Can We Merge 2 Astrophotography images into One?
4 replies547 views
Szijártó Áron avatar
Hello and welcome I'd like to ask everyone who knows a way of method to merge 2 astrophotography images into one. I have 2 separate images I captured with my Seastar s50 of the horsehead nebula and the flame nebula. The first time I tried to capture them both, there were fewer starts in the area where I tried, and Seastar couldn't do more exposure times. So I had to do them separately. Does anyone know how to merge astrophotography images?
You can do this in Affinity Photo using the Panorama function. It's very easy since both images are taken at the same focal length. Affinity should blend them together perfectly.
TiffsAndAstro avatar
Also Microsoft ice might be worth a look for a beginner
danieldh206 avatar
Search how to make an astro photography mosaic. Mosaic is the word used to to combine or merge two images together to make one big image. Also the word stitch is sometimes used. Stitch to images together to make one big image.
To do it well you will need the unprocessed FIT file from the SeaStar. The mosaic can be made with the jpeg files but getting the gradients correct could be difficult.
Many software programs can stitch images together but they usually do not work correctly with astro photography images because there is not enough contrast to align the images.
The only free software I know that can make astro photography mosaics is called ASTAP. What software do you have?
I used Microsoft ice for this 4 panel of Cygnus loop and I think it turned out well for a beginner like myself. I'm certain pixinsight or other tools may well have better results
https://stargazerslounge.com/gallery/image/39373-veil-nebula-4panel-mosaic-as-acjpg/?context=new
Is There Any Method To Get Rid Of Artifacts?
Unprocessed Image Of Andromeda Galaxy https://imgur.com/a/98IUK1g Hello and welcome. I'd like to ask everyone who is using Seastar or any method to get rid of all of the artefacts in their deep sky images. I have a pretty good image I made with m...
Both posts ask for technical advice on post-processing astrophotography images captured with a Seastar telescope.
Oct 1, 2024
How To Fix The Script Failure In Siril?
Hello and welcome. I'd like to ask everyone here who uses Siril to preprocess their astrophotography images. Does anyone come across such script failure that even if i use fits files which the software uses, the software still fails the Script? I...
Both posts describe technical challenges encountered while processing astrophotography images captured with a Seastar telescope.
Aug 28, 2024
Anyways To Process Galaxy Images Without Photoshop?
Hello and welcome. I'd like to ask everyone who already did or knows an alternative way to process Galaxy images without Photoshop. Does anyone know how to process any Galaxy images without using Photoshop? For me to process any images like that ...
Both posts seek advice on post-processing techniques for astrophotography images while facing technical or resource constraints.
Sep 9, 2024
Any Help With Mosaic Processing?
Hello and welcome. I'd like to ask everyone who used or is using Seti astro software if it can be standalone or built into other software. Does anyone have any luck with Seti Astro? I am trying to process the mosaic stacked image that my seastar ...
Both posts describe challenges with processing multiple astrophotography images captured with a Seastar telescope and seek advice on software solutions for combining or processing them.
Jan 5, 2025
