Can We Use Ha Scripts Or Hubble Palette Script on Light Frames?
5 replies240 views
Szijártó Áron avatar
Hello and welcome! I'd like to ask if anyone has experience using light frames with scripts other than the without Darks, Flats, and Biases script. I'm curious if we can use any enhancing scripts to modify our RGB-based images. Is it possible to use these scripts on light frames, or are they only usable with all of the calibration frames as well? If so, it's disappointing if we can't apply these scripts in siril.
Harry Karamitsos avatar
Which scripts are you asking about?
Harry Karamitsos:
I meant the palette scripts like the Hubble or the Osc Ha or Ha extract script.
Szijártó Áron:
Harry Karamitsos:
Hello Szijártó,
I think you are a little confused regarding the Siril scripts. Those scripts are meant to use with stacking RGB images in the first place, calibrated or not, otherwise it won't work with individual files. Some of the scripts that you describe like the one for treating the RGB image without a Dark, or a Flat, etc. means if you don't calibrate the stacking image with one of those calibration frames, the script can try to mimic the lack of those, but they don't do a perfect job as if you actually use the proper calibration frames.
Scripts like the one you mentioned for extracting Ha or the one for Hubble Palette, are simply trash with a fancy name. The one for extracting Ha, what he does is splitting the RGB's channels in individual channels, nothing that cannot be done manually in Siril or other editing software. The Hubble one, uses the same technique but, insted of leaving a mono image from the channel, recombine the RGB with some data manipulation to mimic the colors of an SHO. He just manipulate the data of the color in each channel to give a look of something that is not. Other softwares like the AstroPixelProcessor also have something similar to that, and even in PixInsight you can also fake that too. To achive an Hubble Palette, you need 3 pure and separated channels. Can be done with a mono or a color sensor, but the signal needs to be captured and separated by filter. Other than that is scientifically impossible to be done.
But rebember.. You always need a stacked image to work with them.
I hope I gave you some insight about your question.
Regards,
Cesar
Observatório Astrográfico do Boqueirão:
Szijártó Áron:
Harry Karamitsos:
Hello Szijártó,
Regards,
Cesar
So this modifcation scripts in siril or whatever they are, they can be used or applied without any Calibration frames? For example if I only have lights then I could work with these scripts along with light frames. Right? Sorry im just a bit disoriantated on the useage of these scripts. And i was uncertain whether any modification script could be applied to only  just light frames.
You can use them without calibration frames, but only in the a stack RGB with the light frames. Only in a stacked image. Not in the individual frames/light frames. And the results won't be the same using those scripts, because for example the script for flats can mimic the vigneting pattern, but cannot do anything regarding the dust spots. Just an example..
Bottom line, I know calibration frames sometimes suck to do, specially if you're using a DSLR.. but they need to be done. There's no magic solution to work things around.
Regards,
Cesar
How Does Seastar's New Flats Work?
Hello and welcome, I'd like to ask everyone who is using Seastar and has taken flats with it or has experience, how does this work? I recently managed to do the flat shots with my Seastar, but there's one thing I don't know about this. Li...
Discusses flat frames usage, relevant to calibration frame processing workflow.
Jul 28, 2025
[PixInsight] How to prevent Flat overcorrection?
I'm not sure why, but my light frames are getting "overcorrected" by the Flat calibration process of the WeightedBatchPreProcessing script. Does anyone know why this happens and how I can prevent this? Is this maybe due to the large dar...
Discusses light frame processing with calibration scripts and frame types.
Dec 24, 2022
Which imaging acquisition and processing techniques could I learn more about to increase image quality and accuracy?
Hello, I use a full-frame mirrorless camera, I mostly do daylight photography, some night photography and astrophotography too. I did hightlight in bold keywords to make it easier to scroll thru, for those that don't want to read most of my post. Bef...
Covers imaging techniques and processing methods for improving astrophotography image quality.
Dec 29, 2025
Gradient in dark frames
Hi everyone! I recently bought the Player One Poseidon C Pro camera and after a very long period of cloudy nights it finally cleared and I got to try it. When taking the lights everything was normal. When the sun rose again the pictures got very satu...
Addresses dark frame issues, directly relevant to calibration frame processing in Siril.
Mar 5, 2026
Flat Darks or Bias?
Hello, I'm going to be using the Esprit 100 ED with the ZWO ASI2600MC camera, sitting on a ZWO AM5 mount. I'm wondering whether I ought to take dark flats with my flats or forego the dark flats and take bias frames. Anyone using this camera h...
Discusses calibration frame strategies including bias frames for astrophotography processing.
Nov 11, 2022
