough back focus to do that. I have two focusers on my C14. My Moonlite on the center back and a Pegasus Cube Zero that drives the C14 focus knob. I use the Moonlite for visual use and imaging planets and the moon. You don't need to guide for either of those targets. I use the Pegasus to "center" the Moonlite focus point and then I lock the mirror and only focus with the Moonlite. This keeps things tight as for planets as you like to shoot around the meridian to keep your imaging through the least amount of atmosphere. With the mirror locked you get little to no movement and with my AP1600AE in most cases I can shoot well past the meridian without having to do a flip. Depends on what is up and where but with the AP you can push it.
For DSO photography with my C14 in Phoenix under my Bortle 6-7 skies like I mentioned, I found I cannot use my C14 without the 0.7x reducer. The problem is when you are guiding with an OAG and you are at F11 mode, unless you are shooting right in the heart of the Milky Way, it is quite difficult to get enough stars to guide. In fact at F11 I was finding it next to impossible to even find objects because I could not get enough stars to plate solve after a go-to. I use the Celestron 0.7x reducer. With that, I'm now shooting F7.7 and have a wider FOV. The combination of a wider FOV and the brighter stars due to the shorter focal length I can plate solve with no issue. I can make very large pointing models. I use the Celestron OAG designed for the C14 and I use an ASI174MM as my guide camera. I shoot using NINA and I autofocus with the Pegasus Cube. Now, since I am using the Pegasus I obviously have an issue because the mirror is not locked. I have found so far, that tends to not be a huge issue, most likely because I have my C14 on an AP1600AE mount. When I pass the meridian I always do a plate solve to repoint and an autofocus so after a flip, I have "fixed" the mirror flop and because my AP tracks so well I don't have much correction even with the flop. (My C14 Edge HD is relatively new, purchased only a few years ago from B&H Photo) I shot
M27 last May and it came out quite nice I think. The other thing to think about is if you wish to use a Hyperstar with your C14 as I would like down the road, you cannot use the setup
@John Hayes mentions because the secondary focuser is replaced with your Hyperstar so you need something like the Pegasus Cube Zero to focus your image. Now however, with a Hyperstar you are shooting at F2 so you have boatloads of light over a very wide FOV so plate solving and pointing is a non issue. Guiding with a guide scope/camera at F2 should also work well but I have not tested this as I currently do not own the Hyperstar adapter.
Lastly, if you have nice dark skies where you have your C14 I would go ahead and try guiding OAG at F11 and see if it works. Since you have an AP100AE your capabilities are very similar to mine. Down the road, I would like to duplicate
@John Hayes setup but there are a few more things I want to try first. Since we both have AP mounts with the absolute encoders, we should be able to use DecArc models and just bypass guiding all together. I was just at the point of trying this out earlier this year when summer hit hard and fast and I had to take down my setup. It is one of the first things I want to try once I get things back up and running. With an AP mount I really think for most things, we should not have to guide at all but that remains to be seen.
Phil
