Hello
I was wondering if there is a risk to use a cooled camera with a power supply that has the right voltage but a lower amperage than required.
In my case I have a QHY294M that uses about 3 Amps when the cooling is at 100%.
At 100%, the camera cools about 35°C below ambient, but because the power consumption grows with the square of the temperature difference,
it only needs 25% power to reach half of the maximum cooling or about 0.75 Amps for 17°C below ambient (I've tested that).
So my plan would be to use a portable 5v/2.1A batterie that are really common, cheap and realiable and a 5 to 12v converter that will give me a
12v/0.875A (minus the conversion loses) power supply to get about 15°C below ambient which is sufficient in my opinion for portable imaging.
Does anyone know if doing that can in any way damage the camera or have other negatives effects ?
Clear Skies
Clear Skies
