NINA 3.1 HF2 and my QHY247C Sequencing Problems
1 reply87 views
Richard Strouse avatar
I'm having a problem running my sequences in NINA. First let me list my equipment: CEM70 iOptron mount, QHY247C camera, Pegasus Falcon v1 rotator, ZWO Focuser, RedCat 51, Orion 60mm scope with ZWO ASI174 (for guiding), Pegasus Ultimate Power Box V3, MeLE Quieter3C Fanless Mini PC with Windows 11. The RedCat and guide scope are mounted on my Explore Scientific ED102. Wow that a lot of money, I've spent! Now the problem.  Last night I was sequencing The Heart and Soul nebulae. Several times the sequence stopped (Legacy sequencer) before my preset number of 60, 6 min exposures. The mount parked and the camera went to warming mode. Guiding stopped, and the progress of exposures showed that I had finished taking all 60 (in reality, not even close).   Now this didn't happen to me before, but admittedly, I've just started DSO photography. Also very curiously, the camera sensor which had been set to -10 C, showed a temp of over 2 billion degrees!   And these problems "seemed" to start after my upgrade to NINA 3.1 HF2. Or is it my camera?  Or is it Windows 11, corrupt driver?  I'm not sure. I was wondering if anyone out there has experienced anything like this.  Before this occasion, I sequenced the Cygnus loop and the North America and Pelican nebulae without incident. Any help would be appreciated from, the much more knowledgeable than I,  members of the forum. Thanks,Richard Strouse
Helpful Respectful Engaging
TiffsAndAstro avatar
Honestly I was going to suggest user error, but 2 billion degrees C suggests it might not be smile
Might be worth looking up Nina discord server, almost certainly a driver compatibility bug?
​​​​​​Is it possible to revert to previous Nina version for time being?
Need help: NINA meridian flip at wrong time
📷 Bildschirmfoto 2026-01-04 um 19.12.50.pngRecently, I've encountered the following problem in NINA: The time for the meridian flip is no longer correct, but all other times are displayed correctly. The system time in Windows is correct, and the lati...
Author uses NINA sequencer; meridian flip issues are common problems.
Jan 6, 2026
Possible NINA Mount Control Issue
I connect to my Tak EM200 mount using The Sky Pro 64 and control my imaging through NINA. This has worked well many times with the same sequencer templates. However, last night I had imaged up to the meridian, manually done a meridian flip and then s...
Author uses NINA with mount control; similar equipment integration problem.
14 days ago
NINA Repeatedly Disconnects from Observatory Safety Monitor & Weather
Nina is repeatedly disconnecting from my observatory's safety monitor and weather. I should mention this is at a remote observatory, I'm some 900 miles away from my scope. I added the Reconnect: Safety Monitor and Reconnect: Weather to the Ad...
Author uses NINA sequencing; safety/connectivity issues relevant to troubleshooting.
Sep 1, 2025
Very Weird NINA Behavior (or ASCOM?)
Are there any known new bugs in the latest versions of ASCOM and/or NINA? Last night all the images were taken properly but NINA's sequencer shows that only 1 out of 45 blue filter images were taken when in fact I just downloaded 180 images plus ...
Author experiencing NINA sequencer problems; similar unexplained behavior issues.
Dec 18, 2025
Don't underestimate what Claude can do with your NINA Advanced Sequencer JSON
Been using Claude (Anthropic's AI) as a hands-on co-pilot across my entire AP workflow — not just for generic questions, but with direct access to my files, FITS headers, and sequencer JSON. Here's what a single session looked like. It started by rea...
Author uses NINA Advanced Sequencer; JSON automation could optimize workflows.
13 days ago
